Bob
Joined: 24 Oct 2006 Posts: 89 Location: Damascus, Maryland, USA
Posted: Wed Mar 28, 2007 7:46 am Post subject: Rustoleum? |
Quiet day on the site and I don't have any epoxy paint available right now, so ...
Any actual experiences or problems with using Rustoleum to touch up some nicks in powdercoat? We're talking match-head size stuff, not repainting a length of tube. I have small cans of primer and gloss in white, matching the powdercoat. The alternative on-hand is some clear 2-part epoxy. My metallurgist friend says to use the Rustoleum, due to the zinc in the primer. As much as anything, I'm wondering if PolyTac will dissolve it (due to the MEK) but then re-seal the nicks. Again, I'd appreciate actual experience, not what people think maybe could happen.
Bob
_________________ Remember that internet advice may only be worth what you pay. |
Aerobatics(at)aol.com Guest
Posted: Wed Mar 28, 2007 7:51 am Post subject: Rustoleum? |
In a message dated 3/28/2007 10:49:05 A.M. Central Daylight Time, dswaim1119(at)comcast.net writes:
| Quote: | --> Kitfox-List message posted by: "Bob" <dswaim1119(at)comcast.net>
Bob
I use it all the time.... for touch up....takes a long time to dry..............
Dave
AOL now offers f="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com.
n85ae
Posted: Wed Mar 28, 2007 10:21 am Post subject: Re: Rustoleum? |
Rustoleum will dissolve so fast it will make your head spin with anything
with MEK in it. Otherwise, it is a great paint for Steel.
The answer is that it won't work well with the Polyfiber system
Jeff
Posted: Wed Mar 28, 2007 12:18 pm Post subject: Rustoleum? |
In a message dated 3/28/2007 1:23:53 P.M. Central Daylight Time, n85ae(at)yahoo.com writes:
| Quote: | The answer is that it won't work well with the Polyfiber system
Jeff
My KITFOX 2 was done in the poly system, all diana cream with a green, Piper Cub style lightening bolt on the side.
The green trim is rustoleum, applied a little over 3 years ago and has been fine. Looks great, very easy to apply. I keep the cans warm, not hot, as I spray buy keeping them in warm water. this ensures good pressure. Flows great, excellent coverage. I used a mist coat, then in about 15 min the colour coat.
I am certain its not the right combination and there are better, but it was very easy, looks great and worked for me
Dave
I have photos to share of it....
See what's free at AOL.com.
n85ae
Posted: Thu Mar 29, 2007 5:50 am Post subject: Re: Rustoleum? |
You can paint over polyfiber stuff with Rustoleum, however, I'll buy the
beer if you let me to come over to watch you try polyfiber'ing over
Rustoleum.
IF you used Rustoleum on your parts, and then tried to attach fabric with
polytack you would find out fast that it is not very compatible.
I use Rustoleum a lot for stuff I weld, etc. It is great paint, and quite
durable for spraycan paint. The way I remove it from stuff for welding,
etc. Is with MEK.
Jeff
Posted: Thu Mar 29, 2007 5:54 am Post subject: Rustoleum? |
In a message dated 3/29/2007 8:51:56 A.M. Central Daylight Time, n85ae(at)yahoo.com writes:
| Quote: | You can paint over polyfiber stuff with Rustoleum, however, I'll buy the
Rustoleum.
etc. Is with MEK.
Jeff |
hmmm never tried it UNDER poly good to know! just tried it over..
Dave
if you come over will you help LOL
