sarg314(at)comcast.net Guest
Posted: Tue Apr 03, 2007 2:14 pm Post subject: magneto wiring |
I just hooked up my magneto grounding wire (a shielded #1 . Checking
with a continuity meter, there is continuity betwen the mag ground
terminal and the P-lead regardless of whether the switch is open or
closed or even disconnected, for that matter. I'm concluding from this
that the 2 terminals on the mag are connected internally through some
coil, so the continuity test doesn't show what I was expecting.
Is this correct?
Tom S.
RV-6A, wiring.
mprather(at)spro.net Guest
Posted: Tue Apr 03, 2007 3:08 pm Post subject: magneto wiring |
Yep.
A buzzbox detects the difference in inductance between shorted to ground
via the points when the points are closed (L=0), and shorted to ground via
the primary winding in the coil when the points are open.
Matt-
Is this correct?
Tom S.
RV-6A, wiring.
nuckollsr(at)cox.net Guest
Posted: Tue Apr 03, 2007 3:17 pm Post subject: magneto wiring |
At 03:12 PM 4/3/2007 -0700, you wrote:
terminal and the P-lead regardless of whether the switch is open or closed
or even disconnected, for that matter. I'm concluding from this that the
2 terminals on the mag are connected internally through some coil, so the
Is this correct?
The p-lead is connected across the PRIMARY winding
of the magneto coil which has a very low resistance.
Further, the timing points inside the magneto are
connected in parallel with the magneto switch
so even if the primary winding had some significant
resistance, your ohmmeter check would still read VERY
low if the points were closed.
This is why an ohmmeter cannot be used as a practical
tool for timing a magneto . . . it's exceedingly
difficult to deduce when the points open based purely
upon the DC resistance one observes from the outside
looking in. This is why you use a "buzz box". The
buzzer in a buzz-box generates a sort of AC signal
that IS NOT highly loaded by the AC impedance of the
magneto coil primary but IS severely loaded by closed
points.
Modern solid-state replacements for the century old
buzz box use electronics to generate an
AC signal needed to bias the magneto primary so
that transitions of conductivity across the points
may be readily detected during a timing operation.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
