				 Posted: Wed Apr 04, 2007 2:48 pm    Post subject: mkIII Center Section and BRS Installation |
				Hi Gang:
 Here are some photos of what I did today to finish up most of the
 center section for my mkIII.  Click on the file, but start at the
 bottom and go up instead of top and down.  For some reason the FTP
 loaded them that way when I uploaded to the index page.
 http://home.elmore.rr.com/jhauck/hauck%20mkIII/
 The black material is frangible haircell plastic that covers the exit
 through the sheet metal for the parachute.  The rocket has been
 lowered 5" to fit inside the center section.
 Normally, the center section is built of sheet metal, lexan, and 3
 nose ribs.  To make the center section accept the parachute, I built 4
 nose ribs with enough space for the pack tray inbetween the middle
 ribs.
 Hardware and rocket will be installed once the center section is on
 the wings.  It is a job to do, but it makes a nice clean, weather
 proof installation.
 Two of the inspection holes will have inspection plates installed to
 help cut down some of the noise inside the cockpit.
 The deployment handle is right over my forehead.  I can get to it with
 left, right, or both hands.  It is pretty easy to find my forehead, in
 normal circumstances, so maybe it will be as assist to find that
 handle should I need it.
 If you have any questions about the photos, please ask.  I do not have
 time to write about each photo.  Behind the power curve trying to get
 the mkIII ready to fly to Lakeland.
 Still got an engine to mount and lexan to install.
 Take care,
  _________________ John Hauck
Titus, Alabama |
		JetPilot
				 Posted: Wed Apr 04, 2007 3:29 pm    Post subject: Re: mkIII Center Section and BRS Installation |
				The new center section looks really good John.   Keep up the pace, I look foward to seeing you and your plane at Sun And Fun.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
				 Posted: Wed Apr 04, 2007 3:41 pm    Post subject: mkIII Center Section and BRS Installation |
 | Mike
 Thanks Mike:
 Now all I need is an engine and lexan, then a little test flying to
 see if I can still fly.  Have not been airborne since the Kolb
 Homecoming, end of Sep 2006.  Looking forward to getting back in the
 air and making the flight to Lakeland and out to MV, SE Oregon, and
 points West.
 DO NOT ARCHIVE
Titus, Alabama |
		cspoke
				 Posted: Wed Apr 04, 2007 6:56 pm    Post subject: Re: mkIII Center Section and BRS Installation |
				John,
 Your center section looks great. I'm looking forward to seeing it in person at Sun n fun
  _________________ Craig Spoke
Mark111 Xtra
VW Redrive
Lillian, AL
cspoke@mediacombb.net |
