Posted: Sat Mar 31, 2007 2:09 pm Post subject: ELT and RJ11 cable. |
Is RJ 11 cable simply 4 wire telephone cord. Is it the stuff you can buy at
Radio shack?
I need some right now and I rather not run down the hill for a one hour
outing. I might just cut some off the thirty foot extension I already have
that is being used to hook this computer up to the phone line. I'll replace
the cable tonight before my wife even knows its gone. HONEY, What's wrong
with the internet connection.
What, is it slower than usual??
JOhn G.
LarryRosen
Posted: Sat Mar 31, 2007 3:40 pm Post subject: ELT and RJ11 cable. |
Same stuff.
Don't even cut it leave the manufacture connectors so you don't have to
replace them.
Larry
John Gonzalez wrote:
buy at Radio shack?
hour outing. I might just cut some off the thirty foot extension I
already have that is being used to hook this computer up to the phone
line. I'll replace the cable tonight before my wife even knows its
gone. HONEY, What's wrong with the internet connection.
JOhn G.
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tim Olson
Posted: Sat Mar 31, 2007 3:46 pm Post subject: ELT and RJ11 cable. |
Same cable John, but it's not pinned the same from what I understand.
I don't know the pinouts, but I think the cable is either rolled
or has a couple of crossed wires or something like that. I think
I'd wait for the real deal if you can.
at Radio shack?
have that is being used to hook this computer up to the phone line. I'll
replace the cable tonight before my wife even knows its gone. HONEY,
JOhn G.
kdbelue(at)charter.net Guest
Posted: Sat Mar 31, 2007 3:54 pm Post subject: ELT and RJ11 cable. |
John,
In my experience, the wire is telephone wire, but the pinout is different. I
have an Ameri-king AK-450 and a telephone cord would not work as-is. I had
to cut off one connector and wire it differently - sorry, don't remember the
pinout (6 years ago).
rvbuilder(at)sausen.net Guest
Posted: Sat Mar 31, 2007 3:56 pm Post subject: ELT and RJ11 cable. |
Yes
Posted: Sat Mar 31, 2007 4:27 pm Post subject: ELT and RJ11 cable. |
I think you should be fine. Verify that the wires are the same or opposite
on both ends, then go ahead. I think, since it is flat cable, that the
wires are in the same order, so the question is the orientation of the ends.
You can see the colors, so that's fine. If you are going to run the wire
and don't want the whole length, just cut one end off (keep it so you can
verify the wire order later) and run the wire, then you can get another end
and borrow a crimper to put the new end on when you are ready for it.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
LarryRosen
Posted: Sat Mar 31, 2007 4:42 pm Post subject: ELT and RJ11 cable. |
I gave you bad information.
From the Ameri-King AK-450 installation manual
Note: The interconnecting wiring is a straight wiring configuration,
I.e. Pin 1 to 1, Pin 2 to 2, Pin 3 to 3, Pin 4 to 4.
The wiring configuration is not a telephone application. (Telephone
application is a cross wire configuration, i.e. Pin 1 to 4, Pin 2 to 3,
Pin 4 to 1) To convert from cross wire to straight wire configuration,
just simply reverse either plug upside down.
Larry
Larry Rosen wrote:
Same stuff.
to replace them.
Larry
> <indigoonlatigo(at)msn.com>
> buy at Radio shack?
> JOhn G.
#40356
N205EN (reserved)
<http> |
Posted: Sat Mar 31, 2007 5:18 pm Post subject: ELT and RJ11 cable. |
Thank you all for the information.
| Quote: | From what I learned, Telephone application is 1-1,2-2,3-3,4-4. Networking
apllication is as you say Larry, 1-4, all others the same.
I need to cut one end off anyway. I forgot to run this wire and it is the
last one to go in, I have no more room inside the conduits. I got both the
solenoid wires in as I had forgotten them also. Remember dual Batts.
Thanks all for the speedy replies.
JOhn G. Do NOt Archive
| Quote: | From: Larry Rosen <LarryRosen(at)comcast.net>
Subject: Re: ELT and RJ11 cable.
Date: Sat, 31 Mar 2007 20:38:35 -0400
Note: The interconnecting wiring is a straight wiring configuration, I.e.
application is a cross wire configuration, i.e. Pin 1 to 4, Pin 2 to 3, Pin
4 to 1) To convert from cross wire to straight wire configuration, just
Larry
Larry Rosen wrote:
>Same stuff.
>replace them.
>Larry
>>at Radio shack?
>>JOhn G.
