hugs.mackenzie(at)sympati Guest
Posted: Sun Apr 29, 2007 3:50 pm Post subject: Ignition Module Wiring - revisited |
I have finally decided to change my secondary ignition module to the TP45 from the Stratus supplied unit. I searched the archives here but did not find any definitive info on the coding of the three wires coming from the Stratus supplied flywheel pick-up.
Here is what I found in the archives:
Coil + goes to TP45 B terminal
Coil – goes to TP45 C terminal
Magnetic pick-up + (usually a red wire) goes to TP45 G
Magnetic pick-up – (usually a white wire) goes to TP45 W
The magnetic pick-up I have has three wires, Red, White and Black. The suggestions above from the archives did not work. Can some one using this Stratus supplied pick-up tell me which one is which? I assume the third wire is +12v.
Hugh Mackenzie
CH601HDS
| | - The Matronics Stratus-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
Posted: Sun Apr 29, 2007 5:27 pm Post subject: Ignition Module Wiring - revisited |
Hi Hugh,
I looked at my ignition this evening and find three wires red black and
green coming from the pickup to a plug connected with the solid state
module that goes with the flywheel pickup. From it, two wires red and
black come from the solid state box to my B coil, red to the black with
white stripe coil wire and the black going to the blue coil wire. I'm
not sure that you could use the TP45 in replacement of the solid state
box provided by Stratus.
Hugh & Sherry MacKenzie wrote:
third wire is +12v.
Hugh Mackenzie
CH601HDS
frank.hinde(at)hp.com Guest
Posted: Mon Apr 30, 2007 6:59 am Post subject: Ignition Module Wiring - revisited |
Yes this is the first time I have heared of somebobody trying this.
Besides, last time I was standing in Mykal's shop there was a little
pile of flywheel pickups that ther labelled "bad" So I would not be
surprised if using the TP45 is not replacing the unreliable part anyway.
The Twin TP 45 system builds two subaru pickups into the distributor,
each of which drive a TP 45 (same as the GM 4 pin module).
Of course you need a second pickup. I happen to have one if you need it.
Frank
Posted: Mon Apr 30, 2007 4:32 pm Post subject: Ignition Module Wiring - revisited |
Thanks to everyone for the responses so far.
Is the second pick-up people are putting in the distributor the same as the
original (i.e. something I can pick-up at NAPA)?
Also, is the second pick-up easily installed in place of the original
ignition module, or is there some mechanical work that needs to be done?
I am some what reluctant to replace the primary ignition since it has been
running fine for years, hence my trying to get the TP-45 working with the
existing flywheel pick-up. However, I am not exactly sure what part of the
secondary ignition is actually causing the problem. If a second pick-up
installs easily in the distributor, then I guess that might be the simplest
path.
Thanks, Hugh
Posted: Tue May 01, 2007 5:54 am Post subject: Ignition Module Wiring - revisited |
Hugh,
The second pickup can be had as an LX600 from NAPA Auto Parts. They're
about $60.00, but very durable.
The addition of a second pickup in the distributor requires removal of
the Nippondenso module (replacing it with two TP45 NAPA modules)
locating them on the firewall. The disk that holds the pickup has to be
removed from the distributor and drilled and tapped for the second
pickup or a new disk made for the installation. Both pair of wires are
lead back to the firewall to the TP45s. Each has a IC107 coil mounted
on the firewall and the bolt pattern for the coil can support the TP45s
as seen in the links below.
http://www.macsmachine.com/images/electrical/full/TP45mounts.gif
http://www.macsmachine.com/images/electrical/full/dualdizzy2.gif
If you decide to do the dual ignition pickup within the distributor, let
me know and I'll send you the information for
the disk size, material, locating the holes and tap data. The disk is
fussy work but not that hard to do. If you need a disk
I can turn one for you if you decide this is what you need.
Larry McFarland
path.
Thanks, Hugh
