kheindl(at)msn.com Guest
				 Posted: Tue May 08, 2007 4:33 pm    Post subject: Melted silencer |
				Hi Ron,
 The picture would be a problem. Th exhaust is installed now, and the damage
 is almost impossible to see because there is very little clearance. One can
 see the damage to the aluminum duct. The affected area must have vaporized,
 as there is now an indentation. On the underside there are pinhead size
 blisters, but it didn't burn right through.
 I am quite sure now that this was caused by electrical discharge(s). The
 duct with the radiators is completely isolated from the engine and is
 probably acting as a giant capacitor, which then discharges to the nearest
 metal object above. What causes the  buildup of static ? I guess I will
 never know. This is potentially very dangerous, and if it happened to me, it
 could happen to anyone else.  Someone from the factory should take
 aninterest in this.
 The best I can do is run a wire between duct and engine to eliminate any
 static discharges.
 Karl
 [quote]From: "Ronald Parigoris" <rparigor(at)hotmail.com>
 To: kheindl(at)msn.com
 Subject: RE: Lost message
 Date: Tue, 08 May 2007 18:13:18 -0400
 Hello Karl
 If you can, I would like to see a picture. On teflon hoses, static created
 from liquid would damage the hose:
 http://www.sacskyranch.com/statichose.htm
 I know that airplanes with rubber boots on the lead edge of the wing can
 get full of pinholes from static discharge.
 I set up to fly my hot air balloon once, and was close enough to the guy
 next to me that our balloons were rubbing back and fourth that has happened
 many times before. This time the thermocouple wire that runs from the top
 of the balloon to the basket was close to the contact areas of the
 balloons. Static jumped onto the wires, and was discharging to a fuel tank
 not too far from the wires in the basket!
 You have exhause running through the exhaust, not beyond the realm of
 possability that the exhaust is poorly grounded and seeking ground at that
 point? I don't have a good picture, but air flowing and charging something
 could cause static as well.
 Try to change nothing, go flying and see if you can measure any voltage
 potential between the 2 parts.
 Is it possable that somehow the ignition is not well grounded to the motor,
 and jumping to ground here? I had a Kawasaki F5 and F9 that used electronic
 ignition and surface gap plugs. The surface gap plugs had a gap in the
 porecelin to allow no leakage from tip. What I am getting at is if ignition
 is finding ground where you are having problem??
 Please let me know resolve.
 Sincerely
 Ron Parigoris
 >From: "Karl Heindl" <kheindl(at)msn.com>
 >To: rparigor(at)hotmail.com
 >Date: Tue, 08 May 2007 20:57:06 +0100
 >>From: postmaster(at)mail.hotmail.com
 >>Subject: Delivery Status Notification (Delay)
 >>Date: Tue, 8 May 2007 06:07:45 -0700
 >>This is an automatically generated Delivery Status Notification.
 >>THIS IS A WARNING MESSAGE ONLY.
 >>YOU DO NOT NEED TO RESEND YOUR MESSAGE.
 >>Delivery to the following recipients has been delayed.
 >>        rparigor(at)suffolk.lib.ny.us
 >><< attach3 >>
 >>To: rparigor(at)suffolk.lib.ny.us
 >>Subject: Re: Melting silencer
 >>Date: Tue, 08 May 2007 01:48:59 +0100
 >>Hi Ron,
 >>Thank you for your interest. Unfortunately no pictures but it is a
 >>standard XS fwf installation (not 914).
 >>The vertical distance between silencer and duct is about 10mm. Very
 >>difficult to see when everything is installed. If I hadn't seen it with
 >>my own eyes I wouldn't have believed it. I can only think of electricity
 >>causing that intense localized heat. Of course I don't know when it
 >>happened or whether it is happening all the time. I won't be able to fire
 >>up my engine for another 2 weeks.
 >>I am taking a wild guess that if I connect a ground wire to the duct it
 >>will fix the problem.
 >>There must be someone out there who can explain this phenomenon.
 >>Karl
 >>>From: <rparigor(at)suffolk.lib.ny.us>
 >>>To: "Karl Heindl" <kheindl(at)msn.com>
 >>>Date: Mon, 7 May 2007 23:20:04 -0000
 >>>Hello Karl
 >>>Do you by chance have any pictures of overall location and close up of
 >>>damage?
 >>>Ron Parigoris
 >>>On Mon, May 7, 2007, Karl Heindl <kheindl(at)msn.com> said:
 >>> > No, it was a little forward of that. Think of the temperatures. What
 >>>is
 >>> > stainless steel melting point ?
 >>> > And if the heat came from the inside, why is not burned right through
 >>> > Karl
 >>> >>From: "Duncan & Ami McFadyean" <ami(at)mcfadyean.freeserve.co.uk>
 >>> >>Reply-To: europa-list(at)matronics.com
 >>> >>To: <europa-list(at)matronics.com>
 >>> >>Date: Mon, 7 May 2007 20:52:44 +0100
 >>> >>Was the "heat-stressing" opposite where one of the header pipes goes
 >>>in to
 >>> >>the silencer i.e. where hot gases directly from the end of the header
 >>>pipe
 >>> >>would impinge internally?
 >>> >>Duncan McF.
