chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri May 25, 2007 1:11 pm Post subject: XL Upper rudder Hinge instalation |
Hi
Just installing the top rudder bracket on my XL 6b2 -71but have just noticed that there is no shim under the bracket between the 2 top rear Longerons. Does it just get riveted onto them and the top triangle rear panel 6b3-6?
There is a 40 thou gap should this also have a shim just like the bottom hing between the longerons?
Chris..
Michael Valentine
Posted: Fri May 25, 2007 2:09 pm Post subject: XL Upper rudder Hinge instalation |
I just did mine a couple months ago - I just left the gap. As it is pretty narrow at that point, I didn't even give it a thought.
Michael in NH
On 5/25/07, chris Sinfield <chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)> wrote:[quote] --> Zenith-List message posted by: "chris Sinfield" <chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)>
Hi
Chris..
tonyplane(at)bellsouth.ne Guest
Posted: Fri May 25, 2007 4:12 pm Post subject: XL Upper rudder Hinge instalation |
Chris,
I do not like shanked rivets, which you have without a shim for the center rivet. I put a shim in - In fact, I believe I made it a working shim (doubler) by extending the shim and tying the shim down with two additional rivets into the 6B3-6. By tying in the shim, you minimize bending loading of the aft center rivet.
Tony Graziano
XL 493TG
Subject: XL Upper rudder Hinge instalation From: chris Sinfield (chris_sinfield(at)yahoo.com.au ([email]chris_sinfield(at)yahoo.com.au?subject=Re:%20XL%20Upper%20rudder%20Hinge%20instalation&replyto=1180127509.m2f.114807(at)forums.matronics.com[/email])) Date: [b]Fri May 25 - 2:14 PM[/b] [quote] | Quote: | Hi
the longerons?
Chris..
| [b]
