Posted: Thu May 10, 2007 7:29 am Post subject: Priming - Sherwin Williams DTM |
Les;
Good day!
I called Sherwin Williams and asked what the proper surface prep for DTM
wash Primer is. The Tech support gentleman (not the store) mentioned to use
a water based cleaner like Simple Green, etc.. He advised not to use MEK,
Acetone or any non water based cleaner as it does not properly prepare the
surface for the DTM primer.
Probably not a problem for you but wanted to advise what SW told me today.
Regards!
Pascal
LloydDR(at)wernerco.com Guest
Posted: Thu May 10, 2007 7:55 am Post subject: Priming - Sherwin Williams DTM |
I had heard never to use simple green around aluminum? Can someone
confirm or deny?
Dan
N289DT RV10E
Vern(at)teclabsinc.com Guest
Posted: Thu May 10, 2007 8:19 am Post subject: Priming - Sherwin Williams DTM |
Pascal,
If memory serves me regular Simply Green causes corrosion on aluminum.
Because of this, Simply Green came up with a formula for aircraft which
is not supposed to promote corrosion. I wonder which one he was
recommending.
Just food for thought,
Vern Smith (tailcone attachment #324)
mritter509(at)msn.com Guest
Posted: Thu May 10, 2007 8:24 am Post subject: Priming - Sherwin Williams DTM |
I use Extreme Simple Green on the dirty side and it works great. Directions
on the bottle ok its use on aluminum.
Mark
N410MR
[quote]From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Subject: RE: Priming - Sherwin Williams DTM
Date: Thu, 10 May 2007 11:55:20 -0400
confirm or deny?
Dan
N289DT RV10E
Posted: Thu May 10, 2007 10:24 am Post subject: Priming - Sherwin Williams DTM |
For long term use one wants to use Extreme (aircraft friendly)
http://www.simplegreen.com/pdfs/07_msds_extreme_aircraft.pdf simple green.
The normal simple green supposedly showed problems after prolonged use. BUT
for for cleaning and rinsing than it was fine.
Les;
He was suggesting ANY water based cleaner. Simple Green being the example he
gave.
http://consumer.simplegreen.com/cons_prod_ori.php- General purpose cleaner
info
http://consumer.simplegreen.com/cons_buy_canada.php- where to buy in Canada.
ANY aluminum cleaner that is water based is the key for the DTM wash primer,
versus using a non water based chemical- at least per the manufacturer.
Pascal
Posted: Thu May 10, 2007 10:35 am Post subject: Priming - Sherwin Williams DTM |
Unfinished, uncoated or unpainted aluminum cleaned with Simple Green
products should receive some sort of protectant after cleaning to prevent
oxidation.
Aircraft Cleaning with Simple Green or Crystal Simple Green
Many private and commercial aircraft owners and operators have cleaned their
craft with All-Purpose Simple Green or Crystal Simple Green® for many years.
However, these products do not have Mil-Prf (military testing) authority.
The testing involves very long (168 hours in one test) soaking of various
metals in the solution and then a corrosion inspection. If an aircraft owner
only wants to use mil-prf approved products; he will not want to use Simple
Green. Please see the additional information under "Aluminum".
Aluminum - Is it safe to use Simple Green on aluminum?
Simple Green products have been successfully and safely used on aircraft,
automotive, industrial and consumer aluminum items for over 20 years.
However, caution and common sense must be used: Aluminum is a soft metal
that easily corrodes with unprotected exposure to water. The aqueous-base
and alkalinity of Simple Green or Crystal Simple Green can accelerate the
corrosion process. Therefore, contact times of All-Purpose Simple Green and
Crystal Simple Green with unprotected or unpainted aluminum surfaces should
be kept as brief as the job will allow - never for more than 10 minutes.
Large cleaning jobs should be conducted in smaller-area stages to achieve
lower contact time. Rinsing after cleaning should always be extremely
thorough - paying special attention to flush out cracks and crevices to
remove all Simple Green/Crystal Simple Green residues. Unfinished, uncoated
or unpainted aluminum cleaned with Simple Green products should receive some
sort of protectant after cleaning to prevent oxidation.
He did mean the general purpose at the 1:30 ratio as he was talking general
purpose cleaners not aircraft specific.
Thanks for asking Vern.
