dimples in door halves don't line up?
CJohnston(at)popsound.com
PostPosted: Sat Mar 31, 2007 8:57 am    Post subject: dimples in door halves don't line up? Reply with quote
hey all -
forgive me if i sound like a bummer all the time, but remember when i posted that i couldn't see all of the dimples molded into the door halves? well, the ones i could see i drilled holes in like you're supposed to, and i figured that all would become apparent when i got them together. well, now the holes that i do have drilled don't line up with eachother when i try to cleco the door halves together. i get 3 clecos in, and the other 2 holes that i do have drilled in the doors don't line up. about 1/8" off in the worst case. so, the question is, do i get it together so that it looks like i think it should and move on? am i setting myself up for a disaster later? i'd love some feedback on this. i'm not sure if i'm just being a baby, (waaa, my parts don't fall together perfectly) or whether this is an issue that will bite me later.
thanks
cj
#40410
finishing
www.perfectlygoodairplane.net
flysrv10(at)gmail.com
PostPosted: Sat Mar 31, 2007 5:13 pm    Post subject: dimples in door halves don't line up? Reply with quote
I am going to take a shot at this considering that I am not there
admiring your problem. I think that if your door halves mate nice
and snug against each other, the doors are not twisted when they sit
on the fuselage and you have the same clearance around the door
(looking from the inside), you are good to go.
Rob,
Flyimg - 130 hrs TT
On Mar 31, 2007, at 12:57 PM, Chris Johnston wrote:
hey all -
thanks
cj
#40410
finishing
<winmail.dat>
Tim Olson
PostPosted: Sat Mar 31, 2007 7:14 pm    Post subject: dimples in door halves don't line up? Reply with quote
I'd agree with Rob, cj....if you match the halves up good, and the gap
around the inside looks nice, there's not a whole lot to worry about.
The outside gets trimmed to fit, so you just need to ensure the
inside looks respectable. Also, you can verify that the window
opening area looks reasonably nice together. Other than this as
guidance, it's hard to know what else to give without being right
there to see it first hand.
admiring your problem. I think that if your door halves mate nice and
snug against each other, the doors are not twisted when they sit on the
fuselage and you have the same clearance around the door (looking from
Rob,
Flyimg - 130 hrs TT
