av8rps(at)tznet.com Guest
Posted: Mon May 14, 2007 3:43 pm Post subject: Speedster features giving it higher speeds |
Don,
Here is something I scanned that offers a good description of what differs
between the Speedster and the rest of the earlier airplanes. Please note
the paragraphs that talk about the elevator trim, and the extra false ribs
on the bottom of the wing, as I personally believe this is what gives the
Speedster and later Kitfoxes considerably higher speeds than some of the
earlier model IV's (which fwiw are still faster than the 3's and earlier).
My IV-1200 on floats will go 120 mph on a 912ul, and it has a long wing.
I've been perplexed as to why it goes that fast when others say they can't
go that fast on wheels? And it is faster than a few of my buddies Model
IV-1050's that are on wheels? Only observable difference between the
airplanes is that I have extra false ribs in my wing they don't, and I have
electric elevator trim. Apparently these things make a large difference.
And I think I can understand as they both make sense. If the wing doesn't
hold it's shape consistently at high speeds, it will revert back to the
original airfoil shape somewhat, thereby increasing drag. And the elevator
trim definitely helps as you no longer need to trim the plane with the
flapperons, which are major drag if not neutral to the airstream (they are
essentially full length wings with a 10 inch chord, right?). So in my
opinion, if you you want a good little cross country Kitfox, make sure it
has those features.
However, if you desire a real booney basher with extreme stol
characteristics, but a model 3 or earlier with the lightweight airframe and
the high lift undercambered airfoil.
Just my two cents worth...
Paul Seehafer
Central Wisconsin
Model IV-1200 912ul IVO prop
Aerocet amphib floats
109.69 KB |
345 Time(s) |
127.9 KB |
373 Time(s) |
pwmac(at)sisna.com Guest
Posted: Mon May 14, 2007 4:35 pm Post subject: Speedster features giving it higher speeds |
True. If the shape of the bottom of the wing can be held in the
Riblitt designed shape It is bound to improve performance. And 3
false ribs/bay is much better than zero and 4 is better than 3. More
than 4 is starting to add weight. Standard speedster had 3 false
bottom robs in each bay.
Paul
At 04:39 PM 5/14/2007, you wrote:
| Quote: | Don,
differs between the Speedster and the rest of the earlier
airplanes. Please note the paragraphs that talk about the elevator
trim, and the extra false ribs on the bottom of the wing, as I
personally believe this is what gives the Speedster and later
Kitfoxes considerably higher speeds than some of the earlier model
wing. I've been perplexed as to why it goes that fast when others
say they can't go that fast on wheels? And it is faster than a few
of my buddies Model IV-1050's that are on wheels? Only observable
difference between the airplanes is that I have extra false ribs in
my wing they don't, and I have electric elevator trim. Apparently
these things make a large difference. And I think I can understand
as they both make sense. If the wing doesn't hold it's shape
consistently at high speeds, it will revert back to the original
the flapperons, which are major drag if not neutral to the airstream
(they are essentially full length wings with a 10 inch chord,
right?). So in my opinion, if you you want a good little cross
country Kitfox, make sure it has those features.
airframe and the high lift undercambered airfoil.
Paul Seehafer
Central Wisconsin
Guy Buchanan
Posted: Tue May 15, 2007 5:51 am Post subject: Speedster features giving it higher speeds |
| Quote: | Here is something I scanned that offers a good description of what
differs between the Speedster and the rest of the earlier airplanes.
Paul,
Thanks for this post. When I get my "Kitfox Flying Guide"
back I'll try to put together a Matronix Wiki entry covering the
various models and history which people can update at will.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