Pascal
Posted: Thu May 10, 2007 11:06 am Post subject: Priming - Sherwin Williams DTM |
I've been scuffing with a Scotchbrite pad soaked in Coleman fuel and
getting what appears to be satisfactory results with the DTM wash
primer. I'll try the SimpleGreen next.
I've worked to spray a thin coat but apparently got carried away. My
Tech Advisor observed that aluminum was shining through on some of my
pieces indicating the coat was too thin. There is a distinct shiny-ness
that can be observed on surfaces where a heavier coat is needed. What
seems to happen is that the primer falls into the valleys of the scuff
marks. The spec sheet for the primer states that it is not effective on
sandblasted metals due to surface roughness. Enough to fill the scuff
profile is required (and easily done). Therefore, I'm now using the
finer Scotchbrite pad for the scuffing.
Vans says that the QB parts are primed with the same stuff (but without
the greenish tint). It's apparent that they are brushing it on rather
than spraying. Perhaps foam brushes? Anyone with experience brushing
the wash primer on?
Pascal wrote:
Les;
Good day!
DTM wash Primer is. The Tech support gentleman (not the store)
mentioned to use a water based cleaner like Simple Green, etc.. He
advised not to use MEK, Acetone or any non water based cleaner as it
does not properly prepare the surface for the DTM primer.
today.
Regards!
Pascal
apilot2(at)gmail.com Guest
Posted: Thu May 10, 2007 12:00 pm Post subject: Priming - Sherwin Williams DTM |
The regular Simple Green might be okay on a single sheet of aluminum
that was then thoroughly rinsed. The minute you introduce lap joints
and rivets you have no assurance you can in fact get all of the
substance off, and it is that residue in the joints that is the
corrosion risk. I'd like to know what the objection is to any of the
petro solvents that leave no residue, like toluene. Or you could
compromise with pure isopropyl alcohol, which is sorta water based,
and certainly not petro based.
Les;
gave.
info
Pascal
Posted: Thu May 10, 2007 12:30 pm Post subject: Priming - Sherwin Williams DTM |
As Van's says in Chapter 5 "whatever you use, prepare the surface as per the
manufacturers instructions". I am simply relaying that information per the
manufacturer.
I'm fine with the Simple Green option, it's biodegradeable and less fumes.
You do ask interesting questions however. Call SW and ask them. 800 33107979
(US based).
Pascal
AV8ORJWC
Posted: Thu May 10, 2007 12:43 pm Post subject: Priming - Sherwin Williams DTM |
Yes. As long as it is "Extreme" Simple Green (which was introduced at
OSH two years ago). The problem was, and is technically known as
"Hydrogen Embrittlement". The Faying action - Wicking of chemicals
(especially alkalines) does cause long term corrosion. It is the
hardening of steel fasteners which is the big issue. "Extreme" has been
reformulated.
The new Extreme Simple Green is now "Boeing approved". The swelling
action of Tefzel wire insulation has been reduced as well.
Most of the problems come from improper or incomplete rinsing of
solvents and contaminates. All aluminum immediately begins oxidation
once it dries. That is why reasonably quick primering of exposed
surfaces is highly recommended for long term protective paint
application.
However to correct your last statement - Simple Green in the original
form (though used for years) was and remains VERBOTTEN on U.S. military
aircraft. It is great for cleaning grease and hydro-carbon based
contaminates but it did allow Hydrogen Embrittlement. Understanding
faying action will show that it is not possible to flush out chemicals
once introduced and wicked into a joint or crack.
On this subject I will gladly wear a flame suit cause I did research
after A&P school and got to communicate direct with Simple Green's
president and worked with the Beta Version before public release for
Prime Time.
Don't use the old stuff - Boeing wouldn't allow it either. "Extreme
Simple Green" or use other products.
John Cox - the Turbinator
Posted: Thu May 10, 2007 1:31 pm Post subject: Priming - Sherwin Williams DTM |
Thanks for the feedback. I should have mentioned I called ALL the
maunfacturers before using anything. Sure "extreme" is fine full strength
and even has anti corrosion bult into it, sure "General Purpose" SG is toxic
to Aluminum full strength. When mixed per the instructions of 30:1 it is
quite approved by Simple Green for pre priming. I cleaned, rinsed,
compressed air dried it and primed all within 1 hour of each other.
What me worry? not a bit!
Pascal
