irampil(at)notes.cc.sunys Guest
Posted: Fri May 04, 2007 7:32 am Post subject: Re Coolant Coice |
Pretty pictures Ron but the fires do not illuminate the situation
regarding coolant. The fact that it easily burns is no surprise.
Rotax made an engineering mistake with Evans and is backing off.
PFA is making the situation more confusing with a totally mindless
directive.
For safety, experimental a/c builders need to understand the facts,
rationales, and theorys, and to know which is which.
Unlike the the antique powerplants in certificated a/c, Rotax engines
have a significantly different metallurgy - they are made of aluminum
alloy. Fact. This alloy anneals just below 300F. That is to say it
softens and the cylinder heads will begin to warp with temperatures
exceeding 275F for a length of time. Fact, see Line maint manual for
temp-time tolerance curve. This temperature limit is more than 100F
below routine lycosaurus CHT. Exceeding the time-temp limits buys you
a tear down and Rockwell hardness testing of heads.
Liquid coolant is required to keep Rotax CHTs in the required range.
The coolant must provide an efficient path to dump combustion and compression heat to preserve the temper of the aluminum. Evans is far less
efficient at heat transfer then water-based coolant.Fact. The "value" of
Evans is its higher vapor pressure. Why? As fluids approach their boiling
point they start to nucleate small bubbles (look at a pot of near-boiling water). These bubbles insulate the walls of the coolant path from
efficient heat transfer from the metal to the liquid.
Evans will not form as many of these bubbles at operating temperature
as standard coolant. It will nontheless let heads rise closer to the
annealing temp because it can't carry away the heat as fast even
without the bubbles.
A new solution to continue using water based coolant is to change the radiator
cap to 1.2 atm from 0.9. This will keep the vapor bubbles from forming in the
old coolant and lead to altogether better heat sinking the cylinder heads.(Theory)
There is a new SB for kit manufacturers to measure coolant temperature or to
measure the extent of the gradient between the standard CHT measurement point
on the outside of the head and the coolant outflow point. The temperature of the
coolant exiting the head, going to the radiator is always hotter and more
closely related to the max temp inside the head than the CHT sensor. The coolant
temp must not exceed 275F and if the gradient to the true internal temp is not
known, then a worst case assumption leads to the new max (old style) CHT of 248F
As for the flammability and the PFA, every other fluid forward of the firewall is
flammable. One more adds no significant added risk. Stemme had a poorly designed
coolant/exhaust system which lead to melting of coolant lines. This, I submit was the
problem, not the flammability of the coolant! It could have just as easily been
a gas or oil line.
Temperature shield hoses and keep the engine aluminum cool!
Check out the new intrinsically heat-shielded fuel line hoses in the 900 series
now shipping. Nice clean new design to deliver fuel to mechanical pump and thence
to carbs with new crimp fittings, a double banjo line splitter, etc.
Ira N224XS
Fresh from Dean Vogel's Rotax Engine course.
mikenjulie.parkin(at)btop Guest
Posted: Fri May 04, 2007 8:09 am Post subject: Re Coolant Coice |
I have just drained the Evans stuff out of my 914 - putting it in the engine in the first place was not my best ever decision. What is the 'totally mindless PFA directive' ??
Have I missed something??
regards,
Mike
Posted: Fri May 04, 2007 8:46 am Post subject: Re Coolant Coice |
irampil(at)notes.cc.sunysb.edu a écrit :
path from
Ira and all,
I'm afraid it is the other way round : nucleate boiling help reject
tremendous amounts of heat from the engine.
Phase change from liquid to vapor absorbs several hundred times more
heat than just raising the coolant temperature just another degree, and
helps convection. This was clearly established by NACA researchers
during the '40s.
See Contrails
http://contrails.free.fr/engine_liquide_refroid.php (only in French at
the moment)
Scroll down to the NACA reports.
