Brett Walmsley
Posted: Wed Feb 08, 2006 5:08 pm Post subject: engine mount steel bushing |
I seem to recall a procedure to shorten the steeel bushing in the engine mount to affectivly tighten the engine mount bushings more. Anyone else remember this? Was it a service bulletin? or letter?.
Brett
_________________ Brett
Model IV 1200/912UL |
KITFOXPILOT(at)msn.com Guest
Posted: Wed Feb 08, 2006 7:33 pm Post subject: engine mount steel bushing |
I do remember that if your were upgrading the 912 mount, then the shorter steel bushings were the required ones. You can shorten yours, I would have to look at my specs to see what the new size was.
Ray
Jim Shumaker
Posted: Thu Feb 09, 2006 10:05 pm Post subject: engine mount steel bushing |
Yes, shortening the steel bushing tightens the engine to the frame. The new dimension is 0.92".
Jim Shumaker
Brett
_________________ Jim Shumaker |
Brett Walmsley
Posted: Fri Feb 10, 2006 6:28 pm Post subject: engine mount steel bushing |
Thanks Jim.
I will do that.
