gmvouga(at)hotmail.com Guest
Posted: Thu Apr 05, 2007 4:49 am Post subject: Electrical Design Confusion |
All,
I'm having some heartburn trying to figure out the best electrical system to
use. I am planning on the following type of system:
- All electric IFR setup ( Dual GRT, Garmin radio/GPS stack, Autopilot, AOA)
- Superior XP-360 w 1 lightspeed electronic ignition and 1 slick mag
- Thinking about the SD-8 alternator
- Single battery
I was looking at the Z-13/20 diagram and planning to substiture the 20A
alternator for the SD-8. Will this work? I also looked at the Z-13/8, but
it seems that it is missing some of the benefits and simplicity of the LR-3
controllers.
Any help on this would be appreciated.
Greg
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/?icid=hmtag3
nuckollsr(at)cox.net Guest
Posted: Thu Apr 05, 2007 5:09 am Post subject: Electrical Design Confusion |
At 05:47 AM 4/5/2007 -0700, you wrote:
All,
to use. I am planning on the following type of system:
- Single battery
but it seems that it is missing some of the benefits and simplicity of the
LR-3 controllers.
The vast majority of OBAM aircraft flying would be
just fine using Z-11 taking advantage of the reliability
of modern alternators and RG batteries combined with
the e-bus alternate feed philosophy. IF you don't plan
to have a vacuum system, then plugging the open hole
on the back of the engine with an SD-8 is a good thing to
do and you step up to Z-13/8.
In Z-13/20, the aux alternator IS an SD-20 . . . but
what makes you think you'll NEED this kind of auxiliary
energy? Also, be aware that the depiction of any particular
brand of main alternator and its associated controller
is NOT carved in stone. The Z-figures are to illustrate
architectures and should not be interpreted to recommend
specific hardware, breaker-fuse sizes, wire sizes or what
gizmo runs from which bus. These are things you need to
decide based on the specifics of your hardware selections
and operating philosophy.
From what you've described I'm betting that Z-13/8
is going to meet all your needs with a minimum of weight
and cost.
Posted: Thu Apr 05, 2007 8:29 am Post subject: Electrical Design Confusion |
Thanks for the information. This is helping... However, i have a couple
more questions.
1. The LR-3 alternator controller looks like a nice option and simplifies
things (crowbar, indicator light, regulator all-in-one) for the main
alternator. Is there any reason, other than cost, not to use this?
2. For the SD-8 it would be nice to have a indicator light or gage to make
sure it's functioning properly. I could wire this into the circuit as well,
but I still need regulator and crowbar OV. So... Is there any reason not
to use the LR-3 other than cost. In Z-13/8 it simply states "voltage
Regulator." Is there a specific model that you recommend?
As you might already be able to figure out, I'm a little electron
challenged. So forgive me if any of these questions seem a somewhat basic.
I have actually read the AeroElectric Connection, but I'm still a little
confused. I'm really just looking for a safe, simple, wiring archetecture
that will fit my equipment (Avionics and engine) choices. Saving a few
pennies would be nice, but at this point i would pay a few more bucks to
make it simple. The This is really the reason that I was thinking of just
trading the SD-8 for the 20 amp alternator in Z-13/20. I don't think I need
the 20A alternator, and the SD-8 will add the safety that I am looking for
in my all electric system. Is there any reason not to do this?
Thanks in advance,
Greg
| Quote: | From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Reply-To: aeroelectric-list(at)matronics.com
Subject: Re: Electrical Design Confusion
Date: Thu, 05 Apr 2007 09:08:50 -0500
><gmvouga(at)hotmail.com>
>All,
>AOA)
>- Single battery
>LR-3 controllers.
and cost.
Download Messenger. Join the i’m Initiative. Help make a difference today.
http://im.live.com/messenger/im/home/?source=TAGHM_APR07
Posted: Thu Apr 05, 2007 4:21 pm Post subject: Electrical Design Confusion |
At 09:24 AM 4/5/2007 -0700, you wrote:
more questions.
The voltage regulator for an SD-8 is unique to that product and comes
with it. You can't use an LR-3 with the SD-8.
| Quote: | 2. For the SD-8 it would be nice to have a indicator light or gage to
make sure it's functioning properly. I could wire this into the circuit
as well, but I still need regulator and crowbar OV. So... Is there any
reason not to use the LR-3 other than cost. In Z-13/8 it simply states
"voltage Regulator." Is there a specific model that you recommend?
The functionality indicator for ALL alternators is active
notification of low volage . . . i.e. flash a light
if the bus voltage is less than 13.0 volts. OV protection
for the SD-8 is illustrated in Z-13/8
| Quote: | As you might already be able to figure out, I'm a little electron
need the 20A alternator, and the SD-8 will add the safety that I am
looking for in my all electric system. Is there any reason not to do this?
Yes. Too heavy, too expensive and overkill for what you need.
Z-13/8 as published is all you're going to ever need and
more.
Posted: Fri Apr 06, 2007 6:09 am Post subject: Electrical Design Confusion |
Thanks for your input. Looks like Z-13/8 is the direction that I'll be
going.
Greg
Date: Thu, 05 Apr 2007 20:20:38 -0500
>Bob,
>more questions.
>basic.
>this?
more.
Interest Rates Fall Again! $430,000 Mortgage for $1,399/mo - Calculate new
payment
