		| Author | Message |
		| Daniel.Snow(at)wancdf.com Guest
				|  Posted: Wed May 30, 2007 7:47 am    Post subject: Need Master Cylinder Spring Info |   |
				| My brakes are sticking and I would like to install return springs on the
master cylinders.  Has anyone added springs, and if so, can you provide
 details?
 Daniel Snow
 RV-9A, 34 Flight Test hours
 | |  |  | - The Matronics RV-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?RV-List
		| Back to top |  |
		| dennis.glaeser(at)eds.com Guest
				|  Posted: Wed May 30, 2007 12:20 pm    Post subject: Need Master Cylinder Spring Info |   |
				| I'm not flying yet, but decided to add 'helper' springs while I have
better access (top fwd skin not yet riveted).
 I went to the aviation aisle of my hardware store and found springs that
 were 3/8" ID and 3" long. 3.5" long would be better, but that was all
 they had.  I stretched the springs a bit to get more 'help' at the end
 of the stroke.  Another approach would be to either add washers, or a
 short piece of tubing to compress the spring when the shaft is extended.
 The ends of the springs had to be bent away a bit because they dragged
 on the shaft, but once that was done, they slide easily.
 I put a washer down first, then slid on the spring. I was going to put a
 washer at the top as well, but it interfered with the mount. I wish I
 had thought of doing this before the rudder pedals were in the airplane,
 and I don't envy you having to do it on a finished airplane.
 Dennis Glaeser
 RV-7A - starting to paint, waiting for my engine
 details?
 Daniel Snow
		| Back to top |  |
		| Mark Phillips in TN
				|  Posted: Wed May 30, 2007 12:38 pm    Post subject: Need Master Cylinder Spring Info |   |
				| In a message dated 5/30/2007 10:49:58 AM Central Daylight Time, Daniel.Snow(at)wancdf.com writes:
  	  | Quote: |  	  | Has anyone added springs, and if so, can you provide details?
 Here's what I did:
 http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=17458
 ...and by the way- I just added the above log entry to my Expercraft website after not even looking at it in over a year, and even with a new format was very easy- Riggen is a genius and I highly recommend his service!  (unsolicited, uncompensated and unconditional support for Expercraft- great stuff- Thanks again Rob!)
 From The PossumWorks in TN
 Mark
 See what's free at AOL.com.
 From The PossumWorks...
		| Back to top |  |
		| rv9jim(at)juno.com Guest
				|  Posted: Wed May 30, 2007 1:03 pm    Post subject: Need Master Cylinder Spring Info |   |
				| Dennis,
Use a "set collar" on the top to provide the tension you want.  I
 did it to my brake cyl on both sides.  check out my web site for the
 details.  If you can not find it there, I can e-mail you the pix I have
 on how I did it.   You should use a flanged oillite bushing on the bottom
 so the spring rides on it rather than the topof the cyl.
 www.expercraft.com/jimn
 Jim Nelson
 RV9-A
 N15JN
 95% done and 50% to go
		| Back to top |  |
		| seipel(at)seznam.cz Guest
				|  Posted: Wed May 30, 2007 1:29 pm    Post subject: Need Master Cylinder Spring Info |   |
				| I used the following from McMaster Carr (www.mcmaster.com):
 1  6389K625   Nylon Bearing Flanged, for 3/8" Shaft Dia, 1/2" Od, 3/8"
 Length, Packs of 5    $1.71
 1  9657K115   Steel Compression Spring Znc-Pltd Spring-Tempered, 3" L,
 1/2" Od, .047" Dia, Packs of  12    $5.29
 4  9946K13     Aluminum Set Screw Shaft Collar 3/8" Bore, 3/4" Outside
 Diameter, 3/8" Width     $1.82
 for a total cost of about $19 after shipping.  Picture is attached.  Not
 flying yet, so I don't know how well it works.
 PJ Seipel
 RV-10 #40032
 Snow wrote:
  	  | Quote: |  	  |
 details?
 Daniel Snow
		| Back to top |  |
		| Mark Phillips in TN
				|  Posted: Wed May 30, 2007 1:34 pm    Post subject: Need Master Cylinder Spring Info |   |
				| In a message dated 5/30/2007 3:23:11 PM Central Daylight Time, dennis.glaeser(at)eds.com writes:
  	  | Quote: |  	  | I wish I had thought of doing this before the rudder pedals were in the airplane,
 Man, have you got THAT right!
 Mark do not archive
		| Back to top |  |
		| garrys(at)tampabay.rr.com Guest
				|  Posted: Wed May 30, 2007 2:06 pm    Post subject: Need Master Cylinder Spring Info |   |
				| I agree with Jim Nelson's post.  My brakes were dragging too, and Jim fixed
me up with the Oillite bushings and set collars.  The springs can be found
 at most major hardware stores.  Works great!  Check out Jim's website.
 Garry Stout
 RV-7A  Tampa Florida
		| Back to top |  |
