topglock(at)cox.net Guest
Posted: Sun Apr 22, 2007 2:46 pm Post subject: Baby Blue is back! |
As some of you know, Mary and I attended Sun'N Fun without Baby Blue,
this year. The problem was a power loss and shuddering upon takeoff, at
about 500 - 700 feet. I made all the checks I could think of: fuel
flow/pressure, restrictions in the lines/filters, vents, ignition, prop,
etc. I presented the problem to several at Sun'N Fun and got several
good suggestions. Basically, we narrowed it down to a carb problem,
most suggesting that one of the slides may be stuck. Well, I went out
to the plane, today and checked the slides. No problems there, but,
being a bit anal, I popped the tops anyway and checked them both out.
They both looked like new, with no dirt of any kind. A bit disappointed
that I hadn't found anything obvious, I reassembled the carbs and
reattached everything. One of my last checks was to test the spring
pressure on the cables and there it was. The port carb was fine, but
the the starboard spring was completely loose when the arm was pushed
fully forward. Confident that I'd actually found the problem, I
shortened the spring and cowled her up. Subsequent test flight verified
the fix. Baby Blue has never run so smoothly! A new set of springs
will be on order tomorrow.
For those who run into a rough running engine, I highly recommend that
you add checking the springs to your diagnostic toolbox.
Jeff - Baby Blue
Happily flying again...
Gilles.Thesee(at)ac-greno Guest
Posted: Sun Apr 22, 2007 2:57 pm Post subject: Baby Blue is back! |
Rman a écrit :
| Quote: | The port carb was fine, but the the starboard spring was completely
loose when the arm was pushed fully forward. Confident that I'd
actually found the problem, I shortened the spring and cowled her up.
Subsequent test flight verified the fix. Baby Blue has never run so
smoothly! A new set of springs will be on order tomorrow.
Glad to hear you fixed your problem.
How about dispensing with the springs, and replacing the cables with
piano wire ?
That's the way our project is set up, and it works flawlessly.
Best regards,
Gilles
http://contrails.free.fr
acrojim(at)cfl.rr.com Guest
Posted: Sun Apr 22, 2007 3:36 pm Post subject: Baby Blue is back! |
Hey Jeff
I'm glad you found the problem. It seem's the smallest thngs, create the
largest problems. Sorry I missed "Baby Blue".
Jim Brown
jeff(at)rmmm.net Guest
Posted: Sun Apr 22, 2007 3:44 pm Post subject: Baby Blue is back! |
Glad to hear it. Looks like you can put the carb parts you took home on
the shelf for another day. :•)
It was great seeing you and Mary at Sun-N-Fun. Based on the interest at
the show it looks like Europa in America is back. Go for it Bud!!!!
Jeff R.
N128LJ / Gold Rush... Had a blast flying there, being there and flying
back! Even through the smoke!
On Apr 22, 2007, at 5:45 PM, Rman wrote:
at about 500 - 700 feet. I made all the checks I could think of:
fuel flow/pressure, restrictions in the lines/filters, vents,
ignition, prop, etc. I presented the problem to several at Sun'N Fun
and got several good suggestions. Basically, we narrowed it down to a
carb problem, most suggesting that one of the slides may be stuck.
Well, I went out to the plane, today and checked the slides. No
problems there, but, being a bit anal, I popped the tops anyway and
checked them both out. They both looked like new, with no dirt of any
kind. A bit disappointed that I hadn't found anything obvious, I
reassembled the carbs and reattached everything. One of my last
checks was to test the spring pressure on the cables and there it was.
Jeff - Baby Blue
Jeff Roberts
Eagleville Marketing Group / EMG
488 Beasley RD.
Eagleville TN 37060
615-355-7575 Office
615-406-8651 Cell
615-534-1082 Fax
Please note our name & address change.
josok-e(at)ukolo.fi Guest
Posted: Mon Apr 23, 2007 12:54 pm Post subject: Baby Blue is back! |
Hi Giles,
"How about dispensing with the springs, and replacing the cables with
piano wire ? "
Do you really advise here to get rid of a safety feature?
In case of a broken throttle cable or piano wire, you might end up with a very silent engine. The problem here is too tight routing of a throttle cable. Change the inner cable with a solid wire, and things will improve, probably until, because of the same tight routing the wire breaks sooner then might be expected.
Aircraft carburettors have springs to pull full throttle in case something goes wrong with the linkage. Please be careful when changing the basics!
Jos Okhuijsen
Visit - www.EuropaOwners.org
Posted: Mon Apr 23, 2007 1:24 pm Post subject: Baby Blue is back! |
josok a écrit :
| Quote: | Do you really advise here to get rid of a safety feature?
Jos,
Thank you for responding.
Not all aircraft rely on spring tension to open the throttle against the
friction in the outer case. Some have a push-pull cable and the throttle
valve will stay where it is, should the control fail.
