		d-m-hague(at)comcast.net Guest
				 Posted: Wed Apr 18, 2007 12:41 pm    Post subject: Gasohol, gascolators |
				At 03:38 PM 4/18/2007, henry.voris wrote:
  	  | Quote: | 	 		            If you're worried about water contaminated gasohol carrying
  moisture to the innards of your two-stroke engine and rusting the
  bearings... it ain't gonna happen. There are plenty of bad things about
  gasohol but this isn't one of them.
          The ethanol in the gasohol not only attracts water, it forms a
  little cage around each water molecule. To get them to separate takes
  adding another alcohol and a two step distillation process....learn to
  live with the lead (check plugs and for carbon more frequently).... If ya
  gotta use gasohol install a gascolator so you can catch any problems
  before they get to your carburetor...
 That's interesting... my understanding has always been that methanol, at
 least, is a problem for corrosion.  Does ethanol react that much
 differently?  Or is it a problem mainly because methanol based fuels (e.g.
 model glow fuel) is mostly methanol, rather than the 10% in gasohol?  Then
 there's the coming E85 fuel, which is 85% ethanol...
 Re the gascolators... on my Taylorcraft I had a gascolator with a glass
 bowl, which was nice because I could see what was in it before draining
 it.  All the aircraft gascolatars I can find nowadays are all metal, and
 all the automotive or power equipment ones are small and have no
 drain.  I'd like to put a glass bowl gascolator-- with a drain-- on my
 Ultrastar, replacing (or supplementing) the inline fuel filter.  Anybody
 got any suggestions?
                                  -Dana
 My software never has bugs. It just develops random features.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Wed Apr 18, 2007 1:55 pm    Post subject: Gasohol, gascolators |
				At 04:37 PM 4/18/07 -0400, you wrote:
 Dana,
 If you are just interested in seeing if water is dropping out, there is a
 small one available for motorcycles that can be purchased from:
 http://www.enfieldmotorcycles.com
 Part # Z90395 - $9.95
 In eight years, I have never found water in the Bing float bowl.  I drain my
 five gallon tank in the spring and the most water I have found is between
 the volume of a nickel or a dime.  Water does accumulate in my gas cans.  I
 use four 2.5 gallon gas cans to transfer fuel.  I always leave about a cup
 of fuel in the cans.  This keeps the water in the cans and along with enough
 fuel so that when I put in oil, the oil is already some what premixed before
 refilling at the gas station.  I remove the water from the transfer cans
 once a year.
 For what it is worth.
 Jack B. Hart FF004
 Winchester, IN
		rlaird
				 Posted: Wed Apr 18, 2007 2:13 pm    Post subject: Gasohol, gascolators |
				Maybe there's a reason why some people have moved away from glass bowls:
 NTSB Identification: FTW95LA072
 Accident occurred Saturday, December 24, 1994 in LA PORTE, TX
 "LOSS OF ENGINE POWER DUE TO FUEL STARVATION AS RESULT OF THE FAILURE OF THE GLASS BOWL ON THE GASCOLATOR."
 NTSB Identification: LAX95LA150
 Accident occurred Friday, March 31, 1995 in EL CAJON, CA
 "a loss of engine power due to an in-flight separation of the fuel system gascolator glass bowl resulting in a premature fuel exhaustion"
 Ehhh, naw, maybe the NTSB was just looking for SOMEthing and could only come up with a broken glass bowl (probably caused by the crash).
 Or not.
   -- Robert
 On 4/18/07, Dana Hague <d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)> wrote: [quote]--> Kolb-List message posted by: Dana Hague < d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
 differently?  Or is it a problem mainly because methanol based fuels ( e.g.
                                  -Dana
  _________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
formerly: MkIIIc w/ 912ULS  &  Gyrobee
current:  Autogyro Cavalon w/ 914ULS
Houston, TX area
http://www.Texas-Flyer.com |
		biglar
				 Posted: Wed Apr 18, 2007 2:32 pm    Post subject: Gasohol, gascolators |
				This subject came up a bit ago, and I'll repeat my comment from then - I have a Racor marine fuel filter/separator on my boat that has a replaceable filter element (like a standard oil filter) and a plastic (I think polycarbonate, but not certain) see-thru bowl.  Easy to see water in the fuel, easy to change, not too expensive, and not too large.  I got it because I was fishing in Baja and buying gas down there.  Never did have a problem, but it's nice to be sure.  Important on the water, more important on Mexican water, and really important in the air.                           Lar.
  On 4/18/07, Robert Laird <rlaird(at)cavediver.com (rlaird(at)cavediver.com)> wrote: [quote]Maybe there's a reason why some people have moved away from glass bowls:
 Or not.
