RV8-List Vent Route
JAPhillipsGA(at)aol.com
PostPosted: Wed Mar 28, 2007 4:50 pm    Post subject: RV8-List Vent Route Reply with quote
RV-8 Builder Friends, which wing rib lightening hole should I route the rear pax air vent hose through ? The drawings don't specify which hole and my hose will go through even the smallest rib hole. I can't tell from the fuselage drawing if it makes a difference, but so far everything makes a difference if it's wrong. Hope to hear from someone, Best regards, Bill of Georgia
See what's free at http://www.aol.com. [quote][b]
vhimsl(at)adelphia.net
PostPosted: Wed Mar 28, 2007 6:15 pm    Post subject: RV8-List Vent Route Reply with quote
I am assuming you haven’t built the fuselage yet.
The vent hole is (at) 1 foot forward of the aft wing spar. You will be routing the vent line through the second smallest hole…But!
You will probably mount the fuselage (pilot) vent first so I suggest you set the vent tube aside until then as you don’t know exactly the length you will need.
Fact is, you will probably be well in to the finish kit before you return to this. I have the engine installed, canopy done, etc. but my wings are still hanging in the garage with the vent tube sticking out of the access ports looking very dusty.
You will also want to install window screen material over the plastic (excuse me…space age top quality composite) vents to keep out the critters.
Vince H. of Idaho
RV8 – VSB (very slow built) Finish
From: owner-rv8-list-server(at)matronics.com [mailto:owner-rv8-list-server(at)matronics.com] On Behalf Of JAPhillipsGA(at)aol.com
Sent: Wednesday, March 28, 2007 5:49 PM
To: rv8-list(at)matronics.com
Subject: Re: RV8-List Vent Route
[quote]RV-8 Builder Friends, which wing rib lightening hole should I route the rear pax air vent hose through ? The drawings don't specify which hole and my hose will go through even the smallest rib hole. I can't tell from the fuselage drawing if it makes a difference, but so far everything makes a difference if it's wrong. Hope to hear from someone, Best regards, Bill of Georgia
