VHMUM(at)bigpond.com Guest
Posted: Thu May 10, 2007 8:57 pm Post subject: Aileron torque tube help |
My Aileron torque tube rubs on the W-1013 which is the braket that is riveted to the rear wing spar that holds the Aileron on. Only in the downward position. Anyone else had that problem?
Chris
Posted: Fri May 11, 2007 5:01 am Post subject: Aileron torque tube help |
Does it hit on the shop head of a rivet or on the actual shaft? If on the rivet, you could try flipping it over to see if the mfg head would provide better clearance. I may have seen this, but I think the problem went away when the controls were rigged.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of The McGough Family
Sent: Friday, May 11, 2007 12:57 AM
Subject: Aileron torque tube help
Chris
[quote] [b]
LloydDR(at)wernerco.com Guest
Posted: Fri May 11, 2007 5:21 am Post subject: Aileron torque tube help |
Do you have both Aileron's on, and have verified full travel with both? They act as stops for each other and it might be rubbing now, and not when both are hooked up. Once you have both hooked up, you can relieve some of the distance with a file, just be careful not to scratch the paint...ask me how I know that painting and saving the finish is way too hard.
Dan
N289DT RV10E
Chris
Vern(at)teclabsinc.com Guest
Posted: Fri May 11, 2007 7:15 am Post subject: Aileron torque tube help |
I noticed the same interference after completing my wings. Van’s suggested adjusting the number and thicknesses of the washers between the two sides of the hinge, the inboard and outboard hinges and /or the torque tube rod end to shift the aileron and torque tube away from the W-1013. While making sure not to create any other interference.
The other challenge I had was the washers called out in section 21 did not capture the hinge pivot points and allowed the bolt to rotate inside the bearing ball. They said add more washers as needed. These suggestions seemed to help but I won’t know if this solves the problems until I get the wings installed and ailerons fully rigged.
Vern Smith (#324 tail cone attachment)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Lloyd, Daniel R.
Sent: Friday, May 11, 2007 6:22 AM
Subject: RE: Aileron torque tube help
Dan
N289DT RV10E
Chris
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | 0123456789
john_rv10(at)yahoo.com Guest
Posted: Fri May 11, 2007 11:20 am Post subject: Aileron torque tube help |
We had the same problem with our QB wings. What we noticed was that the aileron attach brackets on one wing in particular were not square to the rear spar. After we squared them up, the clearance was OK.
John Cleary (Fuse)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vern W. Smith
Sent: Saturday, 12 May 2007 1:15 AM
Dan
N289DT RV10E
Chris
| Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.com | [/b]http://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com[/b] [/quote]0123456789 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 4 | Quote: | | href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List | 5
