		ebbfmm(at)verizon.net Guest
				 Posted: Tue Apr 24, 2007 3:14 am    Post subject: Oil Temperature High |
				<![if !supportEmptyParas]> <![endif]>
 My friend is test flying an RV6 fuel injected 0320. At 75% power runs ie: engine break-in, he is seeing oil temperatures in the 210 – 220- range. This is with an OAT of 34 degrees. He has a firewall mounted oil cooler and used the van’s kit for installation, which utilizes a 3” scat duct. His feeling is that this is not enough airflow through the cooler and because the cooler plenum (shroud) is so squat that not enough air is being distributed across the entire face off the oil cooler. Any thoughts on this…Thanks
  AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fran Malczynski
 RV6 - N594EF
 Olcott, NY
 <![endif]--><![if !supportEmptyParas]> <![endif]>
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		deruiteraircraftservices( Guest
				 Posted: Tue Apr 24, 2007 3:48 am    Post subject: Oil Temperature High |
				Hi,
  Those temps are fine for an engine that is being  run in. Red line is about 245F. Once he has a few hours on the engine and it  loosens up a bit the temps will come down a bit.
  It's not something that would worry  me.
  Marcel
  [quote]   ---
		shempdowling2(at)earthlin Guest
				 Posted: Tue Apr 24, 2007 5:13 am    Post subject: Oil Temperature High |
				I had the exact same setup with an  io360.  Mine didnt cool much after break in.   I ended up  putting the cooler on the rear baffle.  I havent heard many 320 temp  problems though.  Have him really, really check his baffling for  leaks.  It makes a big difference.  If that doesnt work, I would just  move it to the baffle and get it over with.  At least that way you know its  as good as its going to get.
  Shemp/Jeff Dowling
 RV-6A, N915JD
 300+  hours
 Chicago/Louisville
  [quote]   ---
		n801bh(at)netzero.com Guest
				 Posted: Tue Apr 24, 2007 5:39 am    Post subject: Oil Temperature High |
				For a fresh motor,  210-220 f  is about perfect. Just my two cents worth....
 Ben Haas
 N801BH
 www.haaspowerair.com
  Shemp/Jeff Dowling
 RV-6A, N915JD
 300+ hours
 Chicago/Louisville
		bicyclop(at)pacbell.net Guest
				 Posted: Tue Apr 24, 2007 10:15 am    Post subject: Oil Temperature High |
				The squat plenum may well be causing some turbulence and reducing airflow. The sides of the plenum shouldn’t diverge more than 19 degrees, if I remember the figure correctly, to keep the airflow attached. Pay attention to the exit side also. If there are obstructions, it can reduce airflow.
 We’ve got a firewall mounted Niagara with 3 inch scat (one 90 degree bend) on our 6-a, O-320. It has a long plenum and is fine for winter and spring (185-195), but doesn’t do well enough in summer (220+). We’re thinking seriously about moving it to the baffle. In the meantime, 750 hrs worth of it, we change the oil at 25 hrs, tach.
 Pax,
 Ed Holyoke
		kboatright1(at)comcast.ne Guest
				 Posted: Tue Apr 24, 2007 2:39 pm    Post subject: Oil Temperature High |
				I had high temperatures on my O-320 RV6 initially  and eventually solved the problem, primarily through more airflow. I agree that  210-220 is high with a 34F OAT (presumably at the surface level), even for a new  engine.
  In the past, Vans has indicated that a 3" scat tube  is very marginal for feeding a firewall mounted cooler on an RV-6. That's only a  cross section of 6 or 7 square inches. A 4" SCAT tube would have almost double  the cross section and have less flow loss from surface  friction.
  My recommendation is to increase the size of the  SCAT tube...
  KB
  [quote]   [quote]     ---
		tcervin(at)valkyrie.net Guest
				 Posted: Tue Apr 24, 2007 3:19 pm    Post subject: Oil Temperature High |
				Kyle.....Good idea!!! I have a 4" Tube running to the firewall  mounted cooler on my RV6-A.  I have never seen an Oil Temp. above 185 and  my RV is running the 0-360-A1A.
        Tom in Ohio
  [quote]   ---
		Mark Phillips in TN
  Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
				 Posted: Tue Apr 24, 2007 9:50 pm    Post subject: Oil Temperature High |
				In a message dated 4/24/2007 6:16:14 AM Central Daylight Time,
 ebbfmm(at)verizon.net writes:
 _http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5000_
 (http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5000)
 This arrangement has worked well on my 150hp E3D for over 400 hours.  Click
  	  | Quote: | 	 		  >Next Entry>> at top of page for more entries, and click on foto for bigger
 look...
  	  | Quote: | 	 		  From The PossumWorks in TN,
 Mark RV-6A "Mojo"
 ************************************** See what's free at http://www.aol.com
  _________________ From The PossumWorks... |
