		Deems Davis
				 Posted: Tue Feb 07, 2006 11:29 am    Post subject: TruTrak Roll Servo install |
				I just received my roll servo. There are two  8.5x11" photocopys/pics
 one of the roll servo and one of the elevator. Are there any
 instructions (there weren't any in the package). I believe I can figure
 out where Most all of the hardware goes, but it would be nice to have
 some reinforcement. Also, I only ordered the servo at this time, the
 cable did not come with it. Was it supposed to? I'm thinking about
 closing out my wings and would like to have the cable to install.
 Deems Davis # 406
 Wings
 http://deemsrv10.com/
		schmoboy(at)cox.net Guest
				 Posted: Tue Feb 07, 2006 11:58 am    Post subject: TruTrak Roll Servo install |
				I didn't receive anything other than the photos and drawings either,
 just gave it a whirl.  Turned out ok.
 The harness doesn't come with it.  You have to either make it yourself
 or purchase one.  I went with the 1/2 harness for the wing that Stein
 makes.  It's a very nice harness and you are able to just order the
 portion needed to close out the wing.
 -Sean #40303 (installing tanks finally)
 Deems Davis wrote:
  figure out where Most all of the hardware goes, but it would be nice
  to have some reinforcement. Also, I only ordered the servo at this
  time, the cable did not come with it. Was it supposed to? I'm thinking
  about closing out my wings and would like to have the cable to install.
  Deems Davis # 406
  Wings
		Tim(at)MyRV10.com Guest
				 Posted: Tue Feb 07, 2006 12:06 pm    Post subject: TruTrak Roll Servo install |
				Cables don't come with the servos. You can build them or
 SteinAir sells them prebuilt.
 Use the 2.25" rod on the roll servo.  The install is
 pretty easy if you have the original install instructions
 from their website.
 I don't remember the pitch servo rod length, but that
 install uses an updated bracket (you ditch the one that
 came with the kit) that attaches using the bellcrank
 mounting screws/bolts.  That install was the easy one of the
 two actually.
 I still have to put my roll servo rod arm on now that I'm
 all rigged up.
 Here's a couple of useful links though:
 http://www.myrv10.com/files/TruTrak/RV10_Roll_Servo_Torque_Upgrade.jpg
 http://www.myrv10.com/files/TruTrak/RV-10PitchInstall_old_original.pdf
 http://www.myrv10.com/files/TruTrak/RV-9RollInstall.pdf
 Tim Olson -- RV-10  #40170
 DO NOT ARCHIVE
 Deems Davis wrote:
  Deems Davis # 406
  Wings
		dmasys(at)cox.net Guest
				 Posted: Tue Feb 07, 2006 2:00 pm    Post subject: TruTrak Roll Servo install |
				Having just done this the day before yesterday (and I don't even have the roll servo yet for the -10, but do have a TruTrak in my -7A) I can say that if you are handy at all with a soldering gun, you can make the roll harness in about an hour with:
 - a female DB9 connector from Radio Shack (or Digikey)
 - seven half inch long pieces of 1/8 inch diam heat shrink tubing
 - seven pieces of approx 8 ft long wire (2 that are 20AWG and 5 that are 22 AWG, or all 20 AWG if that's all you have)
 - An 8 position Amp Mate N Lok connector, or another DB9 connector for the wing root.
 At the servo location, solder one end of the wires (pins 1 and 9 are the larger 20 AWG wires) to the pins on the DB9 connector, per the wiring diagram listed below.  Slide a little piece of shrink tubing over each pin as it is soldered.  Thread the wires through the snap bushings to the wing root, and attach the other connector there.  Viola.  Your done.  Testing it (other than a continuity test on each wire) comes months later...
 The plug wiring diagram is on page 13 of the installation manual, which is at:
 http://www.trutrakflightsystems.com/documents/DigiflightIIinstall.pdf
 -Dan Masys
 40448
  	  | Quote: | 	 		   From: Deems Davis <deemsdavis(at)cox.net>
  Date: 2006/02/07 Tue AM 11:28:19 PST
  Subject: TruTrak Roll Servo install
  Deems Davis # 406
  Wings
		Deems Davis
				 Posted: Tue Feb 07, 2006 5:00 pm    Post subject: TruTrak Roll Servo install |
				Wow Dan, Thanks for the instructions! sounds like it shouldn't be too
 much of a hassle and another 'learning experience' I think I'll give it
 a try. The servo install went pretty straight forward, (didn't end up
 with any left over parts!)
 Dan Masys wrote:
 -Dan Masys
 40448
 >To: rv10-list(at)matronics.com
 >Deems Davis # 406
 >Wings
		LarryRosen
				 Posted: Tue Feb 07, 2006 5:30 pm    Post subject: TruTrak Roll Servo install |
				Deems,
 There are a bunch of photos of the install on my website at
 <http://lrosen.nerv10.com/Construct/Log/Wings/RollServo/index.html>
 Tim has the information on the bolts and washers that are required.
 Don't forget the over sized washer to keep the bearing in place if it
 ever fails.  Get some different length AN-3 hardware.  As always the
 length you want is the length you do not have.
 Larry
 Deems Davis wrote:
  Deems Davis # 406
  Wings
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
