		by0ung(at)brigham.net Guest
				 Posted: Sat Apr 14, 2007 7:51 pm    Post subject: re. gasohol |
				| Would moisture have a chance to rust anything with the Pennzoil?  I
 can see
 | synthetic allowing rust, but natural oil?
 | Larry, Oregon
 I cant remember where I read this,,  but a natural mineral oil was better
 for corrosion protection against moisture,,,,   but synthetic oil was better
 at reducing friction wear,,,   so I use a mineral oil and synthetic  blend.
 Like john mentions an engine not run up to temps is more likely to have
 condensation  and moisture left in the system than an engine run at proper
 temps.   As to the alcohol or no alcohol in the gas should not make any
 difference.....   any time you burn a hydrocarbon in an engine  it will
 produce varing amounts of carbon  c   carbon monoxide   co   and carbon
 dioxide   co2   and h2o as byproducts,  so all the moisture in an engine
 does not come from the alcohol,,,,  it comes from the gas...   the alcohol
 in the engine will prevent water buildup in the fuel system including  the
 fuel tank and carb bowls.
 Boyd
				 Posted: Sat Apr 14, 2007 8:08 pm    Post subject: re. gasohol |
 alcohol
 including  the
 | Boyd
 Boyd:
 I think a major consideration is everything that is pulled through the
 carb goes through the crankcase in a two stroke before it gets to the
 upper end of the engine.
 Will this be a major factor in determining moisture/corrosion of
 bearings on the crank shaft?
  _________________ John Hauck
Titus, Alabama |
		d-m-hague(at)comcast.net Guest
				 Posted: Sun Apr 15, 2007 4:59 am    Post subject: re. gasohol |
				At 11:49 PM 4/14/2007, boyd wrote:
  	  | Quote: | 	 		  Like john mentions an engine not run up to temps is more likely to have
 The problem is not the water produced by burning hydrocarbons, but the fact
 that the alcohol absorbs water.  In small quantities it's not a problem; as
 you say it absorbs any water buildup in the tank (up to a point), but if
 that water comes back out of solution it can lead to corrosion in the
 internal parts (crankcase and bearings) before it ever gets into the
 cylinders to be burned.
                                  -Dana
 My software never has bugs. It just develops random features.
				 Posted: Sun Apr 15, 2007 12:51 pm    Post subject: re. gasohol |
  	  | Quote: | 	 		  >>>>>>>>>>>>>>>>>>>>>
 John
 I think that the major factor in determining moisture/corrosion on the crank
 shaft would be
 1  frequency of use...  in an engine that is used only infrequently will
 allow the oil protecting the metal parts  to drain off leaving it exposed to
 whatever is in the environment.
 2   temp of the engine when shut down.   If it is shut down cold the
 possibility of condensation is much greater,
 3   the type of oil...  synthetics drain off the metal parts faster than
 mineral oil.  And could also reduce proper  lubrication on start up. [ if
 infrequently used] ( I've been using mineral / synthetics  blend...you get
 the best of both worlds)
 4   the humidity of the air where the engine is stored...  would affect
 1,2,and 3 above.
 In a 2 stroke the biggest worry for me would be keeping the dust and dirt
 out by the use of a good filter,,  the moisture would be of little concern
 if operated correctly. The heat in the engine will keep the moisture boiled
 out.  The oil in the fuel should coat and protect everything from the
 moisture.  Even in a 4 stroke,, the moisture from humidity /combustion
 process will end up in the bottom end...   just at a smaller percent.
 Remember you are using blow by to force the oil back to the oil tank.   And
 all the same precautions concerning moisture  apply.
 If putting any engine away for any length of time,,,  it would be very
 beneficial to use some type of fogging / storage oil just before shutdown.
 The fogging oil is designed to stick to the parts without draining off and
 protecting the engine parts.
 I read in a magazine where a gentleman would turn the prop over once or
 twice a month  over a years time till he sold the engine/plane ,,, his
 thought process was to keep things moving.....  but turning it over without
 getting the oil up to temp and pressure,, caused the rings to scrap all the
 remaining oil off the cylinder walls and the bearings went dry...  when the
 engine was finally fired up it had very poor performance,  the teardown
 showed a multitude of moisture related  problems...  moral of the story was
 run it properly or store it properly,,  anything else will cause problems.
 Boyd
                                  -Dana
 Dana..
 Any alcohol in the tank will not reach outside the tank to find extra
 moisture to absorb...  it will  only work on what is already in the tank....
 thus if you fill the tank when done flying and force all the high humidity
 air from the tank before it has a chance to condensate on the tank walls and
 enter into the gasohol mix you will minimize the problem....
 Still in my opinion,, the greatest amount of problems associated with
 alcohol in the gas is the corrosion to storage tanks and seals used in the
 system.  NOT corrosion problems in the combustion process.
 Boyd
