Deems Davis
Posted: Tue May 29, 2007 4:46 pm Post subject: Blast Tubes for Mags? |
Has anyone routed a blast tube to cool their mags? Apparently some
aircraft are know for having problems with heat and mags. Living in AZ,
any time I hear of a heat issue I pay attention. I'm at the point where,
if I'm going to do it it Now would be the time. So If anyone has done
this I'd be appreciative of any pictures you might have or would be
willing to share as well as any information regarding how you installed
them. e.g. where exactly do you direct the air to on the mag? Which part
is it that get the hottest?
Deems Davis # 406
Baffling / Plenum / Engine Stuff
http://deemsrv10.com/
AV8ORJWC
Posted: Tue May 29, 2007 5:18 pm Post subject: Blast Tubes for Mags? |
One of the bench checks in rebuilding a Mag is to heat the capacitor to
see if its ability degrades with modest heat increase. Unfortunately,
you must cool the case and cap to achieve the desired cool operating
temperature.
Blast tubes do localize the cooling at the point of discharge.
John #600
ScooterF15
Posted: Wed May 30, 2007 3:08 am Post subject: Blast Tubes for Mags? |
I used the Van's cooling kits supplied with the Firewall Forward kit. Really it's just a piece of corrugated tubing held into a hole in the baffles with hi temp silicone. The left one is directed at the left mag. I don't have a right mag so I pointed the right blast tube at the heater valves / firewall just forward of the tunnel; that's one of a few different tunnel heat fixes I did (not sure if it did any good, but the tunnel stays cool).
I had an A&P look at my engine a couple months ago. He didn't like the fact that I had the blast tubes secured to my engine mount with zip ties. He said that the tolerance for wear on the engine mount frame was very small and that zip ties will eventually chafe enough to cause wear. So as you can see from the photos the blast tubes are held by a healthy glob of red silicone.
-Jim
40134
In a message dated 5/29/2007 8:48:31 P.M. Eastern Daylight Time, deemsdavis(at)cox.net writes:
| Quote: | --> RV10-List message posted by: Deems Davis <deemsdavis(at)cox.net>
Deems Davis # 406
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
See what's free at AOL.com.
83.8 KB |
470 Time(s) |
83.54 KB |
438 Time(s) |