Hundreds of MCRs have been flying for years with a piano wire to replace
the stranded cable and spring, without any problem whatsoever. The
linkage is far far safer with a push-pull control than with a flimsy
stranded cable and puny spring. You can even keep the spring for your
peace of mind !
You mentioned the real cause : inadequate routing of the cable with
tight turns. This leaves you with no option to open the throttle. There
are frequent reports of buckling cable in such setups.
Do not hesitate to reroute the offending cable until it has only large
natural sweeps instead of turns. The usual place for breaking a cable is
at a wrongly rigged portion between throttle lever and cable case. So a
careful design of this portion, and some provision for pivoting is key.
Gilles
Posted: Tue Apr 24, 2007 12:24 am Post subject: Baby Blue is back! |
Hi Gilles,
| Quote: | > Do you really advise here to get rid of a safety feature?
| Quote: | Not all aircraft rely on spring tension to open the throttle against the
We are talking about the Rotax engine, and the Europa. In the Rotax
documentation it is quite clear, why the spring is there and that the
spring should be able to pull the cable. Rotax even offers two methods for
improvent if the supplied spring is not strong enough. Removing the spring
is not one of them. If the valve remains shut on final, when you would
like to compensate for a stronger then estimated head wind you will
discover the reason.
| Quote: | Hundreds of MCRs have been flying for years with a piano wire to replace
peace of mind !
A solid wire is per definition more prone to breaking. In a Europa, that
wire has to go around corners, it can not be straight. Therefore, in a
Europa, where this list/forum is about, it will break sooner then a
stranded cable, especially if routed wrong in the first place. If you
think the factory supplied throttle cable is flimsy, i suggest to try to
break it. By hand. I guess you need about 600 kg of pulling force. I
can't take remarks like that very serious. Advising to remove safety
components on the other hand is very serious business.
| Quote: | natural sweeps instead of turns. The usual place for breaking a cable is
Again, it's all in the manual, this case the Europa Builders Manual. Have
you ever looked at it?
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
raimo.toivio(at)rwm.fi Guest
Posted: Tue Apr 24, 2007 2:33 am Post subject: Baby Blue is back! |
I used original Europa throttle cables
but shortened them and routed
them directly to the carburrettors
(w/o any loops as per manual)
and they seem to work very well.
No binding at all.
In fact I have some difficulties to get enough
friction to the throttle lever to prevent it´s
"auto-moves" and to keep it idle w/o hand.
Raimo
Raimo M W Toivio
OH-XRT Europa XS Mono #417, FCAA permitted for test flights
OH-CVK C172 Skyhawk, reinterioring completed
OH-BLL Beechcraft C45, w radial engines, singing this summer?
37500 Lempaala
Finland
tel + 358 3 3753 777
fax + 358 3 3753 100
gsm + 358 40 590 1450
www.rwm.fi
Posted: Tue Apr 24, 2007 4:26 am Post subject: Baby Blue is back! |
Hi Raimo
As per Nev's advice: Weld the nuts to the metal washers, then the friction washers work. Without that the metal washers turn on the nuts instead.
Jos Okhuijsen
Posted: Tue Apr 24, 2007 5:12 am Post subject: Baby Blue is back! |
Raimo
the "auto move" common on the factory throttle box is because the
friction pads (nylon washers) are not restrained. It's a backlash issue
not friction. I used large pieces of nylon sheet and stopped them
turning. Cured it completely.
Graham
No binding at all.
Raimo
Raimo M W Toivio
37500 Lempaala
Finland
www.rwm.fi
Posted: Tue Apr 24, 2007 8:36 am Post subject: Baby Blue is back! |
Hi! Jos/Raimo/Graham/Duncan/all
Duncan flagged this problem up recently for my interest and suggested
welding however I had some spare Redux mixed from another job and used
it to smudge round the metal washers to nut interface (rather like
fixing the nut in place) and although not yet "used in anger" it does
ensure the friction washers are now working as intended as a friction
clamp.
Bob H G-PTAG
Posted: Tue Apr 24, 2007 11:03 am Post subject: Baby Blue is back! |
Jos,
| Quote: | A solid wire is per definition more prone to breaking. In a Europa,
that wire has to go around corners, it can not be straight. Therefore,
in a Europa, where this list/forum is about, it will break sooner then
a stranded cable, especially if routed wrong in the first place. If
you think the factory supplied throttle cable is flimsy, i suggest to
try to break it. By hand. I guess you need about 600 kg of pulling force.
The problem is, one needs to push, not pull, to open the throttle.
Reports on cable buckling and failure to increase power are not
infrequent. I thought someone was reporting a carb cable/spring trouble.
Hence my suggestion, that has been working for tens of thousand flight
hours.
