Rudder Trim
Robin Marks
PostPosted: Sun Feb 05, 2006 9:18 am    Post subject: Rudder Trim Reply with quote
I have a 6A with no Rudder Trim. I have seen foam style wedges that are
applied to the lifting surface to act as fixed trim surfaces. I do not
know what the material is, what the best angles are and how they are
affixed onto the surface. I assume this has been discussed at length in
the archives. Can anyone give me a lead to what they are called as I
have looked in the archives but I don't think I am searching the proper
terms and there are a lot of listings on trim?
Robin
RV-6A - Needs Right Rudder
RV-4 Sold
RV-6A 0-360 - C/S Flying
ronlee(at)pcisys.net
PostPosted: Sun Feb 05, 2006 9:42 am    Post subject: Rudder Trim Reply with quote
I just cut a piece of ordinary foam, perhaps two inches long at my
eye-balled engineered angle and duct taped it on. It is temporary
until I decide what I really want.
I could get 3M double-sided tape, make it out of fiberglass, etc
but that will come later. It works for now.
Ron Lee
rhdudley(at)att.net
PostPosted: Sun Feb 05, 2006 10:31 am    Post subject: Rudder Trim Reply with quote
Hi Robin,
I have not seen any dimensions or specifications in postings on the
list. I have seen lots of RVs with wedges on the left side of their
rudders. They often are made of aluminum or wood. When I began testing
my -6A there was and obvious need for rudder trim. My solution was
trailing edge balsa made for model airplanes that I found at a hobby
shop. My procedure was to cut an arbitrary length of this material as a
starting point. I believe that I started with 10 inches. I taped it onto
the left trailing edge with the thickest part of the wedge aft using
duct tape. The 10 inches turned out to be too much. So, I cut it in half
and tried again. After several iterations, I ended up with about 6
inches length. I then finished a 6" length with the paint I used on the
plane and attached it with double stick foam tape. It has been in place
for about 60 hours and the ball is in the center at cruise speeds.
Hope this helps.
Richard Dudley
-6A 75 hours
Robin
Rick Galati
PostPosted: Sun Feb 05, 2006 11:38 am    Post subject: Re: Rudder Trim Reply with quote
terms and there are a lot of listings on trim?Thanks, Robin RV-6A - Needs Right Rudder Do Not Archive
Robin
Here is the link and the description of wedge I use with great success.
http://www.epm-avcorp.com/trimtabinst.html
Here is a detail photograph of my installation:
http://www.vansairforce.com/community/showthread.php?p=26694#post26694
Rick Galati RV-6A "Darla"
Robin Marks
PostPosted: Sun Feb 05, 2006 11:49 am    Post subject: Rudder Trim Reply with quote
Richard,
Thanks, that helps a lot. Did you place the trim high on the
rudder, low on the rudder? (seems like I have see them on the lower
section below the horz. stab) Did you place it perpendicular to the
horizon or running along the trailing edge?
Robin
RV-4 Sold
rhdudley(at)att.net
PostPosted: Sun Feb 05, 2006 4:43 pm    Post subject: Rudder Trim Reply with quote
Robin,
I can't look at it right now but, I believe that I put the wedge about
midway on the rudder. The trailing edge of the wedge is flush with the
trailing edge of the rudder. I think that the actual position along the
trailing edge of the rudder is not important. I placed it where it
looked ok to me.
Richard
Robin Marks wrote:
Richard,
Robin
