Jaybannist(at)cs.com Guest
Posted: Tue May 08, 2007 1:25 pm Post subject: Corvair Mount |
Corvair Guys:
I finally received a motor mount from WW today. I tried to fit it up to the mounting bolts and found that the bolts won't go through the spool pieces. Are they supposed to be driven; or are the tubes supposed to be reamed for a fit?
Jay in Dallas
Gig Giacona
Posted: Tue May 08, 2007 1:38 pm Post subject: Re: Corvair Mount |
When I mounted mine all it took was a light to medium tap with a rubber mallet.
Will the bolts of the same size slide into the mount unmounted? Or is it a positioning problem?
601XL Under Construction
Posted: Tue May 08, 2007 1:47 pm Post subject: Corvair Mount |
Is it a question of alignment or actual diameter? In other words will a
loose bolt fit into the spools? I would *not* force the bolt in. I suspect
the problem is a combination of alignment and distortion of the spool during
welding. Unfortunately (as you probably know) William is on vacation until
the middle of the month.
I would do two things: if it won't remove too much metal ream them out so
that a free bolt will fit in. Then if there are alignment problems loosen
the bolts that hold the motor mount brackets to the longerons, bolt the
mount and then retighten the brackets. If you do this you may want to
replace the nylon-insert locknuts on the motor mount brackets.
-- Craig
Posted: Tue May 08, 2007 2:57 pm Post subject: Corvair Mount |
Corvair Guys,
Thanks for the help. I ran a 3/8" drill bit through each of the spool holes. All except one now let the bolt slip all the way through. I think the holes were just "dirty." One still gets tight about three-quarters of the way in. I think that spool tube probably got distorted during welding. I also think that I can get that one installed with just a light amount of force with a rubber hammer.
Thanks again for the help
Jay in Dallas
