rtoth1(at)verizon.net Guest
Posted: Fri May 18, 2007 5:10 am Post subject: Kitfox-List Digest: 33 Msgs - 05/17/07 |
Thanks for all the comments on the Grove Gear. To answer the question as to why I don't like the Tube Gear even though I haven't flown it yet. I feel it's too narrow of a foot print. Bungees were a pain to install. I like the appearance of the Grove over the Tube. For sure I like the comments about the Grove Gear.
Bob Toth
Woodbridge, Virginia
From: Kitfox-List Digest Server <kitfox-list(at)matronics.com>
| Quote: | Date: 2007/05/18 Fri AM 01:58:49 CDT
To: Kitfox-List Digest List <kitfox-list-digest(at)matronics.com>
Subject: Kitfox-List Digest: 33 Msgs - 05/17/07
[quote]*
Today's complete Kitfox-List Digest can also be found in either of the
of the Kitfox-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 07-05-17&Archive=Kitfox
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 07-05-17&Archive=Kitfox
Kitfox-List Digest Archive
Total Messages Posted Thu 05/17/07: 33
Today's Message Index:
1. 03:25 AM - Grove Landing Gear (fox5flyer)
2. 05:11 AM - floats (Don and Dianne Usher)
3. 05:29 AM - Re: gas cap not venting? (Barry West)
4. 06:50 AM - Re: floats (akflyer)
5. 07:21 AM - Re: Kitfox V in Cameron Park California Area (Randy Daughenbaugh)
6. 09:19 AM - KitFox wheel base? (Don G)
7. 10:50 AM - Re: Grove Landing Gear (kitfoxmike)
8. 10:57 AM - Re: KitFox wheel base? (Lynn Matteson)
9. 11:53 AM - Re: Re: Grove Landing Gear (Michel Verheughe)
10. 12:24 PM - Re: KitFox wheel base? (Zimmermans)
11. 12:54 PM - Re: Grove Landing Gear (kitfoxmike)
12. 01:19 PM - Rotax 582 failure (semi off-topic) (Michel Verheughe)
13. 01:31 PM - Re: KitFox wheel base? (john oakley)
14. 01:39 PM - Ogden foxes (john oakley)
15. 01:57 PM - Re: Ogden foxes (kerrjohna(at)comcast.net)
16. 02:29 PM - Re: Re: Grove Landing Gear (Allan Aaron)
17. 02:33 PM - Re: KitFox wheel base? (Don G)
18. 02:36 PM - Re: Ogden foxes (john oakley)
19. 03:33 PM - Re: Re: KitFox wheel base? (Lynn Matteson)
20. 04:13 PM - Re: Ogden foxes (darinh)
21. 04:31 PM - Re: Ogden foxes (Dan Billingsley)
22. 04:37 PM - Re: Re: Ogden foxes (Dan Billingsley)
23. 04:42 PM - Re: Ogden foxes (Dan Billingsley)
24. 04:46 PM - Re: Re: Ogden foxes (john oakley)
25. 04:47 PM - Re: Re: KitFox wheel base? (john oakley)
26. 04:59 PM - Re: Re: Ogden foxes (take 2) (Dan Billingsley)
27. 05:00 PM - Re: Ogden foxes (fox5flyer)
28. 05:07 PM - Re: Ogden foxes (john oakley)
29. 06:23 PM - Re: KitFox wheel base? (Don G)
30. 06:28 PM - Re: Brakes little to none (pilotpat)
31. 07:31 PM - Re: gas cap not venting? (Malcolmbru(at)aol.com)
32. 08:09 PM - Re: Re: KitFox wheel base? (john oakley)
33. 08:19 PM - Fw: Let's Go For It! (jerry evans)
Time: 03:25:58 AM PST US
Subject: Grove Landing Gear
Robert, the 912 prop combo should be a good setup for your IV, but just
out of curiosity, what is it about the tube gear that you aren't happy
with?
Deke Morisse
N148DM
S5/Soob/CAP
NE Michigan
I am building a 4-1200 with a Rotax 912UL IVO medium In-Flt adj. prop.
I have the standard tube gear installed and am not too happy with it.
Does anyone have a Grove Gear available they would like to get rid of???
Robert S. Toth rtoth1(at)verizon.net
Time: 05:11:19 AM PST US
From: "Don and Dianne Usher" <denver7(at)xplornet.com>
Subject: floats
I am installing full lotus floats on my kf 111, and leaving the gear
legs in place. What is the diameter of the axle. Have to drill the main
gear support fitting.
Don
Time: 05:29:32 AM PST US
Subject: Re: gas cap not venting?
MessageOn my Model IV the tube is steel, may be stainless but probably
plated after welding along with the cap. And it is welded, I can remove
and/or tighten the cap by torqueing the tube and see the weld bead. It
is not soldered.
Barry West
