Mark.Summers(at)lwbref.co Guest
Posted: Mon Feb 06, 2006 5:34 am Post subject: which weld |
I am ready to weld a new tail on my KF 2, splice all 4 longerons and
smaller cross braces together. I was intending to get it mig welded with
ers80-d2 wire but now a few second thoughts. I am now concerned about
brittleness from the concentrated heating. Anyone have any
opinions/experiences with welding this 4130 thin tube? I am leaning more
toward gas acetylene and not sure which filler to use. I welcome all input
Thanks Mark
roncarolnikko(at)hotmail. Guest
Posted: Mon Feb 06, 2006 8:46 am Post subject: which weld |
Oxy- acetaline helps avoid brittlenes, and your local welding shop should
have the right filler rod for 4130. So I've heard. I welded my motor
mount mig and will relieve it with a torch. Ron NB Ore
Quote: | From: Mark.Summers(at)lwbref.com
To: Kitfox-List(at)matronics.com
Subject: which weld
Date: Mon, 6 Feb 2006 07:29:24 -0600
Thanks Mark
Posted: Mon Feb 06, 2006 12:03 pm Post subject: which weld |
Am I right to suppose you would not be too opposed to using mig on the
longeron tubes if you welded your motor mounts mig? I have a friend that is
a very good mig welder and that is the easiest road for me to get the job
done, but the brittleness thing has me concerned. Some say that I could do
as you said and normalize the weld with a torch and wrap the tubes with
fireblanket to slow the cooling afterward. Does this sound right, and
thanks for your feedback. Mark
colind
Joined: 10 Jan 2006 Posts: 32 Location: Sydney, Australia
Posted: Mon Feb 06, 2006 1:56 pm Post subject: which weld |
Mark,
I have recently been investigating welding techniques, more out of
interest than need, especially with regard to welding airframes. (Possible
future project).
I came across a gas welding kit which uses oxy-acetylene, but does so in a
unique way, so as to minimise stress and brittleness, etc. The kit is
called the DHC 2000. I don't know who the original manufacturer is, but
suppose that it is actually a US based company. The address that I have
for the distributor in Australia is: www.amweld.com.au. There are a number
of explanatory video clips available at that site. The only US address I
have is: www.fournierenterprises.com . Have a look at this as it may be of
some help to you in deciding what method to use.
Colin Durey
Sydney
is
Colin Durey
Pacific Technology Corporation Ltd
+61-418-677073 (M)
+61-2-945466162 (F)
_________________ Colin Durey
Sydney
+61-418-677073 |
Posted: Mon Feb 06, 2006 3:27 pm Post subject: which weld |
Mark there are many schools of thought. Most agree that a torch is the
easiest to get good results. Tig is the next choice, but a good mig will
suffice. I don't have a tig hooked up and use propagne / oxy or plasma for
cutting. Ron NB Ore
Subject: RE: which weld
Date: Mon, 6 Feb 2006 13:58:26 -0600
kitfox91je(at)hotmail.com Guest
Hello. I wanted to put a quick note on here about welding. There is a
really nice book out at Barnes and Noble and others titled "Monster Garage-
how to weld damn near anything" It talks about performance welding in
aircraft adn racecars and dispels many old myths that are handed down
without basis in fact. It covers MIG TIG and Oxy-acetlyn welding..and gives
the benefits and drawbacks to each. It also gives a really nice overview of
troubleshooting where most get into trouble and how to prepare the welding
rig and the metal. Its not a comlete guide to welding, but a good first
read.
Dan
Kitfox went home to Idaho...working on a Stearman.
Date: Tue, 7 Feb 2006 08:52:56 +1100 (EST)
Mark,
future project).
Colin Durey
Sydney
> is
job
do
Colin Durey
+61-418-677073 (M)
+61-2-945466162 (F)
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
ddsyverson(at)comcast.net Guest
Posted: Mon Feb 06, 2006 4:19 pm Post subject: which weld |
Mark,
There are a lot of books about the subject of welding and lots of opinions as
to the preferred method.
If a person has MIG equipment available and someone with the skill to use it,
it works great. Ditto for Oxy.
I happen to be a bit low tech on this since I use an oxycetylene torch for
just about everything. The big deal with oxycetylene welding is that you can
do just about anything you need to with a few changes of tips for your welder
- it is a very adaptable.
