Structural adhesive
bmwebb(at)cox.net
PostPosted: Thu Feb 09, 2006 4:16 am    Post subject: Structural adhesive Reply with quote
Also, what is "structural adhesive"? And where can I get this?
Thanks again
Bradley
KF2 N1836
Middle GA
bnn(at)nethere.com
PostPosted: Thu Feb 09, 2006 9:58 am    Post subject: Structural adhesive Reply with quote
Structural adhesive is simply high strength glue. It comes in a variety of
formulations, but generally has a shear strength of 2000 psi or greater,
and a peel strength of 20 pli or greater. They are called structural
because they are used as primary structure. There are a wide variety of
formulations, the most common being epoxy based, but there are also
acrylic, methacrylate, cyanoacrylate, and many others. They are made by a
variety of manufacturers, including Hysol and 3M for epoxy, and Plexus for
methacrylate. The various formulations are a result of the diversity of
cost/performance/application requirements.
For Kitfox assembly Aircraft Spruce is probably your most convenient
supplier; they sell the Hysol 9430 epoxy adhesive, which has very good
properties. You can probably get them locally, but it would be a specialty
supplier.
Do not confuse adhesive with resin. The latter can be used as a glue, but
has much poorer peel characteristics. Also avoid using the epoxies you get
in the little tubes at Home Depot. Close inspection will reveal tensile
strengths less than 2000 psi versus more than 5000 psi for the Hysol
product. (They do sell an acrylic adhesive with 4000 psi tensile, but it's
working time is about 15 seconds, too short for anything but very small tasks.)
Guy
