sportav8r(at)gmail.com Guest
Posted: Mon May 14, 2007 4:53 am Post subject: source for ready-made hoses |
It's been ten years - time to replace the aging home-made oil and fuel hoses FWF.
This time I want to go with "lifetime" teflon hoses and professionally installed fittings and firesleeve, with pressure testing, so I'm looking for a good vendor to provide ready-made hoses. Any recommendations as far as price and service, turn-around time and so forth?
-Bill B / Stormy
Bruce(at)glasair.org Guest
Posted: Mon May 14, 2007 5:29 am Post subject: source for ready-made hoses |
If you want aircraft certified hoses try Sacramento Sky Ranch. You migh also try your local automotive speed shop.
Bruce
www.glasair.org
Tailgummer(at)aol.com Guest
Posted: Mon May 14, 2007 6:07 am Post subject: source for ready-made hoses |
Bill, I had all my hoses profesionally made , firesleeved, pressure tested and tagged by Aviall Aerospace in Van Nuys, Ca. I would do it again in a heartbeat. Reall nice people to work with. Try Tim Temple (at) (818) 997-5063.
John D'Onofrio RV8 N585JD
See what's free at AOL.com.
bmeyette
Posted: Mon May 14, 2007 6:22 am Post subject: source for ready-made hoses |
I had good service, quick turnaround, and good products from Southeastern Hose
<![if !supportEmptyParas]> <![endif]>
http://www.sehose.com/
brian
http://brian76.mystarband.net/engineOct06.htm#oct12
_________________ Brian Meyette, Cornish, NH
RV-7A QB tipup, supercharged Subaru STi engine, MT CS prop, all glass day/night/IFR panel, being built with solar and wind power
N432MM
http://brian76.mystarband.net/RV-7Ahome.htm |
vft(at)aol.com Guest
Posted: Mon May 14, 2007 9:40 am Post subject: source for ready-made hoses |
I had these type hoses made up for my Rocket project by Precision Hose Technology (PHT) in Tulsa, OK . I'm very happy with the way they tyrned out however there are a few things you should take into consideration when using these. The first is that they do not have an unlimited service life. Only an unlimited shelf life. The second is these hose assemblies are much stiffer than standard hose assemblies so they really need to fit well. When I measured for mine I intentionently added and extra couple of inches thinking that any extra length could be used up by allowing the hose to bend a bit between the attach fitting as is normaly the case with standard hosed. I ended up having to send some back and redone to a shorter length.
BTW Precision gave me great customer service in dealing with all of this.
Danny Melnik
F1 #25
Melbourne (FL) Rocket Factory
bmeyette
Posted: Mon May 14, 2007 12:08 pm Post subject: source for ready-made hoses |
Oh – and I almost forgot an important part – whoever you get them from, when you order them, be sure to specify OVERALL LENGTH – from the outer end of one nut to the outer end of the nut at the other end. I had specified sealing surface to sealing surface when I ordered mine, and it causes confusion. The hose makers expect lengths you give them are OAL.
brian
N432MM
Vanremog(at)aol.com Guest
Posted: Mon May 14, 2007 7:31 pm Post subject: source for ready-made hoses |
In a message dated 5/14/2007 10:42:06 A.M. Pacific Daylight Time, vft(at)aol.com writes:
| Quote: | | I had these type hoses made up for my Rocket project by Precision Hose Technology (PHT) in Tulsa, OK . |
Anyone have a phone number for them?
GV (RV-6A N1GV O-360-A1A, C/S, Flying 845hrs, Silicon Valley, CA)
Kellym
Posted: Mon May 14, 2007 8:01 pm Post subject: source for ready-made hoses |
www.aircrafthose.com
Vanremog(at)aol.com wrote:
| Quote: | In a message dated 5/14/2007 10:42:06 A.M. Pacific Daylight Time,
<http://www.aol.com?ncid=AOLAOF00020000000503>.
KCHD |
Posted: Mon May 14, 2007 8:13 pm Post subject: source for ready-made hoses |
In a message dated 5/14/2007 9:02:50 P.M. Pacific Daylight Time, kellym(at)aviating.com writes:
| Quote: | www.aircrafthose.com
That's an odd phone number. I have the website listed in the Yeller Pages, but was hoping for a phone number to complete the data. Do not archive.
-GV
Kellym
Posted: Mon May 14, 2007 8:23 pm Post subject: source for ready-made hoses |
I guess it is just to way too hard to click on a link for page that has
the phone numbers right front and center.
919-835-3660, 800-331-5946
| Quote: | In a message dated 5/14/2007 9:02:50 P.M. Pacific Daylight Time,
V
archive.
-GV
KCHD |
Posted: Mon May 14, 2007 9:27 pm Post subject: source for ready-made hoses |
In a message dated 5/14/2007 9:24:47 P.M. Pacific Daylight Time, kellym(at)aviating.com writes:
| Quote: | I guess it is just to way too hard to click on a link for page that has
You're right, the time I spend maintaining the Yeller Pages is of no consequence and as a bonus I get to field potshots from pudknockers such as you.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 844hrs, Silicon Valley, CA)
