jpspencer(at)cableone.net Guest
Posted: Sat May 26, 2007 6:47 pm Post subject: 701 Elevator cable. Weird problem |
I think the problem is inherent to the off center control horn setup. My solution was to run the down elevator cable as slack as I could to avoid the tightening of the cable with right aileron application. So far it works ok(85 hours). I didn't install the bungee-just slipped a length of clear vinyl tubing over one of the cables and let em rub. I will periodically inspect the cable under the tubing to be sure corrision doesn't develop.
Admittedly somewhat shadetree but then that's in keeping with the offset control horn.
Joe
