jhines
Joined: 14 Mar 2007 Posts: 20 Location: Bella Vista, Arkansas
Posted: Mon May 28, 2007 4:35 pm Post subject: Scratch building the wing spar |
My project has been on hold for a while. I shifted gears after I finished the tail kit and decided to start scratch building from hear on. I have a lot of parts cut out but I haven’t popped a rivet in about a year. Of course the spar is complete when you purchase a kit so the standard instructions don’t have any information on the assembly process. Is there a resource out there about scratch building the wing spar?
_________________ John Hines |
Posted: Mon May 28, 2007 4:54 pm Post subject: Scratch building the wing spar |
| Quote: | Is there a resource out there about scratch building the wing spar?
Here is part of it:
www.ch601.org/resources/spar_cap/spar_cap_drilling.htm
-- Craig
naumuk(at)alltel.net Guest
Posted: Mon May 28, 2007 5:35 pm Post subject: Scratch building the wing spar |
John-
Tons of it. Check out Larry MacFarland's site, 601.org, Scott
Mc'Laughlin's, the list goes on. Easiest thing to do is search "spar
construction" in the archives and crossreference the poster's sites.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
jhines
Posted: Mon May 28, 2007 5:58 pm Post subject: Re: Scratch building the wing spar |
Well, I don't see much about actual spar construction on 601.org. And Scott McLaughlin's site says a guy named Jason Isley made his spars. There is nothing about actually building the spar on there, (unless I am blind).
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Mon May 28, 2007 7:16 pm Post subject: Re: Scratch building the wing spar |
Between 9-20-2006 and 11/24/2006 I scratch built wing and center spars and logged all the activity at my kit log with text and pictures. Have a look and see if it helps.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
jhines
Posted: Mon May 28, 2007 7:54 pm Post subject: Re: Scratch building the wing spar |
Ron,
Great detail! I will start studying.
lwinger
Posted: Mon May 28, 2007 9:02 pm Post subject: Re: Scratch building the wing spar |
John,
Having just completed my wing spars today, your question is timely. I was planning on writing out a few tips for those who follow, so here goes.
• Download and read the new Construction Manual (found in “builders” area of Zenithair.com under “Zodiac XL”, “Photo Assembly Guide Updates” near the top of the list).
• If you are using an Olfa knife for cutting your webs, be sure to score them plenty of times because of the .040 thickness. Anything less than 20 to 25 times, and I ended up with a ruined web.
• Edge dressing was a breeze with a Vixen file (http://www.ch601.org/tools/) and 400 grit wet/dry sandpaper. I kept checking it with digital calipers from Harbor Freight to hold close to the 212mm width. Per the Construction Manual (CS #304) this is a critical dimension.
• Bend your 20mm outboard flange before tapering the opposite end or marking your hole pattern.
• Use matched-hole drilling wherever possible. Randy Bryant does a good job of describing that at http://www.n344rb.com/ under “Wing – Spars” on his 5/4/2006 entries.
• Step drilling makes all the difference on the quality of your solid rivet holes. Pre-drill everything to #40 first.
• Another Randy Bryant tip involves spot-drilling your spar caps. Put them in position under the web and barely drill through the appropriate #40 holes to mark the caps. This makes final drilling super simple (because it is self-centering) and extremely precise.
• You’ll need to set up your drill press either in the middle of your table (http://www.ch601.org/resources/spar_cap/spar_cap_drilling.htm) or along the edge (http://www.mykitlog.com/lwinger) entry for 2/25/2007. This insures straight rivet holes through up to four layers of aluminum without introducing bowing.
• Dave Clay’s bending brake is great for making the spar cap angles and miscellaneous smaller parts. http://www.daves601xl.com/Tools/tools.html
• When bending the angles, make your blank wider than the developed length to give the brake something to grip. I used 100mm. On longer pieces, I even drilled out the material under each bolt hole to grip the entire length without bowing.
• Use your bending brake to make the hat stiffeners. See my entries for 3/9/2007.
• Think through your drilling process carefully. I devised a 4-step process that worked perfectly for me (3/17/2007 entry).
• Step drill your bolt hole for the AN-4-10 bolt, working up to a “D” bit, followed by a ¼” hand reamer.
• When you are ready to rivet, immobilize all open rivet holes. The AN-470-AD-5 rivet holes can be held together with the black clecoes. The AN-470-AD-6 rivet holes are too big for clecoes, so I went with AN3-10 bolts (using a washer on both sides). This made the stack very rigid for final riveting.
• Riveting has its own rules. I’ll make another “cheat sheet” on that in the future.
Disclaimer: I realize there are a number of ways to make your spars. These are just the ways that worked for me.
For more details, you can look at my site (http://mykitlog.com/lwinger) between 2/17/2007 and 5/28/2007. Good luck and feel free to email me off-list if you have follow-up questions.
_________________ Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger |
TxDave
Posted: Mon May 28, 2007 9:52 pm Post subject: Re: Scratch building the wing spar |
Hey John,
Herb Heaton has some great photos posted here.
Being able to visualize Herb's spar construction really helped me.
http://www.matronics.com/photoshare/zenith-list.html#Top
Dave Clay
sky_ranger161
Posted: Tue May 29, 2007 3:12 am Post subject: Scratch building the wing spar |
Hey John! Welcome back. I wondered what had happened to you. I saw that you were building a new shop and figured you were tied up with that. I'm still going to order one of those cool hats from your friend.
Although I'm certainly no expert, I documented scratchbuilding my spars on my kitlog site. Check it out. If you're like me, having a number of resources to draw from gives me a good idea of what I'm getting myself into. Scratchbuilding your spars is totally do-able, just be prepared to do your best, most accurate work, and be prepared to learn a few new skills (solid riveting, precise hole drilling, etc.). Here's the link:
www.mykitlog.com/debo
Debo Cox
Nags Head, NC
XL/Corvair
Working on wings
jhines
Posted: Tue May 29, 2007 5:39 am Post subject: Re: Scratch building the wing spar |
Thanks for all the info and incouragement. I am still finishing up my shop but I am dieing to get started again.
Posted: Tue May 29, 2007 2:16 pm Post subject: Scratch building the wing spar |
I set my drill press in the middle of the shop with roller stands on both
ends. As Ron says, there's more than one way to skin a cat.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
You'll need to set up your drill press either in the middle of your table
| Quote: | Disclaimer: I realize there are a number of ways to make your spars.
