Flap Motor Switch
alaskajim(at)cox.net
PostPosted: Fri Mar 23, 2007 7:52 pm    Post subject: Flap Motor Switch Reply with quote
I'm in the process of wiring my flap motor for my 701. I have a 12V
Warner Linear Actuator with only 2 wires. The actuator will reverse
it's direction when I switch the 2 leads on my battery +/- terminals.
My question; is there a "rocker" type switch that will work for this
installation and how is it wired? Thanks in advance for any help. Jim
NYTerminat(at)aol.com
PostPosted: Fri Mar 23, 2007 8:24 pm    Post subject: Flap Motor Switch Reply with quote
Jim,
You can use a double pole double throw switch. Make sure it is appropriately rated for your flap motor or you can do it with two relays and a single pole double throw switch. Check out AeroElectric's website.
Bob Spudis
AOL now offersle="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com.
craig(at)craigandjean.com
PostPosted: Fri Mar 23, 2007 9:32 pm    Post subject: Flap Motor Switch Reply with quote
If you really want a rocker switch (as opposed to a toggle) then use the Ray
Allen RS2-5 (not the plain RS2). The RS2-5 is rated for 5 amps while the RS2
is only rated for 1 amp. It costs you $26 but they will throw in the label
for free.
Switch: www.rayallencompany.com/products/switches.html
Labels: half way down on www.rayallencompany.com/products/indsens.html
For a mere $15 you can get a quality DPDT toggle switch here (look for
S700-2-7):
www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?11X358218#s700-2-7
The S700-2-7 is a two pole switch that normally sits with the lever in the
middle and momentarily pushed up or down.
See figure 11-15 of the article below for how to wire any "double pole,
double throw" (DPDT) switch to reverse polarity:
www.aeroelectric.com/articles/switches.pdf
I assume your linear actuator has internal limit switches.
-- Craig
p.mulwitz(at)worldnet.att
PostPosted: Sat Mar 24, 2007 1:54 am    Post subject: Flap Motor Switch Reply with quote
Hi James,
You want a DPDT Momentary switch for this purpose. The 601 drawings
I received from ZAC include a wiring diagram for this function. I
also did one for my own installation that includes a 15 amp circuit
breaker (the size recommended by ZAC), the flap switch, wiring for
both limit switches, and the flap motor. I have no idea how much
current your particular flap motor can draw, but with no other
information I would use the same size circuit breaker and switch as
the 601 drawing calls for.
I used a toggle switch for mine. If you want a rocker style switch
instead of a toggle you can probably find one from one of the big
online electronic component houses like Digikey or Mouser. If you
are not used to this kind of supplier it can be a bit
overwhelming. I would be glad to look one up for you if you give me
your final specifications including current requirement and color and
size preference. The most important specs are the current and
DPDT-Momentary. Just send me an email directly if you would like
some further help.
I don't think you can read my drawing file for the flap wiring
diagram. I used Autosketch to draw it. If you want to see it I can
take a picture and send you a JPG file.
Good luck,
Paul
this installation and how is it wired? Thanks in advance for any help. Jim
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
planecrazydld(at)yahoo.co
PostPosted: Sat Mar 24, 2007 8:21 am    Post subject: Flap Motor Switch Reply with quote
Don't get soaked. Take a[url= http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news] quick peek at the forecast [/url]
with the[url= http://tools.search.yahoo.com/shortcuts/?fr=oni_on_mail&#news]Yahoo! Search weather shortcut.[/url] [quote][b]
paulrod36(at)msn.com
PostPosted: Sat Mar 24, 2007 10:13 am    Post subject: Flap Motor Switch Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> In addition to these below, you might also consider automotive window or seat switches, which come dirt cheap from a junkyard, and are DC rated, with pretty good amperage capabilities. Some of them look pretty good, too.
Paul Rodriguez
601XL/Corvair
rge177(at)yahoo.com
PostPosted: Tue Mar 27, 2007 4:26 pm    Post subject: Flap Motor Switch Reply with quote
I've ordered a 10 amp breaker for my flap circuit,
which is what ZAC calls out on 6-S-2 of the 03/04
version of drawings for the 601XL. I couldn't find a
current draw rating on my flap motor, so I'm not sure
what is required. Does anyone know if there's been a
change in the requirment for the flap motor amperage?
