whadath(at)rogers.com Guest
Posted: Thu Apr 26, 2007 12:01 pm Post subject: Purchase of an RV 10 Kit |
Fellow Builders
I am a new subscriber to the RV 10 list. I have built and am now flying a F1 Rocket from a parts kit. I have a wife and 2 children who have been enjoying the flying so much that they are now saying that I must start on a 4 seater. It looks like the RV 10 is the one for me to build.
I have decided to go the QB route this time. It looks like the options are Electric trim, which I think may be a good idea for a side by side aircraft.
I wonder about the external steps, due to drag. Anybody have input or experience on this?
Map box. I would think this is a good idea and since I will go with a VFR panel I would think there must be lots of room on the panel.
Fresh air vent? Any input here?
Are there other options I should consider?
Is anybody aware of a QB kit out there in need of a home?
I hope I will be able to contribute to the list and I look forward to the project.
I am located at CYKF in Kitchener, Ontario.
Thanks.
Wayne Hadath
http://www.justplaneworks.com/
Posted: Thu Apr 26, 2007 1:17 pm Post subject: Purchase of an RV 10 Kit |
You might be choosing the most significant option of all - a VFR '10.
I've been lurking here for a year and it seems that everyone is building
an IFR spaceship (including yours truly).
If you were to build a VFR day cruiser you might have one of the fast
built, nicest flying '10s around.
The trick may be to avoid some of the options.
Bill "loading up my QB wings with goodies" Watson
(there are probably plenty of VFR '10s being built....)
BARBARA HADATH wrote:
Fellow Builders
build.
aircraft.
experience on this?
the project.
Thanks.
Wayne Hadath
http://www.justplane <http://www.justplane/>works.com/
LarryRosen
Posted: Thu Apr 26, 2007 3:50 pm Post subject: Purchase of an RV 10 Kit |
Answers to your questions below:
Larry Rosen
RV-10 #356
<http://lrosen.nerv10.com>
Fellow Builders
build.
aircraft.
Electric elevator trim is standard. There is an option for aileron
trim, and DIY options for rudder trim. There are no manual trim options
experience on this?
External steps are included with the kit. It would be difficult to
climb up into the plane without the steps.
With a VFR panel you could probably put in 2 map boxes.
Standard are 2 vents up front and 2 vents for the rear passangers
Accuracy Avionics <http://www.accuracyavionics.com/> has an overhead
console that adds air vents.
Lots, for the tail kit they are limited to static ports and rudder
control fairings. Just get started, stay on this list, check out the
builders web sites and have fun building. If you could build a 4
(without pre punched skins, the 10 will be a breeze).
the project.
Thanks.
Wayne Hadath
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
edrv(at)cox.net Guest
Posted: Fri Apr 27, 2007 7:08 am Post subject: Purchase of an RV 10 Kit |
Larry, I have a 10 qb wing /fuse/ tail kit also --just finished my 8A, just thinking about not continueing tth 10, I have a 540 --it doesn't have to go with it-- call me if interested 479 629 1986 Ed 479 629 1986 Thanks ---- Larry Rosen he <LarryRosen(at)comcast.net> wrote:
Larry Rosen
RV-10 #356
> Fellow Builders
> build.
> aircraft.
> experience on this?
> the project.
> Thanks.
> Wayne Hadath
