Posted: Tue May 08, 2007 5:38 am Post subject: wing walk material |
Hi guys,
I took Jeff Smalls advice and purchased some wing walk material from Ray
Allen
Company. The material deserves a second look by anyone wishing there were a
better wing walk material than what looks and feels like roofing shingles.
After cutting it to size and rounding off the corners, I placed it
exactly where it needed
to be. Daughter Sara picked up 6-inches of the forward end and
separated the peel-
off material, cut off the excess peel strip and folded corners each side
at the cut and I pushed
the material down while continuing to hold position for the lower half.
When the front
portion was stuck down, the rear portion was lifted and peel strip
corners were pulled to
separate the peel off material. I worked to spread the contact area back
to the
other end. Two rows of rivets were underneath this material and a pin
prick near each
rivet allowed the air to be removed. A 5/16 nylock nut was used to push
the material
down around each rivet. The whole operation for both wings was done in
about 30-minutes.
Thanks Jeff, this material is exactly what I was looking for and the
finish is non-skid
without the associated loose grit.
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Tue May 08, 2007 7:06 am Post subject: Re: wing walk material |
How about a nice close up picture?
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
