[ Bob Haas ] : New Email List Photo Share Available!
BobTezyk
PostPosted: Tue May 08, 2007 5:45 am    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Yes Bob,
We are out here. Just we just have nothing important to say right now.
Do not Archive
Bob Tezyk
601XL QB J3300
Building Elevators
________________________________ Message 1
_____________________________________
Time: 01:26:27 PM PST US
Subject: [ Bob Haas ] : New Email List Photo Share
Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available:
Poster: Bob Haas <checkpoint2(at)comcast.net>
Lists: JabiruEngine-List
Subject: Sensenich Ground Adjustable Prop
http://www.matronics.com/photoshare/checkpoint2(at)comcast.net.05.07.2007/index.html
View user's profile Send private message Send e-mail Yahoo Messenger
hulens61(at)comcast.net
PostPosted: Tue May 08, 2007 6:06 am    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
> Bob Tezyk
++ Yep, we're out here waiting for something earth-shaking to respond to!
Fred 280 hours 3300/Zenith 601HDS
Lynn Matteson
PostPosted: Tue May 08, 2007 1:11 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Well, try this one on for size:
I have had to adjust my valve clearance several times recently, and
when I did it a few days ago, I found brass-colored metallic
particles inside one of the valve covers. I removed the oil filter
and cut it apart and found a few specks of the same material in the
filter. I removed the rocker shaft from the head to inspect the
rocker arm bushings, and found them in very poor shape, having lost
their teflon coating on the bottom of the bushing, and exposing the
sintered brass backing. The shafts are in good shape, slightly
discolored, but not worn.
Anybody else have a problem with valve lash? If you do, there's a
good chance that the bushings are worn, causing the lash to increase.
I did some research on the bushings, and found that they will
withstand over 400 degrees F, but could find no specs on how much
pressure the bushings will endure.
Lynn Matteson
Grass Lake, Michigan
flying w/275+ hrs
On May 8, 2007, at 10:06 AM, Fred Hulen wrote:
<hulens61(at)comcast.net>
> now.
> > Bob Tezyk
respond to!
Lynn
Kitfox IV-Jabiru 2200
N369LM
Peter H
PostPosted: Tue May 08, 2007 1:19 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Lynn, nice to hear a voice or two on this list. How many hours on that
engine and what oil have you been using? (I have only 25hours but counting)
Peter H
milreed(at)directcon.net
PostPosted: Tue May 08, 2007 2:40 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
What prompted you to check ? Noisy, or was it a routine check. Keep it
going.
Mil
Lynn Matteson
PostPosted: Tue May 08, 2007 5:11 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
I've been here since day one, but have held off posting much of
anything on this group (I also watch the Yahoo one) until now...lack
of anything to write about. But I've got a couple of issues to talk
about...more later.
I've got about 280 hours on it since it was first flown about 13
months ago. I used the mineral oil break-in oil recommended, then
switched to Aeroshell 100W after that. During the winter I used
Aeroshell 15W-50. I've always changed the oil at 25-30 hours, with
the filter.
I enjoy the engine very much, and try not to bad-mouth it, but
recently I've had a couple of disturbing incidents. Anybody looked
inside their distributor caps lately?
Lynn Matteson
flying w/275+ hrs
On May 8, 2007, at 5:17 PM, Peter Harris wrote:
<peterjfharris(at)bigpond.com>
counting)
Peter H
Lynn
N369LM
Lynn Matteson
PostPosted: Tue May 08, 2007 5:39 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
After just the suggested checking at the proscribed hour, and
checking during the suggested head torque period, it came to me that
the engine was running more roughly...vibrating, actually...and
knowing engines as I do, I knew this could be caused by a cylinder
being off on valve lash. (If cylinders are dissimilar in their valve
lash, the power output is affected, hence it runs rough or vibrates.
It's a whole lot more noticeable on a 4-cylinder than on a higher
number of cylinders) After a lash re-setting, the engine ran fine.
When I found the brassy-colored particles the other day, inside the
rocker cover, and then "fingering" the rocker arms for slop, I
decided to pull the rocker shafts and have a look at the bushings.
What I found was a loss of the teflon coating where the arm contacts
the rocker shaft. I took the parts to an engine-knowledgeable person
locally, and he immediately recognized the bearing material as a DU
bearing material...do a google search for DU and read the interesting
history about this technology.
When I contacted my dealer, he said that apparently there is no
problem in the history of the Jabiru line of engines.
Perhaps there is no problem, but I've seen what my bearings look like
and I don't like the looks, and will be changing bushings soon. Since
I am out of warranty, I don't expect Jabiru to do anything for me, so
I'm taking the repair into my own hands.
Lynn Matteson
flying w/275+ hrs
On May 8, 2007, at 6:39 PM, Milburn Reed wrote:
<milreed(at)directcon.net>
it going.
Mil
Lynn
N369LM
Peter H
PostPosted: Tue May 08, 2007 8:11 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
I got a vast improvement in smooth running when I had my wooden prop
dynamically balanced even though I had spent hours to achieve a perfect
static balance. When the dynamic weights were added it was like a new
engine.