   -- Robert
  On 4/18/07, Dana Hague <d-m-hague(at)comcast.net  (d-m-hague(at)comcast.net)> wrote:   	  | Quote: | 	 		  --> Kolb-List message posted by: Dana Hague <  d-m-hague(at)comcast.net (d-m-hague(at)comcast.net)>
                                  -Dana
  | 	  [b]
  _________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
		rlaird
				 Posted: Wed Apr 18, 2007 2:39 pm    Post subject: Gasohol, gascolators |
				Lar --
 Is this the one:
 http://reddenmarine.com/site/new-detail.cfm?id=RAC215R2
   -- Robert
 On 4/18/07,  Larry Bourne <biglar(at)gogittum.com (biglar(at)gogittum.com)> wrote:[quote] This subject came up a bit ago, and I'll repeat my comment from then - I have a Racor marine fuel filter/separator on my boat that has a replaceable filter element (like a standard oil filter) and a plastic (I think polycarbonate, but not certain) see-thru bowl.  Easy to see water in the fuel, easy to change, not too expensive, and not too large.  I got it because I was fishing in Baja and buying gas down there.  Never did have a problem, but it's nice to be sure.  Important on the water, more important on Mexican water, and really important in the air.                           Lar. [b]
Robert Laird
Houston, TX area
				 Posted: Wed Apr 18, 2007 4:55 pm    Post subject: Gasohol, gascolators |
				At 07:07 PM 4/18/2007, Jack B. Hart wrote:
  	  | Quote: | 	 		  If you are just interested in seeing if water is dropping out, there is a
 Problem with that one (like the tractor parts) is no drain, unless you
 remove the bowl each time... messy.  The aircraft gascolator on my T-Craft
 had a glass tube between a metal top and bottom, with the drain in the bottom.
                                  -Dana
		biglar
				 Posted: Wed Apr 18, 2007 5:36 pm    Post subject: Gasohol, gascolators |
				Perty close, Robert, but that one's for a diesel.  Mine has a smaller filter section, and a larger, blue colored bowl.  The whole thing's a little bigger than my fist.                   Lar.
  On 4/18/07, Robert Laird <rlaird(at)cavediver.com (rlaird(at)cavediver.com)> wrote: [quote]Lar --
 Is this the one:
   -- Robert
  On 4/18/07, Larry Bourne <biglar(at)gogittum.com (biglar(at)gogittum.com) > wrote:   	  | Quote: | 	 		  | This subject came up a bit ago, and I'll repeat my comment from then - I have a Racor marine fuel filter/separator on my boat that has a replaceable filter element (like a standard oil filter) and a plastic (I think polycarbonate, but not certain) see-thru bowl.  Easy to see water in the fuel, easy to change, not too expensive, and not too large.  I got it because I was fishing in Baja and buying gas down there.  Never did have a problem, but it's nice to be sure.  Important on the water, more important on Mexican water, and really important in the air.                           Lar.   |
Palm Springs, CA
"Vamoose" |
		Steve Boetto
				 Posted: Thu Apr 19, 2007 3:12 am    Post subject: Gasohol, gascolators |
				Just saw a really small gascolator at SnF. It was on a new version of an  Easy Riser.
  BTW, got to see John Moody fly an original Riser late yesterday in 25 mph  winds.
  The gascolator was available from Briggs and Stratton at a mower  store.
  Steve
 See what's free at AOL.com.
		rowedenny(at)windstream.n Guest
				 Posted: Thu Apr 19, 2007 5:43 am    Post subject: Gasohol, gascolators |
				[quote]   Just saw a really small gascolator at SnF. It was on a new version of an    Easy Riser.
    Steve
 Steve,
    Did it have a sump drain and glass bowel?
    Denny Rowe
		lcottrell
				 Posted: Thu Apr 19, 2007 6:51 am    Post subject: Gasohol, gascolators |
				Why don't you guys build your own as per the instructions put on the list  earlier in the year? The cost is two PVC caps, a short piece of PVC, two nylon  fuel barbs, and a ?Murphy? drain valve for 17.50 that comes out the bottom of  your airplane to drain it. I forgot you will also need a tube of thread sealer  as well. Mine works well.
  Larry, Oregon
  do not archive (am I the only one using this feature?)
  [quote]   ---
		Paul Petty
				 Posted: Thu Apr 19, 2007 9:13 am    Post subject: Re: Gasohol, gascolators |
				Dana,Larry all,
 I made mine from a small block of aluminum and a certified sump. Mine can be sumped from the back of the plane at the lowest point in the system with the little sample cup like the spam can guys use
  _________________ Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp |
		Steve Boetto
				 Posted: Thu Apr 19, 2007 6:26 pm    Post subject: Gasohol, gascolators |
				In a message dated 4/19/2007 9:44:40 A.M. Eastern Daylight Time,  rowedenny(at)windstream.net writes:
   	  | Quote: | 	 		     Steve,
    Denny Rowe
  yup
  steve
				 Posted: Fri Apr 20, 2007 5:21 pm    Post subject: Gasohol, gascolators |
				Steve,
  Please give me that part number again, I think I want one.
  Denny
  [quote]   ---
		Steve Boetto
				 Posted: Sat Apr 21, 2007 3:10 am    Post subject: Gasohol, gascolators |
				Denny
  no part #. Going back to show today, I will get more info
  steve
