Deems Davis
Posted: Fri May 25, 2007 6:51 pm Post subject: Magneto to sparkplug routing |
Anybody up for a temporary break from panel discussions? (which I'm
enjoying thoroughly!)
I'm into the engine install, and working on baffling and plenum, and I'm
trying to think ahead so I know I've got clearance for spark plug leads,
how to attach, baffling penetration etc.. I've got dual Slick mags
6350/6351 (I may be willing to be an early adopter on some things, but I
couldn't get comfortable (yet) with conflicting info I was hearing on EI ).
My engine shipped with the mag harnesses uncoupled from the plugs, And
I'm at a loss on how to reconnect the leads. I've searched the Internet
for information about how to connect them and I've come up empty. I know
I can get the info from Allen (at) BPE on Monday AM, but am hoping someone
might have the answer over the weekend.
(My Lycoming manual depicts 2 different methods for dual mags.)
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Deems Davis
Posted: Fri May 25, 2007 7:01 pm Post subject: Magneto to sparkplug routing |
Boy, do I feel stupid :-[
I'm assuming that the answer must have something to do with the B3
(bottom cyl # 3 ?), T5 top Cyl #5?) , B6 ........etc stamped on the end
of the leads that connects to the plug....
Too long in a 100 degree garage!
Deems
Deems Davis wrote:
I'm trying to think ahead so I know I've got clearance for spark plug
leads, how to attach, baffling penetration etc.. I've got dual Slick
mags 6350/6351 (I may be willing to be an early adopter on some
things, but I couldn't get comfortable (yet) with conflicting info I
Internet for information about how to connect them and I've come up
empty. I know I can get the info from Allen (at) BPE on Monday AM, but am
hoping someone might have the answer over the weekend.
Deems Davis # 406
Tim Olson
Posted: Fri May 25, 2007 7:09 pm Post subject: Magneto to sparkplug routing |
What seems to be the problem with attaching the harnesses. They
did come with the wires all into a cap right? ... and that cap
just gets screwed to the mag. The cap actually only fits perfectly
in 1 orientation...but you have to be really careful because it
looks very close in one other orientation. As far as mag vs.
firing order....I'd have to dig in to read on that myself. It
was easy with a Lightspeed...just hook the top plugs to that
and the bottom to the mags. I can't remember the wire arrangement
for a pair of mags though...it's been toooooo long.
Deems Davis wrote:
Deems Davis # 406
Tim Olson
Posted: Fri May 25, 2007 7:31 pm Post subject: Magneto to sparkplug routing |
Don't feel too bad...you remembered it first. As soon as I
saw this post I had the head slapping moment myself. Now
I remember that it's printed right on the wires.
Well, at least you have the means to progress now!
Deems Davis wrote:
Deems
> Thanks
> Deems Davis # 406
Jack.Phillips(at)cardinal Guest
Posted: Tue May 29, 2007 3:48 am Post subject: Magneto to sparkplug routing |
Yeah, but don't trust Slick to get it right. When I built my first
plane, I installed new Slick mags and routed the harness per the labels
stamped in the lead caps. Tried for a week to get the engine to start
and run, but it was missing terribly, hitting on only 2 cylinders.
Finally disconnected the leads from all 8 plugs and checked the firing
order and found that the leads were mis-marked. Once I had them
correctly attached, the engine ran fine.
Jack Phillips
Just dimpling away on the tailcone