Also some basic info at :
http://www.tpub.com/content/doe/h1012v2/css/h1012v2_62.htm
Please note that we are speaking of nucleate boiling, and not of the
"boiling crisis", which is the transition from nucleate to "film
boiling". It is film boiling which tends to isolate the hot walls from
the coolant.
Best regards,
Gilles
Posted: Fri May 04, 2007 9:50 am Post subject: Re Coolant Coice |
Hello Ira
The info provided about flammable liquids was not a full discussion on the
Pros and Cons of Evans, but was results about the flammability which I
wanted to see and feel actual results for myself before I went flying with
it in my cooling system. The results were just about what I expected. I
added a test to see if 100LL in fact does ignite as easily as Mobil 1 when
put on a hot muffler (it does not, Mobile 1 ignites a lot easier).
There are Pros and Cons about Evans. I spent several days in contact with
folk at Evans when Rotax first came out with recommendation. I have posted
results and my conclusion in the past, but will restate:
The folk at Evans were a bit shocked that Rotax made such a quick and bold
jump with so little testing in their opinion
It is true that Evans can run with a Zero pressure coolant pressure cap,
but that is when the system design has cap located on the vacuum side of
the water pump. The Rotax 9xx has the pressure cap on the pressure side of
the water pump. You should not run a Rotax 9xx with a zero pressure cap.
On my 914 install, I will run Evans with a .9 bar cap.
The ability of Evans to transfer heat is not as good as water, or quite as
good as a 50/50 mix of water and Ethylene Glycol. Evans on most of their
applications recommend increasing flow rate of water pump or increasing
radiators ability to dump heat to compensate for this. I don't know of a
high flow Rotax water pump for use with Evans, but may be a good idea??
Evans also knows that Evans is more viscous and the radiator should not be
too restricting, or it needs to be replaced with one less restrictive, I
have the info of core requirements if anyone needs, but the Stock Europa
Radiator seemed OK when I measured it.
Evans will run a bit hotter than a 50/50 mix due to a poorer ability to
carry away heat (Perhaps 10 degrees F, what I have read anyway about
Europa Monowheels). I am willing to accept this downside. I am installing
a Rotax cooling air baffle that I think will just bout negate the slight
higher temp Evans will run over a 50/50 mix.
On a 914 with intercooler, and a monowheel to restrict cooling flow on the
ground, boil overs on ground and in the air are not a welcome occurrence.
In addition when you are making some BTUs at altitude (an intercooled 914
can more easily do than normal aspirated), remember that the pressure cap
for the cooling system is not altitude compensating, thus at altitude you
will have less pressure in the system than at sea level, and less air to
cool things. (Side note, this lesser pressure at altitude and higher oil
temperature can cause oil tank to not condense foaming oil and a very
undesirable oil pressure drop can occur, same goes for 912 or 912S). Even
though you could have an overall acceptable coolant temp and cylinder head
temp there can be pockets of boiling coolant that have very little ability
to carry away heat and can cause hot spots a gauge will not reveal. Evans
has a much higher boiling point, and even if you did get it to boil, it
still will carry away a significant amount of heat (Think it is 50% ??) of
what it is capable of when not boiling.
Evans does not have to be changed, and will not hurt aluminium. Use of
Silicone coolant and radiator hoses, should negate having to replace every
5 years, not a trivial job.
Should a leak occur where pressure was reduced, Evans would conduct at a
lower pressure better than a boiling 50/50 mix.
If you developed a coolant leak, landed and repaired and could not find
Evans, You could mix up to about half with Ethylene Glycol to get you
home, but then should flush and replace with Evans 100% (according to
Evans Tech.).
Evans about a year ago would test your coolant (for free) to make sure it
is still up to snuff (CT office).
I fully agree that keeping the heads of a 9xx cool so as not soften them
is a worthy effort. If I find that there are conditions that temporary put
motor hotter than I care for, a water spray onto radiator could help with
that, no matter Evans or 50/50. I am also going to try and optimize
cooling intake and exhaust for radiator, intake no larger than needs to
be, exhaust adjustable cowl flap (Gilles has great info on cooling
dynamics). If I see that things are not quite acceptable, an easy thing to
try a 50/50 mix (I also have a 1.2 bar cap).
