		kitfoxfugit(at)yahoo.com Guest
				 Posted: Sun Apr 22, 2007 10:54 pm    Post subject: "Florida" Trip |
				Re
 Lynn Matteson <lynnmatt(at)jps.net>
 Subject: My "Florida" trip
 Pilotage
 Radio Use
 Turbulence
 Crosswinds
 Some thoughts:
 A pilot is supposed to access "all information" before
 flight.  Of course by the time you are done, you have
 to start over due to conditions becoming stale during
 the time lapse.  All joking aside, there are some
 important things to check.  That includes weather
 conditions, your route, prohibited airspace,
 alternatives, and the condition of the aircraft,
 including making sure parts like seats are properly
 fastened (like pilot seats on many Cessnas that can
 slide back upon takeoff).  Remember, the pilot in
 command usually is assigned the blame.
 Many of us who started flying before GPS, and without
 radios, learned pilotage.  Still good to know.  You
 can find landmarks almost anywhere, can determine your
 heading and groundspeed and make compass corrections
 (if those were not calculated on preflight or differ
 due to changed conditions or a wrong forecast).  Other
 options besides GPS are vectors from ATC, or
 intersecting readings from two VOR's.  One should be
 able to determine and hold a proper compass heading
 over featureless terrain.
 Radio use is just like landings, it takes practice.
 Like you, I liked to stay out of busy places and was
 not comfortable with radio use, because I learned and
 flew without ever using it much.  But, it can be
 convenient to pass through certain airspace and
 usually you will not get reprimanded if your technique
 is not perfect.  Visit an ATC facility sometime.
 If you fly into bad conditions, there is usually a
 real good option, better exercised earlier rather than
 later: the 180.  Normally it is better where you came
 from and you can go back there.  Proceeding is not
 worth dying for or breaking up an airplane, although
 people do both in T-storms or severe weather
 conditions of some type that, often, they could have
 flown away from.  The longer you continue into the bad
 conditions, the more restricted your options usually
 become.
 If you arrive someplace that has a crosswind beyond
 the plane's (or pilot's) limitations and have to land
 soon, you may have a couple of alternatives to
 potential damage from a beyond-limits crosswind
 landing.  If you have an AFD or GPS (and it is not too
 bumpy to read it and you know where you are) you may
 be able to find a strip with more favorable runways.
 Another option some pilots have used in a strong
 crosswing is to land across the runway/taxiway or on
 the ramp, depending upon the facilities and
 conditions, as the rollout should be short.  After
 landing, you may need to let the plane weathervane and
 get help walking the wings in and tying down to avoid
 blowing over on taxi.  Being closer in is an advantage
 for that.  Some runways have sheltered areas on the
 runway due to terrain or buildings.  You can look for
 clues or drag the runway first, but watch for
 windshear in the transition.
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Float Flyr
				 Posted: Mon Apr 23, 2007 3:30 pm    Post subject: "Florida" Trip |
				Lynn:
 Don't worry too much about your radio "technique" The important thing is to
 be on the right frequency listening to the correct information.  That's what
 it's all about.  I've only once heard about anyone getting written up over a
 lapse of radio procedure.  On the ham bands where the contact is the
 important thing then procedure is really appreciated but that's another
 quintal of fish.
 Noel
 [quote] --
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Guy Buchanan
				 Posted: Mon Apr 23, 2007 8:22 pm    Post subject: "Florida" Trip |
				At 04:30 PM 4/23/2007, you wrote:
  	  | Quote: | 	 		  Don't worry too much about your radio "technique" The important thing is to
 it's all about.
 I'm going to encourage Lynn to work hard on his technique, because
 I've found it makes a big difference for the following reasons:
 1. Most importantly it makes a difference in how ATC and control
 towers handle you. If your technique is spot on you get many more
 benefits than if it's even a little off. If you're really pedantic
 you can get parked in the boonies, or sent around airspace, or
 extended downwind, or denied flight following, or any number of other
 nuisances.
 2. When at a busy field it is very easy for frequencies to get bogged
 by slow, incomplete transmissions. At non-towered fields this can get
 worse than frustrating, it can get quite dangerous as location calls
 start getting missed or simply ignored. At towered fields it just
 means fewer people get to operate.
 3. Finally, it's really easy to have good technique. Learn a few
 simple rules and practice.
 Guy Buchanan
 San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
		kitfoxmike
				 Posted: Tue Apr 24, 2007 6:41 am    Post subject: Re: |
				This is cool stuff.  When I flew over to arlington last year(airshow in washington state)  I was watching the weather like a hawk.  I didn't like what I saw, I had the info on computer for the passes and all the airports along the way.  If you go to the national weather site you can acces airports that have weather reporting, very cool stuff.  In fact the state has cameras set up in most the passes, I was able to see first hand what those looked like.  When things cleared, by friday, me and the wife jumped in the plane and set off.
