topglock(at)cox.net Guest
Posted: Sun May 06, 2007 6:52 am Post subject: Thank you, John Lawton. |
Last year, I had the pleasure of flying into John's airstrip, in
Tennessee and visiting with him and his near finished bird, for a
while. In our conversation, John mentioned how sealing up the aircraft
would clean up the lines, resulting in better speeds. As John said, the
glider guys do it and it works. Well, while I had Baby Blue
disassembled and was cleaning her up for Sun-N-Fun (which she did not
make, as she was still ailing from the weak carb spring incident) I
decided to add some gap seals to the wing, to seal the flaps, upon
retraction. What I used was a 2.25" wide piece of .020" styrene, a
product that I use, almost daily in my sign/graphics business. I
attached it to the wing using 1" hem tape (a very strong, two sided
tape, used to hem banners). Once the engine was restored to normal
operating condition, the results were immediate and astounding. I
haven't done a complete test, yet, but the results seems to have yielded
about 4-5 kph at cruise. It has also resulted in more float, during
landing, which I attribute to reduced stall speeds. I say reduced stall
speeds, because, by reducing my final approach from 65 kph to 60 kph,
across the numbers, Baby Blue lands like she used to. I'll be doing
more extensive tests, as the weather settles. However, I am extremely
pleased with the initial results of the simple and inexpensive mod.
Thanks again, John for your suggestion...
Jeff - Baby Blue
284 hours
Posted: Sun May 06, 2007 11:55 am Post subject: Thank you, John Lawton. |
Jeff
are you sure the seal strip was styrene? The glider boys over here use
Melinex which is polyethylkene teraphthalate. Dacron to you and Terylene
to us but in film form. They make pop bottles from it too.
Keep us informed about your performance gains please/
Graham
| Quote: | product that I use, almost daily in my sign/graphics business. I
Jeff - Baby Blue
284 hours
Posted: Sun May 06, 2007 12:18 pm Post subject: Thank you, John Lawton. |
Graham,
Yes, I'm sure it is styrene. I buy it in 4 x 8 sheets at .020"
thickness for under $7. a sheet. In the sign industry, we use it for
commercial displays. Cut to size, add your graphics and a few strips of
velcro on the back. It's not the same as the stuff used by the glider
guys, but is apparently just as effective, for a much lower price...
Jeff - Baby Blue
Graham Singleton wrote:
<grahamsingleton(at)btinternet.com>
Jeff
Terylene to us but in film form. They make pop bottles from it too.
Graham
> Jeff - Baby Blue
> 284 hours
william(at)wrmills.plus.c Guest
Posted: Sun May 06, 2007 11:11 pm Post subject: Thank you, John Lawton. |
Jeff,
Why does the tape need to be so wide, or does it just come in 2 1/4" widths?
If you get a chance, perhaps you could publish a photo.
Best wishes,
William
pete(at)lawless.info Guest
Posted: Sun May 06, 2007 11:31 pm Post subject: Thank you, John Lawton. |
Jeff
Are you talking about landing flap up or flap down?
Pete
Posted: Mon May 07, 2007 7:07 am Post subject: Thank you, John Lawton. |
Flaps down...
Jeff
Pete Lawless wrote: [quote] [quote]--> Europa-List message posted by: "Pete Lawless" <pete(at)lawless.info> (pete(at)lawless.info) Jeff Are you talking about landing flap up or flap down? Regards Pete --
Posted: Mon May 07, 2007 7:23 am Post subject: Thank you, John Lawton. |
William,
1" of the 2.25"s is used up on the wing, by the attachment tape. The
other 1.25"s spans the gap and spills out onto the flap. I'm going to
trim the strip, until it affects the flight characteristics and see what
happens. I'll report my findings.
Jeff
William Mills wrote:
<william(at)wrmills.plus.com>
Jeff,
widths? If you get a chance, perhaps you could publish a photo.
Best wishes,
William
Posted: Mon May 07, 2007 7:32 am Post subject: Thank you, John Lawton. |
Jeff
That rather suggests that this ‘gap seal’ does not just block the gap with the flaps up but improves the airflow over the flap though the gap when the flaps are down.
Is there a picture of it anywhere?
Pete
Posted: Tue May 08, 2007 9:52 am Post subject: Thank you, John Lawton. |
Pete and all,
I finally found the time and the photos. You can see the process and end result here: http://www.europaowners.org/modules.php?set_albumName=Flap-Seals-Baby-Blue&op=modload&name=gallery&file=index&include=view_album.php
Jeff - Baby Blue
285 hours
Pete Lawless wrote: [quote] 14 Hantone Hill
Jeff
Pete
-----Original Message-----
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com)] On Behalf Of Jeff B
Sent: 07 May 2007 16:06
Subject: Re: Thank you, John Lawton.
Flaps down...
