knowvne(at)aol.com Guest
Posted: Sat Mar 31, 2007 5:57 am Post subject: TAB adjustments UL |
Steve
Your one of the Lucky ones....
Your able to fix your problem by simply stepping on the other peddle..
Here's a serious Question.... Will the degree of TAB deflection Change
when going
from one blade length to another or to a different pItch setting? No
experince doing
either so I was curious...
Mark
Blame Rotax
They build the 912 so it spun the prop in the wrong Direction....
Mark
Hi Mark,
The 447 spins in the opposite direction, and guess what, the trim tab
goes on the other side.
Bryan Melborn of Custom Air mounts the same tab on every plane and
gets consistent results.
Steve B
See what's free at AOL.com.
________________________________________________________________________
from AOL at AOL.com.
=0
