RSamuelson(at)aol.com Guest
Posted: Fri Apr 20, 2007 4:27 pm Post subject: Govenor oil leak |
I have a new O-360 and the Jihostroj prop governor. I have a persistent oil leak that appears to be coming from the gasket between the governor and the engine. I changed the gasket once and my mechanic changed it a second time. The leak seems to be at the top of the joint and oil dribbles on down various hoses and wires and exits at the lower cowl.
Anyone else have the problem?
Roy Samuelson
RV7A at Oakland CA
See what's free at AOL.com.
dale1rv6(at)comcast.net Guest
Posted: Fri Apr 20, 2007 8:20 pm Post subject: Govenor oil leak |
I have the same equip, installed 14 months ago. I believe there was a special note with governor saying I may need a thicker gasket to avoid internal contact of metal parts that would prevent proper seal and improper friction. Can you assemble gently without the gasket to get an idea of how much gasket space you have before anything bottoms out inside? In my case this gave the appearance that the gasket they shipped was adequate. It has worked ok for 14 months and 200 hours.
Good luck as always,
Dale
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of RSamuelson(at)aol.com
Sent: Friday, April 20, 2007 8:27 PM
To: rv-list(at)matronics.com
Subject: Govenor oil leak
Roy Samuelson
RV7A at Oakland CA
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
Jerry Cochran
Joined: 10 Jan 2006 Posts: 111 Location: Wilsonville, OR
Posted: Sat Apr 21, 2007 7:29 am Post subject: Govenor oil leak |
I had the same problem with MT governor. First, tightened nuts at upper end of torque limits. No joy. Removed governor, gasket looked fine, cleaned everything, put thin film of Red RTV on surfaces, torqued using "armstrong method". No more leaks.
HTH.
Jerry Cochran
RV-6a N18XP 11 hrs.
| Quote: | Time: 05:27:49 PM PST US
Roy Samuelson
RV7A at Oakland CA |
martin(at)gbonline.com Guest
Posted: Fri Apr 27, 2007 6:19 pm Post subject: Govenor oil leak |
Try Radiator Specialty "Tite Seal Medium" gasket sealant. Available (at) Wicks and others Etc.
Dick Martin
RV8 N233M
the fast one
Posted: Sat Apr 28, 2007 4:03 am Post subject: Govenor oil leak |
Hi Roy-
| Quote: | I have a new O-360 and the Jihostroj prop governor. I have a
| Quote: | Anyone else have the problem?
Quite a few. There is a thread on this in the archives, but some of the lycs have an issue with blowing that gasket and dumping all the oil overboard. The solution seems to be 2 gaskets with a metal plate sandwiched between. Check the list of applicable engines....
Glen Matejcek
flamini2(at)comcast.net Guest
Posted: Sat Apr 28, 2007 4:14 am Post subject: Govenor oil leak |
Check for a hairline crack at the hose fitting, i had it on an 0-360 due to overtightening of the tapered pipe thread.
Dennis in Chicago