 Now for pilotage.  I have the IQ3600a and will say this unit is amazing.  But I don't like only one option, so I had an old gps one of the first small garmin no III something like that, I had behind our head with fresh batteries for a back up.  I had current charts for the route and a washington state ground map.  As I was flying the wife had both the other maps and following our progress while I flew the plane and kept an eye on the GPS and the charts.  When I fly I go IFR(i fly roads, railroad tracks, rivers)  That's where the ground maps come in, I want to know what rivers, roads are under me, the main roads are on the GPS, but I want to make sure that I'm following the proper stuff.  Dead reckoning is cool but can be pretty tough sometimes, but will get you out of a pickle.
 Main thing is, you need to have all the options open and available to you.  Don't rely on luck, go on skill.  My instructor once told me that when you first start out you have a big bag of luck, what you need to do is replace that luck with experience.  Learn what you can, when you can, and practice, practice, practice.  Replace that luck in the bag with experience.
		kitfoxmike
				 Posted: Tue Apr 24, 2007 8:10 am    Post subject: Re: |
				I hope this comes through right, but here are some links for weather at local airports and most important AOPA's flight planner, very cool.
 The flight planner:
 http://www.aopa.org/flight_planner/
 for the airport weather, this one is for Osh.
 http://weather.noaa.gov/weather/current/KOSH.html
 The easiest way to get your airport or one close to you is at the end of the tag replace the KOSH with yours, I think you need to use caps.
 like maybe this one in michigan:
 http://weather.noaa.gov/weather/current/KGDW.html
 Like I wrote, hope the url's came out right.
		kitfoxmike
		kitfoxmike
				 Posted: Tue Apr 24, 2007 8:15 am    Post subject: Re: |
				KGDW is an airport, just not supported I guess.
		Lynn Matteson
				 Posted: Tue Apr 24, 2007 12:41 pm    Post subject: "Florida" Trip |
				Many thanks, John, for all the tips...I printed your message out, but
 forgot to thank you. I did indeed learn pilotage, and enjoy using it,
 because I actually love doing the math, writing down the est. times,
 actual time as I cross them, etc. I find it gives me something to
 keep my mind on rather than just staring at the little airplane on
 the screen which is not seeming to go anywhere...unless I have a
 60-70 mph tailwind!
 Lynn
 On Apr 23, 2007, at 2:53 AM, John Allen wrote:
  Re
  Pilotage
  Radio Use
  Turbulence
  Crosswinds
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		Lynn Matteson
				 Posted: Tue Apr 24, 2007 1:43 pm    Post subject: "Florida" Trip |
				Mike, none of the urls came through on the last two posts, or this one.
 Lynn
N369LM |
		Lynn Matteson
				 Posted: Tue Apr 24, 2007 2:07 pm    Post subject: "Florida" Trip |
				I've found that even on short trips around here, that I carry a road
 map of Michigan so I can see an insignificant road where someone
 lives, etc. And even on the charts, you really have to squint to see
 the VERY fine printing that is the road number on even major highways.
 Lynn
 On Apr 24, 2007, at 10:41 AM, kitfoxmike wrote:
     ***snip*****
  	  | Quote: | 	 		   Main thing is, you need to have all the options open and available
  kitfoxmike
  model IV, 1200
  speedster
  912ul
  http://forums.matronics.com/viewtopic.php?p=108902#108902
N369LM |
		kitfoxmike
		kitfoxmike
		Float Flyr
				 Posted: Tue Apr 24, 2007 3:30 pm    Post subject: "Florida" Trip |
				Your points are well taken.
  The point I was trying to make, I believe Lynn has already come to, was
 that the first thing is to be on the frequency.   Technique will come with
 practice....  Practice will come with being on the right frequency.
 Living so far down in the woods that I have to come out to hunt sometimes
 has it's advantages.  Fewer low flying aircraft is one of them.  Airports
 that are not racked and stacked is another.  This is a great place to
 practice!
 Noel Loveys, RPP
 Campbellton, Newfoundland, Canada
 Kitfox Mod III-A, 582, B box, Ivo IFA
 Aerocet 1100s
 noelloveys(at)yahoo.ca
 [quote] --
Kitfox III-A
		Guy Buchanan
				 Posted: Tue Apr 24, 2007 4:20 pm    Post subject: "Florida" Trip |
				At 04:29 PM 4/24/2007, you wrote:
  	  | Quote: | 	 		  This is a great place to
 practice!
 Noel Loveys, RPP
 Aerocet 1100s
 Thank you Noel, and thank you to everyone else who modified their
 signatures to include their Kitfox information.
 Guy Buchanan, Kitfox List Moderator
 San Diego, CA
Deceased K-IV 1200
		Lynn Matteson
				 Posted: Tue Apr 24, 2007 4:55 pm    Post subject: "Florida" Trip |
				Yup, this time they came through loud and clear...thanks, I'll check
 them out.
 Lynn
N369LM |
