extended wing tips
keystone(at)gci.net
PostPosted: Mon Apr 16, 2007 8:10 am    Post subject: extended wing tips Reply with quote
I installed a flat sheet of sheet metal to the flat portion of the wing tip on my 801. It extends about 3" above the wing in front and about 8" above the trailing edge. For now I just used 100 mile an hour tape to install it. I installed one to see if I could detect any change in flight characteristics. I was hoping for a yawing of the plane indicating less drag. What I got was a rolling effect. Normally when I fly the plane with just me in the left seat the left wing is heavy. With the extended wing tip on the left side the plane flew straight.
What got me started thinking about modifying the wing tip was talking with Bob Jones who installed "stall fences" on his 701. He said the "Dutch roll" tendency was greatly reduced. He really like the way it flew. I looked at the latest thoughts on wing tips and thought can I improve the flight characteristics a couple of percent.
Has anyone else experimented with this?
Can anyone tell me if I have more lift will you go faster? or slower?
Bill Wilcox
N801BW
Valdez, AK
290 hrs
Spring has finally sprung!