Another subject, but keeping the oil hot enough, and warming it up before
you make some BTUs is a worthy effort. Especial desirable when performing
a restart after soaring. I am installing a Mocal oil thermostat with -8
fittings. It always allows a path to and from oil cooler, so if it failed
with valve opened or closed, you would never starve for oil (like some
others I looked at). What the Mocal does, is allow a easier bypass path
internal so instead of all the oil going through the cooler, for the most
part takes the easy path. there is however some oil going through the
cooler at all times. I will plumb my oil system with Aeroquip 498 and 598
(same hose, black or blue) and use mostly Aeroquip steel crimp on
fittings. Will use McMaster 90 degree stainless large radius thin wall
barbed tube fitting for bend needed. The 498 and 598 have same ID as
FC332, has a slight tighter bend radius ability without kinking (slight
larger OD, not much), and I like the crimp on steel fittings better than
the brass or aluminium push on barb fittings. The ID is very large for a
-8 hose, and is good for 300F on inside and 250F with air.
Ron Parigoris
Posted: Fri May 04, 2007 10:48 am Post subject: Re Coolant Coice |
Ron,
While I would not have a problem with Evans coolant on a system designed to
operate with it. However, the original Europa installation was not designed
to operate with Evans.
With G-JULZ, Rotax 914 monowheel, it is quite obvious that the cooling
system is working close to its maximum capacity during a sustained climb on
a summers day.
With the original configuration (oil cooler directly behind the radiator) I
had such a problem with 50/50 during a fairly slow speed climb in the Swiss
Alps behind Dave Buzz. In the end, I had to leave the formation and fly
back down the valley at an increased speed to get the temperatures back
under control.
Once back on the ground under the advice of Andy Draper, I attacked the
lower cowling with a hacksaw to take off a lip that I had misguidedly left
on. That made a slight improvement.
When I arrived back in UK, I lowered the oil cooler to the optional
position. From that point on, G-JULZ never had a temperature problem even
in the most sustained climbs to altitude.
On the introduction of Evans fluid, the temperature problems in the climb
returned. On a summers day it was necessary to level off and accellerate at
about 3,000ft to keep the temperatures within limits.
With both Evans and 50/50, in the cruise the temperatures will drop to 50
to 60 degrees C. Which is why I am just modifying the air duct exhaust with
a temperature controlled 'cowl' flap.
Incidentally, I had considered using an oil thermostat, but gave up on the
idea when I read on this site that the oilstat mod did not work too well.
The bottom line is that if you chose to use Evans coolant on the standard
Europa configuration, don't be surprised if you experience unnecessarily
high CHT temperatures.
regards,
Mike.
josok-e(at)ukolo.fi Guest
Posted: Fri May 04, 2007 11:19 am Post subject: Re Coolant Coice |
Hi Folks,
Maybe i can help and add some more fuel for thought on this burning issue.
My coolant system has an electric heater in it, and is filled with NPG.
Reasons are that cooling is not the problem in my region, heating is.
To my surprise the coolant liquid sizzles in that heater, so it is
micro-boiling.
That while i expected it not to form bubbles on the element.
If the stuff micro-boils at the heater, it will certainly do the same in
the cylinder heads.
This experience imho nolliefies the argument that NPG would prevent
micro-boiling.
The only remaining advantage for me would be that it would not pressurize
the system, preventing blow-outs.
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http://www.europaowners.org/kit600
mau11(at)free.fr Guest
Posted: Fri May 04, 2007 11:55 am Post subject: Re Coolant Coice |
Hi all,
Just for information, since more five years we use a volkwagen coolant
liquid G012 (colour is pink).
This is perfect,there is no limit time to use, no corrosive, and
auto-obturating if you have small leak.
