DAquaNut(at)aol.com Guest
Posted: Mon Apr 23, 2007 9:20 pm Post subject: rotax 447 longevity |
Guys,
Im trying to make a decision. Your input will help me make the right one. Has any one ran a 447 to 100 hours without a decarbon using pennzoil? Has anyone had a 447 fail due to carbon under the rings before reaching 100 hours while using Pennzoil air cooled exclusively? PLEASE, No oil war! If you have experience That falls in either of these categories, I would like to have your imput, otherwise please dont respond. Thanks in advance.
Ed Diebel (FF 62)
See what's free at http://www.aol.com. [quote][b]
JetPilot
Posted: Mon Apr 23, 2007 9:26 pm Post subject: Re: rotax 447 longevity |
You wont get carbon buildup if you use Seafoam I asked a similar question in the Rotax Forum and got some good information. I did not ask about oil, but I did get a lot of responses on engine life. You might want to look at this thread. It got broken into 4 threads, but some good information if you read them all.
http://forums.matronics.com/viewtopic.php?t=23615
Mike
Kolb MK-III Xtra, 912-S |
ElleryWeld(at)aol.com Guest
Posted: Tue Apr 24, 2007 3:13 am Post subject: rotax 447 longevity |
Ed I recently removed a 447 engine that I ran to 401 hrs without any decarbon, the engine was still running fine I just figured it was better to replace the engine but I didnt use Pennzoil
Ellery with a new engine in Febuary
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Tue Apr 24, 2007 4:46 am Post subject: Re: rotax 447 longevity |
I have over 450 hours on my 447. It's never been overhauled or decarboned. I don't plan on doing anything but inspect the rings and cylinders once a year as I always do. I do use Seafoam and Klotz synthetic oil. I believe in it, but that's just my opinion. I like a reliable engine, and I have had great reliability with this combo.
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
Steve Boetto
Posted: Tue Apr 24, 2007 7:02 am Post subject: rotax 447 longevity |
Ed,
Bryan and I pulled the exhaust on my 447 just before the show. This engine probably had Well over 100 hours on it.
Results, Very clean, almost like new. Rings loose, oily and clean. The top of the piston had a mild coating of tan powder and the EGT probes were tan and clean. Hatch marks looked like new and only a very small line of vertical wear.
I run Pennzoil as recommended by Rotax 50:1 and I Fly at 5900 Rpm with the Factory jets and settings.
Simple and Pie Or is it cake
Steve b
See what's free at AOL.com.
lcottrell
Posted: Tue Apr 24, 2007 10:14 am Post subject: rotax 447 longevity |
| Quote: | Im trying to make a decision. Your input will help me make the right one. Has any one ran a 447 to 100 hours without a decarbon using pennzoil? Has anyone had a 447 fail due to carbon under the rings before reaching 100 hours while using Pennzoil air cooled exclusively? PLEASE, No oil war! If you have experience That falls in either of these categories, I would like to have your imput, otherwise please dont respond. Thanks in advance.
Ed Diebel (FF 62)
Hi,
I put 200 hours on a 447 with no decarbon or need to do so, using only Penn air cooled. No noticeable reduction in power, very little carbon on the top of the cylinders. Take your exhaust off and look at it. Do a compression check. A lot of the carbon buildup comes with running the egt's too low. No one of us can tell you it is alright without being able to look at it ourselves. However if I had not obtained a 503, I would still be flying the 447 without a "decarbon".
Larry , Oregon
| [quote][b]
Steve Boetto
Posted: Tue Apr 24, 2007 10:45 am Post subject: rotax 447 longevity |
In a message dated 4/24/2007 11:03:17 A.M. Eastern Standard Time, N27SB(at)aol.com writes:
| Quote: | I run Pennzoil as recommended by Rotax 50:1 and I Fly at 5900 Rpm with the Factory jets and settings.
Simple as Pie Or is it cake
Steve b
Forgot to add, I pitch the prop for WOT level flight at 6600 + a little.
Snoopy Baxley
Posted: Tue Apr 24, 2007 3:33 pm Post subject: rotax 447 longevity |
Ed Diebel (FF 62)
Hey Ed
Got 166 hours on my 447 and no carbon build-up . I am using seafoam with my Pennz-Oil Air Cooled
Stephen
Firefly
Do Not archive
JetPilot
Posted: Tue Apr 24, 2007 8:31 pm Post subject: Re: rotax 447 longevity |
Ed,
There is a lot of risk opening up an engine that does not need to be opened up. There is always the chance of damaging something, or something being done wrong that could cause problems or a fialure. Bottom line, dont work on an engine that has nothing wrong with it.
Remember, many times manuals are written by lawyers, not mechanics. They may say decarbon every 2 hours, that covers their arse. The dont care and they are not liable if the engine is damaged or put back together wrong by a mechanic... So what do you think they are going to recommend ? Get the picture ?
Mike
beauford
Posted: Wed Apr 25, 2007 12:52 pm Post subject: rotax 447 longevity |
Ed:
Whichever oil you use, if you start noticing any extra carbon, my advice is not to wait... pull that little choke piston out of the Bing and inspect the rubber in the bottom of it to make sure it is still seating... I now change that piston every year just because of the prior carbon problems experienced due to deterioration of that rubber in the base.
Also, speaking of Rotax longevity, the DAR who was here yesterday inspecting airplanes pointed out a serious problem with the Rotax rope starters... can cost a man an engine, possibly even his airplane, with no warning... Mine was broken and I didn't even realize it... There is an item about it , with a photo, posted on the Kolb Forum.
Worth what ye paid fer it...
Beauford
Firefly 076
Brandon, FL
