ElleryWeld(at)aol.com Guest
Posted: Sat May 12, 2007 6:53 pm Post subject: Rotax 377 and 477 use same points and ignition? |
Kent
according to my CPS book the part numbers for the contact points set is Soldered part number is 983-349
Threaded part number is 983-343
these points will fit all engines 277,377,447,503
Good luck and I hope this helps you
Ellery do not archive
See what's free at http://www.aol.com. [quote][b]
Posted: Sat May 12, 2007 7:01 pm Post subject: Rotax 377 and 477 use same points and ignition? |
Kent
one more note the early engines prior to 1984 has the soldered wire on the condensers (early) or secured by threaded post (late production)
Ellery in Maine
kentk
Joined: 03 Jan 2007 Posts: 25 Location: College Station
Posted: Sun May 13, 2007 5:56 pm Post subject: Re: Rotax 377 and 477 use same points and ignition? |
Very good! Thanks much for the help!
_________________ Kent Knudsen
College Station, TX
K-IV 1200 / no engine / 25% done |