Ron Ellis
Haslet, TX
601XL Jab 3300 Enigma
Time: 02:54:35 AM PST US
Subject:
Hi James,
The 601 drawings
function. I
15 amp circuit
switch, wiring for
Don't get soaked. Take a quick peek at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
PostPosted: Tue Mar 27, 2007 4:40 pm    Post subject: Flap Motor Switch Reply with quote
I measured the steady-state draw of the factory actuator at 3-4 amps with no
mechanical load. I assume there is an initial surge that my meter doesn't
see and that the draw will be higher when actually moving the flaps in
flight.
-- Craig
davgray(at)sbcglobal.net
PostPosted: Wed Mar 28, 2007 2:59 am    Post subject: Flap Motor Switch Reply with quote
I can add that a 7.5 amp fuse is not sufficient under flight loads. I use a
15 a and it is fine.
Gary Ray
rge177(at)yahoo.com
PostPosted: Wed Mar 28, 2007 7:44 am    Post subject: Flap Motor Switch Reply with quote
Thanks for the info Craig, and Gary, I also have the
15a circuit shown on 6-B-20 (didn't see that before),
so I'll just reorder a 15a breaker so I won't worry.
Ron
with no
that my meter
doesn't
moving the flaps in
flight.
-- Craig
Expecting? Get great news right away with email Auto-Check.
Try the Yahoo! Mail Beta.
txpilot
PostPosted: Wed Mar 28, 2007 8:15 am    Post subject: Re: Flap Motor Switch Reply with quote
Two follow-up questions for some of the responders:
Why DPDT and not SPDT? Maybe there's a difference with the 601 and 701 (I'm a 701 builder), but it seems with only one linear actuator you don't need a double pole. Am I missing something?
Second, does anyone know who sells toggle switches that actually look like a flap handle, as opposed to the generic looking toggle switch?
Regarding your original question Jim, I've purchased Bob Nuckoll's Aeroelectic Connection. He gives an excellent wiring diagram for an electric flap system. In the diagram, he recommends a 15 amp breaker for the flap motor and 5 amp breaker for the flap control (relays and limit switches).
Dan Ginty
PostPosted: Wed Mar 28, 2007 8:47 am    Post subject: Flap Motor Switch Reply with quote
In a message dated 3/28/2007 12:17:09 P.M. Eastern Daylight Time, djg7(at)houston.rr.com writes:
If you are not using relays, you need the DPDT switch to reverse the polarity
Bob
AOL.com.
Afterfxllc(at)aol.com
PostPosted: Wed Mar 28, 2007 8:50 am    Post subject: Flap Motor Switch Reply with quote
The reason for the DPDT is to reverse the polarity one side middle is B+ and the other middle connection is - and you couldn't have that with a SPDT switch.
AOL not AOL.com.
PostPosted: Wed Mar 28, 2007 9:01 am    Post subject: Flap Motor Switch Reply with quote
Hi Dan,
The DPDT switch is needed because both the leads on the motor must be
switched between power and ground. With a single pole switch one of
the motor leads must be permanently connected to one of the power
leads, and this would not allow for reversal of the motor direction.
I found a switch at Radio Shack that has a flattened toggle. It is
not as similar to flaps as the Cessna switch, but it is a small step
in the right direction.
Paul
XL fuselage
Paul Mulwitz
32013 NE Dial Road
Camas, WA 98607
Flydog1966(at)aol.com
PostPosted: Wed Mar 28, 2007 9:28 am    Post subject: Flap Motor Switch Reply with quote
In a message dated 3/28/2007 12:02:24 P.M. Eastern Standard Time, p.mulwitz(at)worldnet.att.net writes:
And I have found that the quality/reliability of Radio Shack switches is horrible. But this was some years ago,maybe its been resolved by now.
AOL at AOL.com.
