RV10-List:Zolatone
LarryRosen
PostPosted: Sat Mar 31, 2007 10:23 am    Post subject: RV10-List:Zolatone Reply with quote
James,
Thanks for sharing this tip with us on the 10 list.
Larry Rosen
RV-10 #356
JAMES MCCHESNEY wrote:
Hey guys-
Just stumbled across this Zolatone thread on the RV Builders Hotline. I'm
building a -7A and plan to finish the interior with Zolatone. After reading
the Zolatone website I just about choked at the cost of the spry guns they
recommend. My local auto paint supplier sugested a "Shutz Gun" which is used
to apply automotive undercoatings. I wasn't convinced that this was a good
idea so I emailed Zolatone and got a very helpful reply regarding an
economical Harbor Freight based alternative. The trick is getting a gun with
as large enough spry tip for the texture particles. Here is the text of that
email. Hope this helps someone.
Jim,
Big time bad. Don't even try it because you can't do the necessary "sheer
coat" then "pattern coat" to properly to install our product as outlined on
our web site and master catalog.
Recently one outfit that does Airstream refurbish work in CO bought this
setup from Harbor Freight and he said it worked well. It is definitely lower
cost than DeVilbiss, Sata and Sharpe which have setups that sell for $500 -
$800.
Harbor Freight Pressure Pot Spray Gun Setup
According to an Airstream refurbisher in CO, this worked very well.
www.harborfreight.com
# 93305 Pressure Pot w/ Bad Gun $49.99
(Buy this and don't use the gun that comes with it)
# 43760 Good Gun w/ .082" Tip $19.99
(1 Qt siphon gun, detach from cup and use w/ pressure pot setup)
Hope this helps.
Sincerely,
Robert Hensley, Vice-President
Zolatone Automotive, Industrial & Marine
Div. Surface Protection Ind. Intl.
3411 E. 15th Street
Los Angeles, CA 90023
Larry Rosen
#40356
N205EN (reserved)
<http>
Vern(at)teclabsinc.com
PostPosted: Mon Apr 02, 2007 7:21 am    Post subject: RV10-List:Zolatone Reply with quote
Thank you all for the input on Zolatone. I also about choked at the
price of the spray equipment and gave up on the idea until John brought
it up.
As a side note the pressure setup James mentioned below (#93305) is on
sale for $39.99 through the Harbor Freight website.
If dimples on the outside of a golf ball makes it fly better, then do
bumps on the interior of a plane make it fly better? Smile
Thanks again,
Vern Smith (#324 fuselage)
