CrownLJ(at)verizon.net Guest
Posted: Mon Apr 09, 2007 8:49 am Post subject: 582 coolant weep |
Why/how would coolant be leaking from the gasket under the water pump housing? The bolts are tightened equally, and the antifreeze has been changed 2/yr. (I use a winter thermostat and change the antifreeze each spring and fall. The old stuff goes to the cars) Only distilled water has been mixed with it, so I wouldn't expect corrosion. Total hrs. 170 ish. Can the housing become warped? How? Can I double gasket it? Or would it be best to lightly plane down the cover with emery paper and just change the gasket?
Larry
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Mon Apr 09, 2007 9:11 am Post subject: Re: 582 coolant weep |
larry, look real close at it to see if the coolant is coming from the weep hole under the housing. the purpose of that hole is to let coolant or oil leak out and you will see it if the seal on the rorary valve shaft is starting to leak. there should be a space between the two seals so the water does't mix with the RV shaft oil when an oil or water seal leaks.
Tom Jones
Lynn Matteson
Posted: Mon Apr 09, 2007 9:25 am Post subject: 582 coolant weep |
Sometimes you can tighten a gasket too much, and then the housing
ends are forced down, and the water leaks from under the (now)
distorted housing. Lay a straight edge on both the housing and the
block to see if this has happened. You might be able to save the fit
by draw-filing the surfaces.
Lynn
On Apr 9, 2007, at 12:49 PM, Larry Martin wrote:
| Quote: | Why/how would coolant be leaking from the gasket under the water
Larry
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
davef(at)cfisher.com Guest
Posted: Mon Apr 09, 2007 9:31 am Post subject: 582 coolant weep |
Good point Tom,
On the 582 I will add that the anti-freeze you use with your distilled water
should be phosphate & silicate free eg - Dexcool or equivilent.
Check your Rotory valve oil bottle for any contamination as well. It will
usually make the oil in RV bottle turn milky. If so your RV seals are gone
and most likely the RV shaft.
I have seen the bolts on water pump housing leak as well but usually oil
from crankcase and they need some locktite put on them.
Dave
Posted: Mon Apr 09, 2007 12:53 pm Post subject: 582 coolant weep |
Thanks for the quick responses. I plan to start doing the engine annual next week and will look for these things.
larry