Peter J3300 25hrs
JohnDRead(at)AOL.COM
PostPosted: Tue May 08, 2007 8:35 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Did you try emailing the factory rather than the dealer about this problem?
John Read
See what's free at AOL.com.
Lynn Matteson
PostPosted: Wed May 09, 2007 5:10 am    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
What kind/make prop? Mine's a Sensenich, and was smooth running from
the git-go. My engine started out smooth as silk, but over the hours
got mild vibration due to the valve lash loosening. After each new
setting, back to smooth again.
Lynn Matteson
flying w/275+ hrs
perfect
engine.
Peter J3300 25hrs
Lynn
N369LM
Lynn Matteson
PostPosted: Wed May 09, 2007 5:32 am    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
I don't know who this question if for , because you didn't include at
least a snippet of the post you're referring to, but I'll take a
chance it was about the valve lash/rocker arm bushing thread.
No, I didn't email the factory, because I've always heard that the
factory doesn't answer their emails. Besides, I've always had good
luck just phoning the dealers here in the USA. That is until another,
previous problem, came up and I never got an answer to my 2 emails
(including pictures) to each of the 3 US dealers....solved that one
on my own.
I guess it wouldn't hurt to email the factory, and see what they have
to say. I'm not trying to bad mouth the dealers, I just want to get
some answers, or alert somebody to a possible problem.
Lynn Matteson
flying w/275+ hrs
problem?
John Read
http://www.matronics.com/Navigator?JabiruEngine-List _-
Lynn Matteson
flying w/275+ hrs
Lynn
N369LM
PostPosted: Wed May 09, 2007 6:58 am    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
engine.
Peter J3300 25hrs
++ Hey Peter, please tell me more about the particular process you went
through to dynamically balance your prop. I went to a specialty place to
have mine done but after about an hour of applying sensors and getting all
of their equipment ready to actually do it, the guy asked that I run the
engine at 2500 rpm for 5 minutes! My cooling is just fine in normal
operations but there's no way could I sit there on the ground and run it at
2500 rpms for 5 minutes without getting too hot. Please tell me some of the
particulars when you had yours done.
Fred
Peter H
PostPosted: Wed May 09, 2007 1:16 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Lynn
My prop is from Ed Sterba and I have been trimming it, also there were
issues with the spinner backing plate. But my experience proved that static
balance was not enough. It was not until dynamic balance that I discovered
how smooth is smooth.
By valve lash do you mean that the tappet clearances were regularly becoming
uneven?
Peter H
info(at)usjabiru.com
PostPosted: Wed May 09, 2007 1:44 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Peter,
Where did you attach the weights to the prop or spinner to balance it? How
much weight did it take? We are about to go into the dynamic balancing
business and are not sure just yet as to where to attach the weights.
Pete Krotje
Jabiru USA Sport Aircraft, LLC
Lynn Matteson
PostPosted: Wed May 09, 2007 2:58 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Yes, valve lash is what it is sometimes referred to over here. It
used to be called tappet clearance (in the days of flathead engines)
when in fact you were setting the clearances *at* the tappet (cam
follower), but with overhead valve engines, the term valve clearance
or valve lash is used...here at least. When dealing with a small
number of cylinders, any cylinder which has its valves mis-adjusted
will operate at less power than the others, causing the vibration or
imbalance. This is partly due to less *effective* camshaft lift
(looser clearance setting), or maybe keeping the valve open when it
should be closed (tighter to 'zero' clearance setting).
Lynn Matteson
flying w/275+ hrs
Lynn
that static
discovered
becoming
uneven?
Peter H
Lynn
N369LM
Peter H
PostPosted: Wed May 09, 2007 9:05 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Pete the maintenance shop here did the job and they have a lot of experience
with the equipment, using electronic equipment which they said cost $6000. A
vibration sensor is attached to the engine near centre front just behind the
prop. A laser is fitted where it will see the reflection from tape on the
prop. The two inputs establish weight and position. The control unit is
attached to the sensor and laser by long leads. The backing disc for the
spinner was indexed and I ran the engine up to 2700 rpm and the first read
out called up weights and a location. At this stage washers were selected
and weighed using a very sensitive electronic scale part of the kit which
measures to .01 G . The washers were fitted for convenience to the nearest
spinner attach screw and we ran again twice more with small adjustments to
the weights, then we calculated by proportion how much weight to fix at a
convenient hidden point at a smaller radius inside the backing plate. From
memory it took about 1.5G which we did with a short bolt and some washers
weighed using the e scale.
What impressed me was how much smoother it bran right from the first
addition. I think it is a good starting point for the flywheel bolts job.I
think your customers will be happy with the result. It took about 45min.
Peter
Peter H
PostPosted: Wed May 09, 2007 9:23 pm    Post subject: [ Bob Haas ] : New Email List Photo Share Available! Reply with quote
Hi Fred,
I covered most of the details in my post to Pete . From the point of view of
overheating it was not really an issue. I had the cowls off and each run up
was for only a minute or so, then there was down time for interpreting the
results, selecting and weighing the weights etc. and I switched off for
this. There was a total of 3 power runs and the whole job took about 45
mins. I would guess that 50% of the time was down time devoted to selecting
and weighing and adding the weights.
Let me know if you have any other questions.
Peter