I took this liberty because I've some experience installing and
operating a 914, and an engine doesn't mind what aircraft it is in, does
it
| Quote: | I can't take remarks like that very serious. Advising to remove safety
The safety component here reads "large and direct sweeps", and "positive
throttle linkage".
| Quote: | Again, it's all in the manual, this case the Europa Builders Manual.
Have you ever looked at it?
Yes sir, especially the engine installation part. Don't recall at the
moment, but if it really suggests installing the throttle cables with
tight turns, I would take it with a grain of salt.
But it is your airplane and and building and engineering decisions are
up to you.
Best regards,
Gilles
Posted: Tue Apr 24, 2007 4:15 pm Post subject: Baby Blue is back! |
Gilles
in an ideal situation I agree push rods are best. Same with flight
controls. Trouble is the Europa's situation isn't ideal for push rods,
hence the second best choice of cables + springs, either of which could
fail. In the EZs it was required that the throttle would still open
without a spring, ie using the stranded cable as a push rod.
Hmmm
regards
Graham
Gilles Thesee wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
Jos,
Posted: Wed Apr 25, 2007 3:51 am Post subject: Baby Blue is back! |
Gilles Thesee <Gilles.Thesee(at)ac-grenoble.fr> kirjoitti Tue, 24 Apr 2007
22:02:17 +0300:
| Quote: | The problem is, one needs to push, not pull, to open the throttle.
Giles, i give up. Without spring yes, but THERE HAS TO BE A SPRING!
My real worry is not about you. But your ill advice might one day kill
somebody. That worries me.
Looking at the high level of your contributions, usually well documented
and investigated, it is surprising how you manage to produce and defend
your last statements. The rest in PM or email please. End of thread for me.
Jos Okhuijsen
Posted: Wed Apr 25, 2007 4:29 am Post subject: Baby Blue is back! |
Jos Okhuijsen a écrit :
| Quote: | But your ill advice might one day kill somebody.
Jos,
The push-pull control cable is not an exotic device from one lister's
troubled mind, bud a widespread and generally trouble free solution
to the throttle actuation problem in an airplane.
Just disagreeing on a point is no problem, whereas affirming a
suggestion is ill and might kill really needs to be supported with hard
facts or proven engineering considerations.
Please don't lose sleep on throttle actuation. The most frequent source
of engine trouble on an experimental is related to fuel supply, not
throttles.
Best regards,
Gilles
mau11(at)free.fr Guest
Posted: Wed Apr 25, 2007 9:55 am Post subject: Baby Blue is back! |
Hi Jos,
During the mod 72 I have some problems with throttle cables. I take a
decision to replace the cable by Stainless steel spring wire diameter 1.5 mm
The curves have big radius and no wire difficluty to slide into her sleeves.
I have now 10 hours without no troubles.
One friend of me use the piano wire since 5 years on the Monowheel with 914
also no problems.
In addition I use graphite grease into the sleeve I introduce the grease
with oil squirt.
Also I note that the carburettors setting is more easy with metallic wires.
Michel AUVRAY
Builder N°145 monowheel 300 hours flight
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com]De la part de Jos
Okhuijsen
Envoyé : mardi 24 avril 2007 10:23
À : europa-list(at)matronics.com
Objet : Re: Baby Blue is back!
Hi Gilles,
peace of mind !
Jos Okhuijsen
Posted: Wed Apr 25, 2007 10:17 am Post subject: Baby Blue is back! |
In addition, before you take a decision to use metallic wire in replacement
of cables, check the radius of yours sleeve cables and install the wire and
re-check the good slip capacity.
[mailto:owner-europa-list-server(at)matronics.com]De la part de Michel
AUVRAY
Envoyé : mercredi 25 avril 2007 19:55
Objet : RE: Baby Blue is back!
Hi Jos,
also no problems.
with oil squirt.
Michel AUVRAY
Okhuijsen
Hi Gilles,
peace of mind !
Jos Okhuijsen
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Wed Apr 25, 2007 5:54 pm Post subject: Baby Blue is back! |
Jos,
I don't wish for this discussion to degenerate into who is right and who is
wrong, but here is a valid data point.
A few years ago a Europa in the US crashed on while attempting a go around.
What happened is that the pilot set himself up for a landing, didn't like
the picture and decided to go around. In his haste he jammed the throttle
forward, the springs didn't take up the cable slack quickly enough, kinked
and jammed. The aircraft stalled at about 2 meters off the ground, landed
heavily and was destroyed.
It was enough for me to sit up and take notice. From that day on I have
always been gentle on pushing the throttle forward. When it comes time to
replace my throttle cables I intend to use solid cables. This is not an
uncommon practice in the aviation industry.
In terms of forum courtesy, in my reading of Gilles contributions and his
WEB site I find that they are extremely well researched and thought out. I
seem to recall that he is a professional aviator an as such would have
exposure to training and flying time that you and I could only dream about.
I for one consider his contributions always worthy of consideration.
Paul
