Tractor Installation without Cowling
jose_m_toro(at)yahoo.com
PostPosted: Tue May 29, 2007 5:18 am    Post subject: Tractor Installation without Cowling Reply with quote
Hi All:
If a jabiru 2200 is installed in tractor configuration without cowling, would the stock air ducts and oil cooler provide adequate cooling? Are there specific considerations that I shoul know?
Thanks!
Jose
http://searchmarketing.yahoo.com/
Peter H
PostPosted: Tue May 29, 2007 1:43 pm    Post subject: Tractor Installation without Cowling Reply with quote
Hi Jose
The air ducts are supposed to direct the ram air down through the fins. If
the engine is not cowled I would think that there will be too much air
pressure under the engine and would reduce that air flow.
Peter
ianboag
PostPosted: Mon Jun 04, 2007 11:30 am    Post subject: Re: Tractor Installation without Cowling Reply with quote
OTOH there are lots of aircraft that run this way. X-Airs, Bantams have naked tractor setups. I don't know anything about their ram air ducts or oil coolers though ......