Many users of Rotax 4 strokes family use this liquid on ultralight
airplanes.
-----Message d'origine-----
De : owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com]De la part de Mike Parkin
Envoyé : vendredi 4 mai 2007 20:48
À : europa-list(at)matronics.com
Objet : Re: Re Coolant Coice
<mikenjulie.parkin(at)btopenworld.com>
Ron,
a summers day.
under control.
regards,
Mike.
Posted: Fri May 04, 2007 3:20 pm Post subject: Re Coolant Coice |
Gilles
I think you have pointed out the difference between theory and testing.
Theory should be used to explain observed facts not the other way round.
The latent heat of vaporization of water is 525 calories per gram,
whereas it only takes one calory to raise the temperature from 99 deg.
to 100, boiling point. It won't boil until it gets the other 524 calories.
Thanks for your clear thinking. It made me think again
Graham
Gilles Thesee wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
> path from
Ira and all,
during the '40s.
See Contrails
the moment)
the coolant.
Best regards,
Gilles
Graham Singleton
Tel: +441629820187
Mob: +447739582005
nwcmc(at)tiscali.co.uk Guest
Posted: Fri May 04, 2007 10:46 pm Post subject: Re Coolant Coice |
| Quote: | Which is why I am just modifying the air duct exhaust with
a temperature controlled 'cowl' flap. <
I have been down this route on 2 occasions once with a Classic cowl and
once with an XS cowl. It is normal to control the exhaust rather than
the inlet air which is what I did in both cases. Even with the outlet
for the XS cowl being fully closed it made little difference to
controlling either oil or coolant temperature. The only flap I have seen
work really successfully controls the inlet air. The design uses a flap
which can be raised to close off airflow whilst airborne or lowered on
the ground to encourage increased airflow.
Nigel Charles
karelvranken(at)hotmail.c Guest
Posted: Sat May 05, 2007 1:11 pm Post subject: Re Coolant Coice |
Posted: Sat May 05, 2007 2:04 pm Post subject: Re Coolant Coice |
Nigel, Ron, Gilles, Ira and all,
For instance I much appreciate your valuable interventions.
Using water/glycol or Evans was and still is a choice
But let's make a statement. We have the performing engine and we have the
fixed configuration with cowlings and radiators. The engine has three
cooling elements: air, oil and coolant. Oil and coolant temperatures are
regulated by air flow thru the radiators. Air flow is dependent of ducts,
speed and propeller wash. Not so simple as at a given outer temperature all
is in the limits when cruising at more then 110 knts. The discussion about
Evans or water/glycol may give a difference of about 10°C. But for the same
configuration with a difference of temperature between winter and hot summer
of 40°C and a take off speed of 60 knts at full power creates the problems.
With 3 liters of oil and 4 liters of coolant we have no margin and no
buffer. Until we don't find to regulate and control from the cockpit this
temperatures we canot climb at the 1000'/min rate in every season. Let us be
humble and say that the cowlings are of a very poor design. But we build an
experimental airplane and we are proud of it. I think that I can find in
Ron's approach a stimulation to continue the experiment by making several
small changes until we succeed. And for my results you still have to wait.
Kind regards,
Karel Vranken, # 447 XS mono 912ULS Airmaster AP332 now only 35 hours.
Posted: Sat May 05, 2007 3:01 pm Post subject: Re Coolant Coice |
Karel
just one further thought, you should make only one modification then
test before you make the next mod, then you have an idea which mod works
and which doesn't
Graham
karelvranken wrote:
<karelvranken(at)hotmail.com>
I think that I
can find in Ron's approach a stimulation to continue the experiment by
making several small changes until we succeed. And for my results you
still have to wait.
Kind regards,
Posted: Sun May 06, 2007 2:25 pm Post subject: Re Coolant Coice |
Graham,
That's the way I am thinking. Thank you for your dedication.
Karel Vranken.