Jeff
Pete Lawless wrote: [quote]--> Europa-List message posted by: "Pete Lawless" <pete(at)lawless.info> Jeff Are you talking about landing flap up or flap down? Regards Pete --
wmjack1(at)t3cs.net Guest
Posted: Tue May 08, 2007 10:39 am Post subject: Thank you, John Lawton. |
Jeff,
The technique looks just like what we have been using for years to curtail turbulence around racing sailboat rudders and trim tabs. I know it works well enough, in the denser medium of water, to provide measurable speed improvements. There is certainly every reason to believe it will work in a similar fashion around moveable aviation appendages.
Jack Hilditch
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Jeff B
Sent: Tuesday, May 08, 2007 1:52 PM
Pete and all,
Jeff - Baby Blue
285 hours
Pete Lawless wrote:
Jeff
Pete
fklein(at)orcasonline.com Guest
Posted: Tue May 08, 2007 11:58 am Post subject: Thank you, John Lawton. |
Thanks for the pixs Jeff....looks very slick and tidy.
Is the width of the styrene wide enough to maintain the seal when the
flaps are deployed?...or have you designed it so that a gap appears and
allows for airflow thru the slot?
Fred
On Tuesday, May 8, 2007, at 10:51 AM, Jeff B wrote:
[quote] Pete and all,
end result here:
Jeff - Baby Blue
285 hours
Pete Lawless wrote:
14 Hantone Hill
Jeff
Pete
ami(at)mcfadyean.freeserv Guest
Posted: Tue May 08, 2007 12:09 pm Post subject: Thank you, John Lawton. |
The effect of your seal is not much different to the standard set-up on the Classic wing, which has a similar but narrower (about 1" rather than 1.25") rearward-projecting 'seal' built in, because of hte method of construction.
I asked Don Dykin about this a few years ago (mainly in relation to a question about the smoothness of the inner duct formed in the TE of the wing, which is provided in the XS but not in the Classic). His view was that the geometry of the duct was not critical to its operation. I guess because it is a converging duct designed to merely 'blow' across the top of the flap to delay or prevent its stall.
Duncan McF.
Posted: Tue May 08, 2007 12:15 pm Post subject: Thank you, John Lawton. |
Good question, Fred. I'll have to look, next time I go out...
Jeff
Fred Klein wrote: [quote]Thanks for the pixs Jeff....looks very slick and tidy.
Is the width of the styrene wide enough to maintain the seal when the flaps are deployed?...or have you designed it so that a gap appears and allows for airflow thru the slot?
Fred
[quote]Pete and all,
Jeff - Baby Blue
285 hours
Pete Lawless wrote:
14 Hantone Hill
Jeff
Pete
steven.pitt2(at)ntlworld. Guest
Posted: Tue May 08, 2007 12:20 pm Post subject: Thank you, John Lawton. |
Jeff, You are confusing me (it does not take much I hear some say!)
I thought I understood from other e-mails that it was necessary to maintain a gap in the flap to allow air to flow upwards when the flap is extended. However your photos suggest that your seal will stop any air going up through the flap at all stages of flight (or is this not the case?).
I can understand sealing the ailerons and have seen this quite clearly on gliders over this weekend, but they don't have flaps so it does not apply to them.
Can someone please point me to an explanation of the aerodynamic theories surrounding this subject. Thank you
Steve Pitt
G-SMDH
Posted: Tue May 08, 2007 1:45 pm Post subject: Thank you, John Lawton. |
Steve,
My understanding is that preventing the air going over the flap, in cruise, reduces drag, resulting in higher cruise speed, which I have experienced. I don't have the engineering background to completely understand what is happening to the wing, in flight. That's why I depend on the guys on the list to keep me straight. I'm more of a "try it and see" kinda guy... John's advice is based on the success that the glider guys have had, sealing the gaps. It seems to have worked on Baby Blue, as well. Continued testing will tell to what degree of advantage the seals make. It may very well prove that the extra few knots is not worth the float upon landing. I won't know until I satisfy myself that I've explored all the angles (and strip widths)...
Jeff
Steve Pitt wrote: [quote] Jeff, You are confusing me (it does not take much I hear some say!)
Steve Pitt
G-SMDH
paul.mcallister
Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
Posted: Tue May 08, 2007 1:52 pm Post subject: Thank you, John Lawton. |
Jeff, would you happen to have a photograph of what your seal looks like with the flap down ? - Paul
Posted: Tue May 08, 2007 2:08 pm Post subject: Thank you, John Lawton. |
Paul,
I will take a few pics at the earliest convenience and post them to the album...
Jeff
Paul McAllister wrote: [quote] Jeff, would you happen to have a photograph of what your seal looks like with the flap down ? - Paul
Posted: Tue May 08, 2007 3:50 pm Post subject: Thank you, John Lawton. |
Jeff...
Measuring my wings w/ full flaps, I find a gap between the vertical
wing close out and the leading edge of the flap to be 4.25 inches.
Fred
On Tuesday, May 8, 2007, at 03:07 PM, Jeff B wrote:
| Quote: | Paul,
the album...
Jeff
<image.tiff>
