Battery Cable Length
LarryRosen
PostPosted: Sun Apr 08, 2007 6:32 am    Post subject: Battery Cable Length Reply with quote
I just pulled my fat wire.
It runs on the left side of the fuselage:
* through the outermost lighting hole at the empennage / fuselage
connection,
* through a hole inboard of the outboard most lightning hole between
the seats and the baggage compartment (this puts the wire between
the 1st and second seat rib)
* then through a hole in the outermost seat rib,
* through the bottom hole (rear seat and floor board),
* through two new holes towards the bottom of the vertical wing spar
channel
* then a straight shot through the firewall (the hole in the
firewall is in the location Vans specifies).
The wire length from the fuselage / empennage connection to the firewall
is 10 feet +/- 1 inch. Then add another foot from the firewall to the
starter contactor and 3-4 feet to the master contactor would give +/- 15
feet.
I would recommend running a weed wacker string through your wire routing
prior to ordering the battery wire, or order extra length.
Larry Rosen
#356
<http://lrosen.nerv10.com
How about a couple of measurements on the lengths of all #2 wires?
That would be very helpful.
Larry Rosen
#40356
N205EN (reserved)
<http>
