Cable Tension
lehmans(at)sympatico.ca
PostPosted: Sat May 05, 2007 5:40 pm    Post subject: Cable Tension Reply with quote
Sounds like a common error; my Traveler had both the elevator and aileron
cable tension at twice the spec value. (Rudder cable tension was OK but,
since springs limit the tension, it can't get set grossly wrong.)
Mike
I just finished an annual on a Tiger that had the elevator cable tension set
way to high. I think they adjusted it by feel, comparing it to the aileron
cables possibly.
Cliff
I'm doing an annual on a Tiger that had the braces for the horizontal
replaced last year. The shop that did it is one of the best. However,
the cable tension to the elevator was over 90 lbs (off the scale on my
tensioner).
