erichdtrombley(at)juno.co Guest
Posted: Thu Apr 19, 2007 4:04 pm Post subject: Mod 72 |
For those that have completed Mod 72, did you have to drive the insert into position or did it slide all the way into position. I am able to get the insert slid most of the way into the tube leaving about 1" to be driven in with a punch. I hate to start driving the insert in only to realize that I am unable to seat it fully.
Erich Trombley
________________________________________________________________________
Interested in getting caught up on today's news?
Click here to checkout USA TODAY Headlines.
rlborger(at)mac.com Guest
Posted: Thu Apr 19, 2007 5:10 pm Post subject: Mod 72 |
Erich,
In my case, it took some gentle tapping with a 1 lb hammer on a block of wood to press the tubing into place.
I compared the 110mm length of the tube to the length of the reamer so I would know when I had the reamer in sufficiently far to allow the tube to seat fully.
You can check my build site (see signature block). Go to Year #6 Q1 2007, page #3 for pics and some description.
Good building and great flying,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(85%) tail kit done, wings closed, cockpit module installed, pitch system in, landing gear frame in, rudder system in, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar in, flap drive in, Mod 70 done. Baggage bay in. Flaps & Main Gear complete. Mod 72 complete. Working in - 24 Instrument Panel, 25 Electrical, 30 Fuel System, 32 Tail, 34 Door Latches & 35 Doors, 37 Finishing. Airmaster arrived 29 Sep 05. Seat arrived from Oregon Aero. E04 interior kit has arrived and is being installed. Installing the ROTAX 914, again.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
DuaneFamly(at)aol.com Guest
Posted: Thu Apr 19, 2007 11:17 pm Post subject: Mod 72 |
Erich,
I measured the distance from the outer edge down into the tube until I hit the frame mounting bolt that's inside there. This way I was sure I had the room to power seat (ball peen hammer and a block of wood) the insert into place. Took a little effort, but it won't come out! Now I see why they didn't call for any adhesive.
Mike Duane A207A
Redding, California
XS Conventional Gear
Jabiru 3300
Sensenich R64Z N
Ground Adjustable Prop
See what's free at AOL.com.
karelvranken(at)hotmail.c Guest
Posted: Fri Apr 20, 2007 12:09 am Post subject: Mod 72 |
Erich,
I had the same experience. Prepare it for definitely drive in and with a rubber hammer and a piece of wood the tubes go in at the bottom. My friend Dirk Oyen did about the same but IMHO he waited to long for the fix so that the metal painture on the tubes became dry and hard. Finally he had to cut of about 1 inch of one of the tubes because he couldn't get it out anymore. Though he assures me that it was reamed at the bottom.
Succes,
Karel Vranken, # 447 Mono XS, Rotax 912ULS, Airmaster AP332.
