Valve rocker shaft / bearing wear
andy(at)suncoastjabiru.co
PostPosted: Wed May 09, 2007 9:29 am    Post subject: Valve rocker shaft / bearing wear Reply with quote
Lynn,
You seem to have done all that is necessary in investigating and remedying
the problem.
I note your email about distributor shaft scoring where the oil seals ride,
but there were no pictures. I don't have a 'quick fix' for that issue
either; it's certainly not a usual occurrence - either oil leaking past the
seal or scoring of the shaft by the seal, and certainly not at the hours you
have. Those seals are usually pretty good but my guess is the one that was
leaking must have been damaged - maybe from new, and the one that scored the
other shaft had picked-up an abrasive particle in the seal. Unlikely? Yes,
but possible. I've seen many bearing / shaft instances where the (relatively
soft) bearing is in good condition, yet the (much harder) shaft has been
worn down. This is due to abrasive particles bedding into the soft bearing
(or in your case seal) material, and cutting away at the harder shaft.
Again, it seems you were unlucky in having these issues but no doubt you
have rectified them.
Andy
Suncoast Sportplanes, Inc.
39248 South Ave, Zephyrhills, FL 33542
Tel: (813) 779 2324 Fax: (813) 779 2246
www.suncoastjabiru.com
Lynn Matteson
PostPosted: Wed May 09, 2007 1:06 pm    Post subject: Valve rocker shaft / bearing wear Reply with quote
Andy-
Yes, that problem has been cured. New seals, new caps and rotors, and
a little product call "Speedi Sleeve". I also drilled a hole in the
lower area of each cap so I could feel there and see if the fix was
still working.
In the email to you, Pete, and Jim, I ended with "I have pictures
available" (or something like that), and Jim responded that he would
like to see them. I sent to him, and CC'd you and Pete. They were
sent via Kodak EasyShare. If you'd like to see them, holler. I sent
them about 3/24/2007 or thereabouts.
Lynn Matteson
Grass Lake, Michigan
flying w/275+ hrs
On May 9, 2007, at 1:27 PM, Andy Silvester wrote:
<andy(at)suncoastjabiru.com>
Lynn,
remedying
the problem.
seals ride,
past the
hours you
that was
scored the
Unlikely? Yes,
(relatively
been
bearing
doubt you
Andy
Lynn
Kitfox IV-Jabiru 2200
N369LM
