12V batteries in series
rtitsworth
PostPosted: Tue Apr 03, 2007 7:10 pm    Post subject: 12V batteries in series Reply with quote
Bob, etal
I'm wiring two 12v batteries in series (to make a 24 volt battery). The
batteries I'm using (Panasonic) have threaded posts as terminals. The
(+)and (-) terminals are symmetric, so placing the batteries back-to-back,
places the intermediate terminals close to each other (~1.5" apart). The
batteries will be physically clamped together in the mount and are in the
tail (relatively low vibration).
Question: How to best "wire" the intermediate (+) and (-) terminals
together?
1. I can make short leads from welding cable (like the other main battery
connections). But, this uses much more material than necessary and creates
a space/routing problem in the battery mount/box.
2. I can make a short connection strap from some bar stock (assume approx 1"
x 2.5" x 1/8" or 3/16" thick) with two holes to mate with the threaded
terminal posts. What to make the strap from???
Copper - good conductivity but eventually corrodes
Aluminum - lighter, but corrosion (al oxide) in not very conductive
Steel - ??? Most vibration resistant?
What about plating any of the above? i.e. Copper with Tin or Nickel
plating. (I have access to a professional plating shop).
Rick Titsworth
Lancair ES - building.
BobsV35B(at)aol.com
PostPosted: Tue Apr 03, 2007 7:23 pm    Post subject: 12V batteries in series Reply with quote
Good Evening Rick,
Way out of my area, but what would you think about using a soft copper strap with a U shaped excursion to absorb any vibration or temperature caused movement?
I would use a strap about 3/4 of an inch wide, one sixteenth of an inch thick and with the U shape about an inch high (or low!). I would make it by making a ninety degree bend, go up (or down) about three quarters of an inch to one inch, make a one eighty back to where the U started, another ninety and off to the other battery.
Nickel plating sounds like a great idea.
Your thoughts?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 4/3/2007 10:11:49 P.M. Central Daylight Time, rtitsworth(at)mindspring.com writes:
Bob, etal
together?
Rick Titsworth
See what's free at AOL.com.
nuckollsr(at)cox.net
PostPosted: Wed Apr 04, 2007 6:25 am    Post subject: 12V batteries in series Reply with quote
At 11:09 PM 4/3/2007 -0400, you wrote:
<rtitsworth(at)mindspring.com>
Bob, etal
But not zero vibration. Battery terminals are designed
with limited structural integrity to mount conductors . .
the lighter and more flexible the better. With lead posted
batteries, there's real risk of stress cracks taking the
post of entirely. Batteries with molded in threads are
at risk for loosing the hermetic seal around the posts.
together?
A 3" piece of 4AWG with a couple of soldered or crimped terminals
represents a space problem?
Be wary of connections having considerable stiffness at
right angles to the terminal. 0.064 sheet brass from a hobby
shop is thick enough. These displays from K-S Engineering
are found in many hobby, craft and hardware stores. They
have small pieces of sheet brass.
http://tinyurl.com/286hsn
http://tinyurl.com/2638yx
Their p/n 248 is an .064 x 1 brass strip that is highly
suited to jumpers between robust studs like the pictures
shown here:
http://www.aeroelectric.com/Pictures/Wiring_Technique/Contactor_Interconnect
But to avoid having the sheet stiffness bear against the
battery terminal, you'd want to make an "omega shaped"
jumper that stands up 1/2 to 1" above the surface so that
motion between the two terminals does not induce stress
due to the relative stiffness of the jumper.
It's not the jumper that's at risk . . . but the
battery terminals. Conductivity for so short a connection
is not a serious issue but ability of the material to
"give" under pressure of the threaded fasteners is what
works toward a gas-tight joint. When the joint is good,
the plating becomes a minor concern for longevity. If
you used a 4AWG jumper and tin plated copper terminals,
you will have selected a combination of materials designed
and proven to meet design goals for connective integrity.
If these are RG batteries, why a battery box? Adding an
enclosure around an RG battery has offers no mechanical
or operational advantages over simply strapping open
batteries into a tray that captures the footprint.
Sound's like a good way to spend a lot of $time$ to
work around a $2 jumper that you can build up in about
ten minutes with a small torch and some house wire for
"wedges" . . . see:
http://aeroelectric.com/articles/big_term.pdf
A 3-4" piece of welding cable would be fine for
the conductor. I need to update this article. Bernzomatic
has a really nice ST-100T, $10 butane torch
offered at places like Home Depot. I demonstrate
these and give them away at my weekend seminars. VERY
nicely built and the price is right. See:
http://tinyurl.com/37qyxf
http://tinyurl.com/3a933o
rtitsworth
PostPosted: Wed Apr 04, 2007 9:31 am    Post subject: 12V batteries in series Reply with quote
BobN,
Thanks for the reply. Some follow-up comments/questions...
I'm not against #4AWG and crimped/soldered ends, but when placed face-to-face, the battery terminals are only 1.5" apart. The top terminals are in a recessed area (below the top battery surface) and thus really only accessible from the sides (see attached photos.)
The short side of the batteries are nearly flush with a bulkhead (~.25” gap), so the terminals are then really only accessible from the long side.
If I tried to make a #4 AWG wire to connect the face-to-face pair, them the crimped/soldered ends would been less than 1/4” apart (essential the ends would just be soldered together, stiff).
I could make a vertical "omega" strap, but if the paired batteries are secured together, I'm not sure I see how the two posts vibrate relative to each other? Rather, I was thinking that the terminals are only exposed to the load(s) due to attempting to accelerate (vibrate) anything connected to them. The direct connecting strap would be relatively light and so little load would be imposed to the terminals. Furthermore, I’m thinking that connecting something solid to both terminals cuts the force imparted to each in half. ???
The K&S suggestion is helpful. I was thinking that I needed something thicker (i.e. 1/8")
As an alternative, I could arrange the batteries back-to-back, but then the connecting wire would need to run around the outside perimeter (> 18”). Perhaps that is best???
Additional thoughts/comments???
Rick
 Filesize:  30.98 KB
 Viewed:  149 Time(s)
 Filesize:  27.11 KB
 Viewed:  155 Time(s)
PostPosted: Wed Apr 04, 2007 3:10 pm    Post subject: 12V batteries in series Reply with quote
little load would be imposed to the terminals. Furthermore, I m thinking
When you have two chunks of lead like these
you only 'think' you have them strapped together.
It's not the weight of the strap but the weights
of the two batteries and the inability to make them
absolutely immobile to each other for all modes of
vibration.
thicker (i.e. 1/8")
No, nothing nearly that thick. All I can do is
give you best practices based on having torn a lot
of stuff up in qualification testing that I thought
was pretty robust. Give it a try. What you've proposed
will probably be okay.