I won't try to give welding lessons over the e-mail, but I will offer a few
bits of advice.
1) MIG or Oxy - in both cases you need to be real sure that the weld has
adequate penetration and no slag incorporated in the weld - I would use
whatever system you have available - they are both good and the most
important issues is the ability of the welder.
2) If Oxy - a) you will have a little more heat involved - do some practice on
scrap pieces of the same thickness and experiment with tip size/gas pressure
to avoid burn throughs when doing it for real. b) Use 4130 rods - I use 1/16"
for aircraft tubing - they run about $5-$8 per pound. c) After welding the
parts up - normalize the weld area and do what you can to slow the cool rate.
On my model 7, I had to do some repair work due to manufacturing defects in
the fuselage weldment; and, did a reverse engineering thing on the front trim
bracket since one was not supplied with my kit at the time of the bankruptcy.
Also - once everything is done, go ahead and try to break it with a
reasonable force - if it doesn't hold - you want to know that before you are
in the air. I am always amazed at how strong 4130 weldments are. Both
projects survived the torture.
Sincerely,
Dave
St Paul
joakley(at)ida.net Guest
Posted: Mon Feb 06, 2006 4:38 pm Post subject: which weld |
I know we want the best welds, but... the factory used mig on all of our
planes, I havn't seen a problem with that in 20 years now... humm... 22
years.
john Oakley
over a thousand hours in fox's now.. and not nearly enough.
Posted: Mon Feb 06, 2006 6:02 pm Post subject: which weld |
I sure appreciate everyone's comments and opinions, I believe I will let my
friend give the mig a try on some extra .035 1/2" tube pieces to get a
feel and if he says go , we go. I have heard or read that 100% argon
sheilding gas is recommended over the argon co2 mix. I hate to keep asking
questions butttt. Thanks again Mark
fultz(at)trip.net Guest
Posted: Mon Feb 06, 2006 8:38 pm Post subject: which weld |
Colin, Mark and the rest of the gang,
If you do any amount of gas/oxy welding and you purchase and DHC 2000
(formerly Henrob 2000, formerly Dillon)you will not be sorry. I found one
in the fly market at OSH used and snatched it up. One af the best purchases
I have ever made.
Andy F.
Posted: Mon Feb 06, 2006 9:28 pm Post subject: which weld |
Anything is better than co2, but even that will work. I use Argon and
steel mix mainly for stainless. Go for it and test your welds. Ron NB Or
Subject: Re: which weld
Date: Mon, 6 Feb 2006 19:59:25 -0600
smokey_bear_40220(at)yaho Guest
Posted: Mon Feb 06, 2006 10:11 pm Post subject: which weld |
Just a side not of interest. When my friend was
welding up his 2/3rds scale Jenny, he changed from gas
to electric welding for some parts near the end.
Building his plane was a chance for him to learn more
and practice his welding, but he got caught by a
routine. When he tried to do his first electric
parts, he couldn't get the arc to stay put on the
weld. He closed the window and turned off the fan.
Fussed with current and tips.
Then it hit him. He was using a magnetic parts tray
to hold the parts. OK for gas, but a pain with
electric. Sometimes it is the little things.....
Kurt S.
Graeme Toft
Posted: Mon Feb 06, 2006 10:29 pm Post subject: which weld |
Talking of magnetics also Kurt electric welding will, as many of us have
found, introduce a magnetic field into the airframe that can be hard to get
rid of. Some may remember the problem I had with my model 1 when I attempted
to install a compass and got a 15degree swing. I had to degause the airframe
before the compass could be acurrately swung. Just my 2 bobs worth.
Graeme
shoeless(at)barefootpilot Guest
Posted: Tue Feb 07, 2006 3:17 am Post subject: which weld |
Numerous Kitfoxes have had broken welds on motor mounts, rudder pedals and
landing gear.
Many of these can be found in the archives and many more have gone
unreported. I don't know all that much about welding, but I wouldn't use mig
in critical high stress areas based upon the failures that I know about.
Cliff
years.
john Oakley
7suds(at)Chartermi.net Guest
Posted: Tue Feb 07, 2006 1:44 pm Post subject: which weld |
Mark,
I repaired the aft section of my Model 5 fuselage using mig, I contacted the
factory and asked what wire they were using and bought the exact wire. I
copped all joints / clusters for a tight fit, I used straight burrs of
various sizes in my drill press with a block of wood clamped on the table as
a steady rest (crude but effective). I then emery papered and de-burred the
ends before assembly. Before welding I pre-heated the joints. I would always
cut the end of my wire before starting my weld so the bead that was left
from the last weld was gone. After all was welded I used a heavy black sand
(can't remember the name) to sand blast all the tubing and especially the
weld joints (has some stress relieving attributes) before priming and
painting. I am very happy with the results. One last thing, I used our
local EAA Chapter tech counselor as a resource, he is an A&P and an
inspector so he checked my work along the way, made sure I didn't do
something dumb. And yes, practice is good. What I found was as I built
clusters they required more attention to pre-heat and weld technique as the
mass would tend to weld cold if you did not direct your arc heat there as
opposed to the tube you were adding to the cluster, hope that makes sense to
you.
Good luck, and have fun!!
Lloyd
Posted: Wed Feb 08, 2006 3:20 am Post subject: which weld |
That is good info, I don't have any clusters to make I bought the aft 5 ft.
of a kf 4 and will inner splice the longerons and outer splice the 3/8"
cross braces between the two rear clusters. So you didn't post heat the
welds at all? I had planned to preheat the weld area just too hot to touch
and maybe post heat about the same and wrap with fireblanket to slow cool.
I bet you don't remember the wire type and which gas you used do you?
Thanks Mark
AMuller589(at)aol.com Guest
Posted: Fri Feb 10, 2006 12:31 pm Post subject: which weld |
Your questions lead me to believe you need to look at the welding techniques
and methods of splicing specified in aircraft circular AC 65-15A. This is
the AIRFRAME AND POWERPLANT MECHANICS AIRFRAME HANDBOOK, esp pages 276, and
figures 6-38, 6-39, 6-40, 6-41 et al for spice joints and pages 269 plus for
welding techniques. There have also been several articles on the advantages and
annealing techniques for the TIG, MIG, and gas welding of aircraft tubing in
Sport Aviation and Kitplanes.. Basically what these said AS I RECALL Generally
they recommend post weld annealing with gas for welds made using gas and TIG
since the heat is less concentrated than MIG. Even the articles in Kitplane
and Sport Aviation have some arguments pro and con on the annealing process
so I would anneal with gas if it were me. According to AC-65 you should use
internal splicing if you need to avoid bulges where surface smoothness is a
factor (i.e. under fabric).AC 65-15 and Kitplane and Sport Aviation address
all welding techniques. WORD OF MOUTH has it that NASA recently adapted a
welding policy that requires "coat hangar" type welding rod with more generous
beads than before for aircraft and spacecraft tubing, and post weld annealing.
Annealing is much higher temperatures than you seem to think. Stress relief
as quoted from the LINCOLN welding manual is"The stress relief range for most
carbon steel is 1100 to 1200 deg F and the soaking time is usually one hour
per inch of thickness.", These are not difficult procedures and are probably
what you intended but should relieve your mind of all doubts. Splicing Tubing
by Inner Sleeve Method should be used
If the damage to a structural tube is such that a
partial replacement of the tube is necessary, the
inner sleeve splice shown in figure 6-41 is recommended,
especially where a smooth tube surface is
desired. A diagonal cut is made to remove the damaged
portion of the tube, and the burrs are removed
from the edges of the cut by filing or similar means.
A replacement steel tube of the same material and
diameter, and at least the same wall thickness is
then cut to match the length of the removed portion
of the damaged tube. At each end of the replace.
ment tube a l/s-in. gap should be allowed from the
diagonal cuts to the stubs of the original tube.
A length of steel tubing should next be selecteddiameter equal to the inside
diameter of the damaged
tube. This inner tube material should be fitted
snugly within the original tube. Cut two sections of
tubing from this inner-sleeve tube material, each of
such a length that the ends of the inner sleeve will
be a minimum distance of one and one-half tube
diameters from the near-t end of the diagonal cut.
If the inner sleeve fits very tightly in the replacement
tube, the sleeve can be chilled with dry ice or
in cold water. If this procedure is inadequate, the
diameter of the sleeve can be polished down with
emery cloth. The inner sleeve can be welded to the
tube stubs through the +&in. gap, forming a weld
bead over the gap.
of at least the same wall thickness and of an outside
